Question about Epson Stylus NX105 All-In-One Printer
Two days ago, I was able to print documents perfectly. However when I tried today, the pages came out completely blank. I am not out of ink, but nothing is printing onto the paper.
    Scholar:
  • 136 Answers
Do a System Restore on your computer. That may reinstall the driver. Restore it to a time the printer was working. If using Windows, Go to start-acccessories- tools. Then down the list to System Restore.
Posted on Nov 11, 2011
What is wrong with my HP Deskjet D2330, and why is it printing only blank pages?
well it has got to be the ink cartridge. wipe of the bottom of it and make sure black ink shows up
Dec 10, 2014 | HP Deskjet D2360 InkJet Printer
Calibration ok but still prints blank pages
If the print tests are good, the only thing preventing your printer from printing is the print drivers. Download the latest correct drivers from Kodak's website and install them.
Nov 19, 2013 | Kodak ESP Office Equipment & Supplies
Lexmark printer not dispensing ink
First, make sure you are using genuine Lexmark cartridges.
Second, try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
If the firmware update doesn't help, please perform a maintenance on the cartridges. To do that, on the control panel of your printer, press on Setup > Maintenance > Deep Clean Printhead.
If it still doesn't help, please contact our technical support team.
Jan 08, 2013 | Lexmark Impact S305 - multifunction ...
Prints blank page first then freezes on the second page.
Blank or partial page printed
1. Clean the ink cartridge. (a) Complete the ink cartridge cleaning procedure.
2. Check the media settings. (a) Make sure you select the correct print quality settings in the printer driver for the media loaded in the trays. (b) Make sure the page settings in the printer driver match the page size of media loaded in the tray.
3. There is a blank page in the file. (a) Check the file to make sure there is no blank page. Something on the page is missing or incorrect (b) Check the margin settings Make sure the margin settings for the document do not exceed the printable area of the device.
4. Check the color print settings. (a) Make sure Print in Grayscale is not selected in the print driver.
5. Check the device location and length of USB cable. (a) High electromagnetic fields (such as those generated by USB cables) can sometimes cause slight distortions to printouts. (b) Move the device away from the source of the electromagnetic fields. (c) Also, it is recommended that you use a USB cable that is less than 3 meters (9.8 feet) long to minimize the effects of these electromagnetic fields.
6. Check the ink cartridges. (a) Make sure the correct ink cartridges are installed and the ink cartridges are not low on ink.
Dec 20, 2017 | HP Officejet 4500 All-in-One -...
My lexmark x3650 printer will print, but the pages come out blank. did a test to see if there was no ink and the diagnostic said 40% ink is still in there.
Try this approach instead:
  1. From the printer operator panel, press Setup button.
  2. Select Maintenance.
  3. Select Clean Cartridges. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them.
  4. Once the test page is complete, try to print your document again to verify that the print quality has improved.
Aug 21, 2011 | Lexmark X3650 Printer
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Printer output is a blank page
hi,
* Please check with the ink level in the Catridge.
* Be sure that catridge nozzle is not dry or dirty.
* Check wheather ink nozzle is clogged/ damaged if so use rubbing alcohol to clean them.
* Try printing by replacing new catridge.
Thanks,
Appereciate to rate as "FixYa"
May 23, 2009 | HP PSC 2210 All-In-One InkJet Printer
Blank pages
You might want to start by doing some general print quality troubleshooting, including printing a test page. The test page should give you an indication if you have issues with print cartridges. Also, some printers may not print at all if even one of their cartridges is empty:
Correcting Print Quality Problems
The other thing that occurred to me is that your document feeder could be pulling in more than one sheet of paper at a time, this means it would output blank sheets as well. Here's a web page that describes the problem and what to do about it:
Automatic Document Feeder Error
Hopefully the answer to your problem is available in those web pages. Good luck.
Sep 07, 2008 | HP OfficeJet 4215 All-In-One InkJet...
No ink showing on page
there is no issue with the cartriage this issues occur most of times open the printer clean all parts and try again
Jan 24, 2008 | HP Deskjet 3845 InkJet Printer
Photo printing
It is definite one cartridge is not running. You do one thing - 1. Write documents in MS-Word - select all - change the color to Red. Take print out. Check Printing is perfect or not.
2. Write documents in MS-Word - select all - change the color to Cyan. Take print out. Check Printing is perfect or not.
3. Write documents in MS-Word - select all - change the color to Yellow. Take print out. Check Printing is perfect or not.
I am sure when you changed the color to Cyan - it did not print Cyan or blank page you got.
So you must replace the Cyan cartridge or may be ink is not coming out through the passage. And first you have to check whether you have removed the plastic tape from the head of t he cartridge.
Oct 25, 2006 | Canon I900D InkJet Photo Printer
Epson Stylus NX105 All-In-One Printer Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
