Question about Lexmark X2250 All-In-One InkJet Printer
Lexmark X2250 says print cartridge is missing but both are there. Not sure how to solve this problem? It shows an image of the black ink level when notification pops up.
  • Lexmark
    Lexmark Oct 01, 2010
    You can do the Clean Nozzle function using the Lexmark Solution Center or manually wipe the nozzles of the cartridge to free it from ink clogs. Make sure the cartridges are properly seated in the cartridge carrier. Poorly refilled/remanufactured cartridges (by third party) may not be recognized by the printer. If problem continues, replace the cartridges (preferably genuine Lexmark cartridges). If these tips don't help, contact Lexmark technical support.
SOURCE: Lexmark all in one 4270 won't print in black
I know your problem. I just put in new cartridges and it will print the test page, but nothing else. Did you get an answer
Posted on Sep 12, 2008
SOURCE: computer says there is no ink cartridge
OK guys, I don't know if this will work for you but it worked for me. Here it is:
  1. Uninstall all Lexmark software from Add/Remove Programs in Control Panel.
  2. Reboot the computer as suggested by the uninstall software
  3. Start the ALL-In-One Installer
Now, the first thing the installer does is load the drivers to your hard drive.
4. When the driver is installed it will ask you what ink cartridges you have. Tell it which ones you have and say they are both brand new (even if one is empty or not new). If it asks you to align the printer or print a test page, say no!
After this is complete, the installer will begin to put in the other software (i.e. fax and scan). It will pause and ask you to click next, but do not do this.
5. Press Ctrl+Alt+Delete, select the installer task and click end task to stop the installation process.
6. When you print for the first time, it may ask you what cartridges you have installed again. Just select the cartridges you have installed select the option from the drop-down boxes that say that both cartridges are new.
Hope it helps since it worked for me. Good Luck
Posted on Oct 20, 2008
sheikhakhlaq
SOURCE: printer not printing
plz give me laxmark X 2250 printer driver
Posted on Jan 22, 2009
rwandrew
  • 115 Answers
SOURCE: Lexmark x4850 ink levels won't reset with new cartridge
Hi...
Silly question, but I have done this myself. Have you removed the tape from the bottom of the cartridge?
Posted on Jan 25, 2009
sifon
  • 29 Answers
SOURCE: Lexmark x5495
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
929
Posted on Mar 03, 2009
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
WITH THE LEXMARK X2250 ALL-IN-ONE PRINTER CAN I USE THE COLOR INK CARTRIDGE TO PRINT BLACK, IF MY BLACK CARTRIDGE IS EMPTY? HOW CAN I DO THIS?
when your black cartridge goes empty , the printer automatically goes into the reserve mode where it mix up the colors in the color cartridge to produce black color
Aug 06, 2012 | Lexmark X2250 All-In-One InkJet Printer
Lexmark S405 : printer will not print until the black ink cartridge is replaced
Smash printer with axe or sledgehammer. Grin maniacally. After researching on internet,go out & buy new printer that allows you to print till empty & refill again! Obviously not a Lexmark...
Jul 21, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Lexmark X4650 InkJet Printer black prints fuzzy. Color is fine, but the black appears out of focus.
Try to check and make sure your black ink level is still good and not about to go empty. On the printer operator panel, press the Setup button > Maintenance > Ink Levels.
If the black ink level is still good, make sure the cartridges are aligned. Try this approach. On the printer operator panel, press the Setup button > Maintenance > Align Cartridges. Your printer will then print a page forcing ink through the cartridge nozzles and clean them as well as align the cartridges.
Try to print a document again to verify that the print quality has improved.
Oct 11, 2011 | Lexmark X4650 InkJet Printer
My pro905 stopped printing in black although cartridge is showing 50% full. what could be the problem?
Make sure you are using genuine Lexmark cartridges. It could be that your black cartridge needs cleaning. Try to do the Deep Clean Printhead function on the printer. Press Ink Levels -> press More Options -> select Deep Clean Printhead. The printer will then print a clean cartridge nozzles page. If black ink is not printed on the page, you may need to update your printer's firmware. The update corrects print quality issues on your printer. You can easily download and install the update using this link Lexmark Platinum Pro905 Firmware Update. Download and install the Pro905 update. Thanks.
Jan 04, 2011 | Lexmark Platinum Pro905 multifunction...
My documents will not print the colored part. just Black and white
I would first check to see how low the color cartridge is. If it is out of ink, you will need to replace it.
Your Lexmark has two cartridges, one for colors and one for black.
To check the level of the ink cartridges, go to the Lexmark Solution Center. This is the software that was installed to run you Lexmark printer.
Check the cartridge ink level images that appear on each tab. If a cartridge is low, or if you have received an Ink Low message on the computer screen, install a new cartridge. An empty or low cartridge is marked with an exclamation point ( ! ).
To order print cartridges:
1 }}--> }}-->Open the }}--> }}-->Lexmark Solution Center .
2 }}--> }}-->Click the Contact Information tab.
3 }}--> }}-->Click Ordering Ink and Supplies.
For help installing a cartridge, go to How to install the print cartridge.
Dec 30, 2010 | Lexmark X6150 All-In-One InkJet Printer
Refill inkcartridge 17 of lexmark x2250 don't work
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 28, 2009 | Lexmark X2500 All-In-One Printer
Printer not printing
Jan 18, 2009 | Lexmark X2250 All-In-One InkJet Printer
Lexmark X2250 All-In-One InkJet Printer Logo
219 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
