Question about Daewoo DSP4210GM 42 in. Plasma Television
My 42' daewoo plasma , model no.DPP 42 A2 is not taking remote control's command. on showing to a TV repair engineer, i was told that the control board is to be replaced. pls tell me where i can get the tuner or the control board from? pls give me their mail id or contact no.
Alrite if your plasma power supply fails its either the fuse or A comman heat seak needs to be replaced or welded back to the board if this happes you plasma will short out the screen and the tv will work but no picture they will say I the video board was out but really it just burned out the lower power or low feq there is a tiny switch on the main power board saying h-L flick the switch to H and turn down the picture refesh a 8th of a turn to the right And ur screen should flicker on the turn it back a qurter of a turn to the left and boom A working dawooo tv :) its a easy fix just remeber to turn down the refresh rate else u will blow it up
Posted on May 21, 2012
Alrite if your plasma power supply fails its either the fuse or A comman heat seak needs to be replaced or welded back to the board if this happes you plasma will short out the screen and the tv will work but no picture they will say I thought video 4 days out but really it just burned out the lower power or low feq there is a tiny switch on the main power board saying h-L flick the switch to H and turn down the picture refesh a 8th of a turn to the right And ur screen should flicker on the turn it back a qurter of a turn to the left and boom A working dawooo tv :)
  • Daewoo Master
  • 8,457 Answers
Try website like Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Oct 01, 2010
We have a 42' plasma flat screen model PD46C10. All of a sudden it went to a white screen with daewoo in blue. No remote function, no controls function on TV base. Won't shut off unless unpluged. Any...
is it perhaps a built in screen saver? try changing channel on remote. or check to see if input is on aux / or component/ dvd etc.. or possibly there is an access code (parental setting) try that first. hope it helps.
Oct 17, 2010 | Daewoo Televison & Video
PINK SCREEN ON DAEWOO PLASMA TV
Sounds like your panel might be going out or a faulty video card. This is the first time I have heard of a solid pink screen on a plasma. Usually this happens on LCDs, though they sometimes go white and stay white, which does signal a bad panel. tv needs repair
May 09, 2009 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo Plasma dp-42sm
Just answered this on a different one. I have the Daewoo Plasma Digital Dream model dp-42sm, My dads tv expert friend looked at it and told us the ysus board was out. I got on ebay and bought the item from a store for 125 dollars used tested good with 12 dollar shipping, I put the part in myself it was very simple just take your time dont try and rush you have to take the actual bar the stand hooks onto off and the 2 boards going into the ysus board. It fixed the problem and is still in working order im using it now as the computer monitor.
Feb 28, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
42' plasma daewoo tv with vertical color lines.
the way how you described it looks like the screen is cracked but problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Feb 05, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Daewoo screen in a samsung
probably not,,,you need to look at the back of the plasma panel itself and see who really made it..the samsung is probably a samsung panel while the daewoo might be from lg..
Sep 21, 2007 | Televison & Video
Theoretically yes functionally no. Not unless the parts are the same, chack the model numbers of the plasma screens. If they match you can change them out, if not don't try it.
Sep 21, 2007 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Remote control does not work for my plasma tv
I also had this same problem. Both the original remote and my universal remote failed to give any response on the TV. Normally the green light flashes when it receives a command from the remote. Called LG Support and they made me an appointment with a local repair company for 3 days later. This seemed pretty quick compared to other companies repair times I'd read about. However next day the repair company called to say it would be 5 more days before they could get a Tech to my location (downtown ATL). 8 days was a long time to wait but once tech arrived he diagnosed it to a bad board and simply went to his truck and swapped it out with mine under factory warranty. Everything has been fine since.
Jul 25, 2007 | LG 42PC3DV 42 in. Plasma EDTV
Daewoo DSP4210GM 42 in. Plasma Television Logo
148 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
