Question about Whirlpool Refrigerators
IN THE BOUBLE DOOR, LOWER UNIT IS NOT COOLING AND SOME SOUND IS ALSO COMING IN INERVALS
    President:
  • 2,559 Answers
This can be the defrost cycle has failed and the sound would be from ice build up, Please provide more details for more help..
Posted on Oct 01, 2010
Why won't the dehumidifier collect water after filter was cleaned.
Is the unit set low enough? Is there humidity to be removed? If the fan runs once it sounds as if it's going through an air sampling cycle and not needing dehumidification. Try lowering the set point.
Dec 12, 2017 | Filter Heating & Cooling
Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Jul 10, 2007 | Sharp CV-P09FX Air Conditioner
When we shut the fridge door a loud continuous humming noise comes from the fridge. This seems to be activated by the door light switch at the top. Thank you
There are 2 possibilities I can think of for the hum. When you activate that door switch it activates 2 fans and the compressor. There is one fan located on the compressor and one located in the vent system in the fridge. The second fan is used to circulate cool air evenly through the fridge. I would recommend holding your finger on the door switch and listen carefully whether the noise is coming from inside the back of the fridge or from the lower bottom. Lower bottom could indicate compressor cooling fan or compressor. They would need to be inspected. If it sounds more like the other fan mentioned above it would again need to be inspected. The compressor cooling fans can get stuck or become noisy due to bearing failure. The vent fan can get stuck or noisy but also in some cases if the defrost circuit is not working can chock up with ice and create a buzzing noise as the fan blades strike the ice.
Jan 13, 2017 | Refrigerators
Model LFX28968ST. Why is water dripping onto lower freezer drawer?
Richard, sounds like the drain plug/ hole is plugged.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
LG Freezer repair French Door bottom Freezer model
Appliance Repair Forums
LG 819 739 refrigerator not cooling or water leakage how to fix repair by...
How to Unclog Refrigerator Drain Line
Mar 12, 2016 | LG Refrigerators
Why can't I lower my honeywell 8500 below 67 on cool?
With a two story house you have to be aware that cold air flows downwards so any cold air coming from an ac unit will flow downstairs( normally down the stairway) so unless you can close off the down stairs then the up stairs unit will be cooling downstairs as well. Ac units have a thermostat located in the air intake and it cools until the cold air has risen to that point. In effect the space above the ac unit will be hotter than the floor. Knowing how they work ,you can see that the upstairs unit will never reach the set temperature because the cold air is continually heating from the house and will never get to the top thermostat.
So your solutions are
1-- fit controls that restrict the cold air from leaving the upper floor (Doors)
2--don't run the upper ac unit unless you are living up there (waste of money
)3 place an ac in each upper room and keep the room door closed
Aug 12, 2014 | Heating & Cooling
My window unit is not blowing cold air. Ive used it a handful of times and it never got cold. How do i fix this?
There are very many possible causes. You do not indicate your model number, but many units take a few minutes before the compressor comes on. If the compressor is not coming on (a low rumble sound, NOT the fan), you'll get no cooling. If the compressor is coming on, and you still get no cooling, it is likely your unit needs a recharge. Things to check: Is the thermostat set lower than the room temperature? Is the unit set to "fan only"? I hope this helps lead you to the problem and a solution.
May 09, 2014 | Heating & Cooling
In Fan mode, fan works; but in AC mode, I can hear the normal AC sounds, except the fan never turns on. This is the fan in the lower half of the unit in the inside of the house, which blows the air...
on a call for air conditioning your therrmastat brings the indoor fan on and the out door unit at the same time. Since your fan comes on in "fan" mode, it sounds like you need a thermastat. For temp. cooling just turn your fan switch to "on" and turn system switch to cool and set desired temp. System will cycle off and on but fan will not shut off until fan control is set back to "auto". I suggest replaceing thermastat
Aug 16, 2011 | Heating & Cooling
Not cooling good
There is a fan down by the compressor that aids in cooling compressor and getting rid of the water that comes out of the freezer during defrost cycle. I am sure that you took the paper cover off the back of the unit on the lower back side so your unit might not have a fan. Now lets look at the fan inside the freezer is it running can you hear it when you open the door? Does the compressor make a clicking sound as it is hot to touch and trying to come on? get back with me ok ken
Jan 31, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
Have WeatherKing Model 10 aja 1801 s/n 6827 m2602 04732
I would say that you are Right.... Sounds like that is it. It's only cooling good lower temp. because it is lower temp. check the temp. of the air coming out. should be about 48 to 55 % anywhere in there is where it should be. But keep in mind the cooler the house the cooler the air will get coming out..
Ken
Sep 23, 2009 | Heating & Cooling
Air conditioning unit not cooling
the problem sounds like a defective capacitor its located on the condensing unit outside, also a contactor that is used can be defective also.
Jun 05, 2008 | Carrier 38CKC036 Air Conditioner
Refrigerators Logo
32 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
