Question about Pioneer Car Audio & Video
I have an older Pioneer TS-LX100 powered car subwoofer. It is missing the power plug, which is used to connect the 12v+, remote, ground, and speaker level inputs. It is an 8-pin connector. I have a power plug from a different item that fits like a glove but I do not know which wire is which. Do you have access to the wire scheme? Thanks, -Mark
  • Pioneer Master
  • 10,045 Answers
You can splice one wire at a time instead of cutting them all at once. Just cut one wire, splice the same wire from the old connecter to the new one. You can identify which pin is which by using a multimeter to find 12 volts and use it set to continuity to see what pin is connected to the wire you just cut.
Posted on Oct 08, 2016
2 Suggested Answers
  • 10 Answers
SOURCE: I need the connection diagram for the carrozzeria
OOO i know diagram can get time all google at
Posted on Jan 19, 2010
I have a pioneer GM-X524 amp connected to a TS-W253C subwoofer and it isn't working. It has 12v power to it and a solid ground, but the power light wont come on and the sub isnt working
there should be 3 power related cables connected to the amplifier:
1-From battery to amp via fuse (positive)
2-From chassis of car to amplifier (negative)
3-From head units (power continuous) (blue or blue/white cable) to the amplifiers remote connection.
this connection enables the amplifier to switch on when the head unit is switched on and off when the headunit is switched off.
I hope this helps and let me know if I can further assist you.
Jan 06, 2014 | Pioneer Car Audio & Video
What amp to use for two pioneer ts-w307d4 car subwoofers
Just get 2pi amp pros at1200 watts. That way u have full control of the bass u need. Just remember to turn the amps down the subs are a little under rated. Done this myself and it is a great sous. There not a good pro sub but they will do the job in a mid size car
Jan 30, 2012 | Pioneer TS-W307D4 Car Subwoofer
Pioneer KEH-8031ZT connection diagram of power and speakers
There are two kinds of pioneer color codes:
pre 1999
P o w e r Memory (+12v Constant) Orange Ignition (+12v Switched) Red Ground (-) Black Illumination Yellow Phone Mute Yellow/Black Power Antenna Blue S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) Green Left Front (-) Green/Black Right Rear (+) Gray/Red Right Rear (-) Black/Gray Left Rear (+) Green/Red Left Rear (-) Black/Green
and 2000 or newer
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Jul 01, 2011 | Car Audio & Video
What is the color codes to a pioneer dxt-2266ub? putting it into a 1997 firebird.
Yellow = Radio Constant 12V Batt +
Red = Radio Switched 12V Acc +
Black = Radio Ground Neg -
Blue/wht = Remote Amp turn on or Pwr Ant
White = Left Front Speaker Wire (+)
White/blk = Left Front Speaker Wire (-)
Grey = Right Front Speaker Wire (+)
Grey/blk = Right Front Speaker Wire (-)
Green = Left Rear Speaker Wire (+)
Green/blk = Left Rear Speaker Wire (-)
Purple = Right Rear Speaker Wire (+)
Purple/blk = Right Rear Speaker Wire (-)
RCA = Output to Amp
Owners Manual =
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 6 1/2′ Speakers
Front Speakers Location: Doors
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6 1/2′ Speakers
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Hope this info helps
please let me know if you need any further info
May 20, 2011 | Pioneer Car Audio & Video
Wiring diagram for pioneer fe1730 please
Older Pioneers used a different code. icon_wink.gif (BTW the orange in the newer code is for dimmer)
Orange - 12V constant
Red - 12V switched (acc)
Black - Ground
Green - Left Front +
Green/Black - Left Front -
Grey - Right Front +
Grey/Black - Right Front -
Green/red - Left Rear +
Black Green - Left Rear -
Grey/Red - Right Rear +
Black/Grey - Right Rear -
Oct 26, 2009 | Pioneer Car Audio & Video
I cant figure out the wiring digram for the DEH-245 pioneer stereo
Yellow = +12V constant (Battery)
Red = +12V switched (Ignition Switch)
Black = ground
Blue-white = Remote On
White/White-black = FL speaker
Grey/Grey-black = FR speaker
Green/Green-black = RL speaker
Purple/Purple-black = RR speaker.
May 30, 2009 | Car Audio & Video
Connection Pioneer TS-W65A
you are probably looking at a dual voice coil subwoofer. This means you have many options of wiring in series/parralel/or bridged parralel. Go to either or crutchfield's learning center in order to figure out what your options are. Then you need to find out what ohm your subwoofers and what ohm your amp is stable at.
May 05, 2009 | Pioneer TS-WX65A Car Speaker
Ts-wx105a pioneer subwoofer connection to car stereo
1 I 2 I 3 I 4 I
---------------------- the wiev from woofer
5 I 6 I 7 I 8 I
1- Right Chanel (-)
2- Right Chanel (+)
3- Left Chanel (-)
4- Left Chanel (+)
5- NC (not connected)
6- GROUND ( - )
7- POSITIVE ( + )
8- Remote (from HU)
Apr 26, 2009 | Car Audio & Video
My subwoofer will not go
Is the SUB connected to both channels? I will give you detailed instructions on how to connect a sub. Check out this website.
Mar 03, 2008 | Pioneer TS-W307D4 Car Subwoofer
Car Audio & Video Logo
540 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
