No phono stage in arcam a85 so my truntable is deed please solve the problum
2 Suggested Answers
  • 5603 Answers
SOURCE: How do i connect a truntable to this? There is no
The answer is you don't... You need a phono preamp which you then can connect to the aux inputs such as the cassette tape inputs.
Normal phon cartridges do not put out sufficient levels to go directely into these inputs.
You can buy phono preamps, possibly even at Radio Shack or other home audio stores.
Posted on Jan 13, 2010
I've been given a Technics sl-bd22d turntable, an Arcam amplifier and a Cambridge 551P pre amplifier. How do I connect them all together?
Depends what type of sockets these have. If the Pre-Amp has a RCA phono sockets you just need some RCA leads. I don't know if the Arcam Amp works with any pre-amp. But if it does, it's likely to have the same type sockets as the others. So you just buy another two RCA leads and connect it up.
Apr 19, 2013 | Audio Players & Recorders
Arcam A65 amplifier keep on go to standymode why?
Depending on the volume level and how many speakers you are driving factor into how the amp will react. Check the speaker wires for shorts, if okay! then we must look at the audio output stage, if the semiconductors are getting to hot, the satety circuits will cause a shutdown, if you run a pair of speakers the amp will run cooler, if you recently added more speakers that would explain the shutdown, if not! there is a problem in the audio output transistors and ic's that will need to be dealt with.
Apr 14, 2012 | Arcam Audio Players & Recorders
Connected to turn table. having sound problem. At 99, sound hardly audible.
The bose as most all in one systems do not have an inbuilt phono stage. Phono especially MM type have a very low signal and an eq curve that gets altered in the phono stage. Without a phono stage (known as a phon pre amp) you will not get much fun from your turntable. To connect : turntable out - into phono preamp - phono pre amp out into bose line in/aux in
Sep 28, 2010 | Bose Wave Music System CD Shelf System
How do i connect a truntable to this? There is no Phono input???
Jan 13, 2010 | Marantz SR-9200 Receiver
Picthure has gotten shorter and shorter over the last few months and now only fills 1/3 of the screen
this problum is vartical stage in tv set pls check vartical stage capaciter or pf .
470uf/63v /1000uf/63v 4.7uf/50v /0.47uf/50v cheked or Replace all vartical stage capaciter .this problum is not creat long time in futuer.
Oct 04, 2009 | Televison & Video
I get no sound when connected to CD connection
if there is no phono input,you need a pre amp to drive it.the record player puts out 5 mv from the cartridge.
a cd player is 800 mv to one volt output.
the turntable can not drive the cd input.
a phono pre amp also has a 60db gain from 20hz to 1khz to offset the -60 db curve when records are made to reduce the groove modulation.
without the bass attenuation,record grooves would have to swing 4" for bass notes.
google RIAA equalization curve for a description.
Sep 01, 2009 | Yamaha HTR-5830 Receiver
I have recently purchased a arcam alpha 10 amp to go with my arcam alpha 9 cd player and my monitor audio rs8 speakers. I am pleased with the amp and i am thinking of adding the power amp, the problem is i...
A better solution is like I have mine; use the Arcam 10 connected to the tweeters of your speakers & the power Amp connected to the woofers & link the pre out's on the 10 to the power Amp. using phono cables. The Manual can be downloaded from Arcams discontinued section of their website.
This Bi-Amp method gives a far superior sound than just using the 10 as a pre Amp.
May 04, 2009 | Audio Players & Recorders
We have teh truntable properly connected to the computer but the computer isn't recognizing the turntable. The turntable turns, but we get no sound through the computer.
hi, first you have to take a pre amp phono, or a mixer for your phono....to amplified the signal coming from your vinyl...please check first..tnx
Nov 28, 2008 | ION Audio Vinyl Recording Turntable
Arcam avr300 intermittent problems
I had this same problem with my Arcam AVR300. I ended up shipping mine to an Arcam repair center and they repaired it and shipped it back for under $200. The problems were cracked connection on the start relay and they replaced power supply diodes. Very well worth it and now I can enjoy it again!
Jun 30, 2008 | Arcam AVR-200 Receiver
Arcam CD73 fault
Hi there. I would check the power supply rails, you have probably lost a volatge about the Audio line output /DA stages. Check voltage reg packs, they fail alot. I have repaired a few of these over the years, hit me back if you need to go further.
regards
Graeme
Mar 27, 2008 | Audio Players & Recorders
67 people viewed this question
 Grubhead
Grubhead
