Question about Cyber Acoustics AC-201 Consumer Headset
Cyber acoustic headsets
I bought a cyber acoustic headset for my Dell Pc. I can hear but the microphone does not work. When I run Test Wizard there is no sound
  • 3 more comments
  • superwheneve Aug 10, 2008
    I have the same problem. Im using this headset on ventrillo with windows vista - I can hear fine but when I try to speak they just get a jumble of fuz or nothing at all. I changed my hardware quality settings once and it seemed ot work but that was a fluke - its no longer working. Help!
  • Anonymous Sep 15, 2008
    IT WONT WORK, it says everything is working fine, but my voice wont output
  • millcreek196 Nov 28, 2008
    I tried to use this headset on my Toshiba laptop for Skype. I could hear the other person fine, but they said my voice sounded distant and like I was in an echo chamber. I tried adjusting the settings, but sound quality did not improve. Is there a specific driver that needs to be downloaded for this headset to work properly?
  • Anonymous Mar 01, 2009
    i hear just fine but on ventillo my mic is just fuzz what do i do ?
  • Anonymous Mar 28, 2014
    Won't work when it is plugged in together
Make sure that your mic is ot muted cause thats what happened to me also check it when ur done in your audio manager
Posted on Aug 28, 2008
Cannot call out
There must be a button to turn on the microphone, you did not do that so you could not call out. Suggest you to look for it then try again.
Tablet pc
Jan 10, 2012 | Cyber Acoustics AC-840 Headset
Cyber Acoustics AC-201 Micrphone Problem
i have cyber acoustics headset and i cant hear anything but my Mic works, my sound is all fine, when i plug my headset out i can hear but when its plugged in, i cant hear anything.
Mar 09, 2010 | Cyber Acoustics AC-201 Consumer Headset
Microphone isnt working
u have to set it up from the computer....go to control panel and audio configure and itll show the rest that would be easy for u to follow....
Oct 06, 2009 | Cyber Acoustics AC-634 Consumer Headset
Headset works, microphone does not.
Try to look for the microphone volume in your control panel. Maybe it is just on mute.
Sep 03, 2009 | Cyber Acoustics AC401 Consumer Headset
Cyber acoustics ac-201 and it doesn't work!!
Hi itsonlyerin,
This has to be rather general as it's a bit hard to give you specific advise without knowing a bit more about your operating system and sound card.
Try checking the following:
(1) Headphone problem
First, I would try to determine if there is a problem with the microphone itself. Do you have another pair or a different model that you could try? If yes, then give them a go and see if the other ones work. If they do then take your ac201's back to the store and get a replacement. If you haven't got another pair then try them in another computer and see if you get a different result. If they work in a different computer then the phones are OK and we need to look into the computer hardware and software.
(2) Software Setup problem.
Have you made sure that on the recording controls that the microphone volume is turned up?
(3) Sound Card setup problem.
Some sound cards have multipurpose jack that for example can be switched between line input and microphone. Check with the card's documentation and especially check that the jack you are using is set to microphone and that you are plugged into the right one.
(4) Software problem - do you have the right drivers for your sound card loaded?
(5) Faulty Sound Card - try a different one.
Good Luck
Jul 06, 2009 | Cyber Acoustics AC-201 Consumer Headset
I have a head set, cyber acoustics AC-634. The microphone part is working but no sound is coming up
hi don, try looking at the ear pieces and see if there is not some plastic film covering the ear holes . ran into that on 2 of my motorlas. good luck
Jan 24, 2009 | Cyber Acoustics AC-634 Consumer Headset
My brand new Cyber Acoustics HS-600 headset microphone won't work with AIM
Hi Bob,
The first thing to check is that nothing is muted/turned down low in the Volume Control/Mixer. Then you need to go into the audio settings in AIM and select a different Microphone from the list. The one set to default is not the one you need. You'll either have a USB input/output for the headset or 2 jack plugs for input and output. These use different drivers on the computer. So just try using the different drivers from the list, one call at a time, remember to reboot AIM as you try each different one, and that the microphone volume settings are turned up in the AIM programs as well as you Volume Control/Mixer.
Hope this helps you progress
Chris (ziraffa)
Jan 12, 2009 | Cyber Acoustics 3-in-1 Headset/Mic Headset
Vista Ultimate -Microphone on Cyber Acoustics Headset not working
Here you go http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_PM_1720&os=WLH&osl=en&catid=&impid go
their its the dell drivers page for Vista, download the drivers their for the microphone and you can
also download things you might need for the computer
Hoped this really Helped,
Thanks!
Dec 24, 2008 | Microsoft Windows Vista Ultimate Edition
Headset wont produce microphone function
u do not need any software to run it sounds like you was duped, crooked, fooled into buying some not quite right somewhere in the system a wire is broke........go to the shop and buy a genuine one and never again buy off some crooking basdard cause the basdards are false......
Jul 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Cyber Acoustics AC-840 USB Headset
heyo...for you online meetings...I am assuming you are using Skype. Check the volume settings in the TOOLS and OPTIONS, audio settings, audio in&out, using the drop down menu for microphone and speakers. Save.
If that isn't a problem, it could be a setting in Windows (also assuming you are using XP). Go into your Control Panel, SOUNDS&AUDIO, Audio tab, check your volume there.
Wayne
Dec 06, 2007 | Cyber Acoustics AC-840 Headset
Cyber Acoustics AC-201 Consumer Headset Logo
566 people viewed this question
Top Cyber Acoustics Radio Communications Experts
Josh Whitehead
Josh Whitehead
Clementina Emerson
Clementina Emerson
Level 1 Expert
Tom Chichester
Are you a Cyber Acoustics Radio Communication Expert? Answer questions, earn points and help others
