Question about Maytag Performa PAV2200
MAYTAG AGITATOR LOOSE
Hello, i read your reply regarding the loose agitator and i have the same trouble with my maytag,,,but the acutual agittor stays bolted to the tub but the augur like piece that has the softner dispenser on top and slides down over the agititor , comes loose, you can easily push it back down and hear it snap in place , but then it floats off after a few rotations,,any further suggestions ,,,thanks
  • lcorvette Jul 10, 2008
    I have the same problem! I find myself sticking my arms into the washer and agitating the clothes myself!! I don't have time for that!
    Is that the only solution - to buy a new agitator? How does it stay in? There aren't any bolts or clips.
    thanks,
    Laura
  • 868 Answers
Replace the agitator,if you look for a store that sells used machines you'll get the best price. Buy a used one!
Posted on May 26, 2008
My mattress cover is stuck under the agittor un my GE washing machine
We should branded products then we feel comfortable.
Sep 13, 2014 | GE Washing Machines
I have an kenmore elite top loader washer model 110 27087602. During the spin it makes loud clunking noise. I seen the other post about the agittor nut sometimes loose but I do not see this nut under the...
The most probable thing that is making that noise is a broken motor coupler if it drains but the tub doesn't move or even if the agitator doesn't move (espically the lower section) on the wash cycle the coupler is the problem. I have included a youtube video that will show you step by step how to replace the coupler http://youtu.be/9K1KHEogf3c
If it does agitate let me know and ill tell you how to completly remove the agitator to check that drive block you refer to as nut under softner dispenser
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Washing Machines
Top half of agitator does not work
Hi... you need to take the agittor apart and you also need to buy a part call "Dogs" it will show you how to instill them .. its really easy
Thanks
Mar 27, 2011 | Whirlpool LSR5132PQ Top Load Washer
It will fill up with water but wont agitate or drain. i've checked the belts. it's a 10 year old washer but just wanna know if it might be the motor.
hello check the brushes on the motor first there will be 2 plastic blocks either side of each other these usually cause most motor trouble hope it helps
regards
shaun
Jan 04, 2011 | Maytag Washing Machines
I have a maytag MAV5920EWW and i need to know how to get the agitator off as well as the front panel
Hello there:
here isa couple of links below that will show you how to do it ok
I hope that this is very helpful for you
Best regards Michael
  1. [PDF] 16026502 Maytag Amana Top Load Washer 8628k - Adobe PDF - View as html MAV5920EWW. MAV551EEWW. NAV8805EWW. Electronic. Energy Star rated. ... "Agitator/Spinner/Outer Tub/Transmission Removal" procedure. ...www.servicematters.com/maytag_library/docs/16026502.pdf
  2. [PDF] Technical Bulletin 1950k - Adobe PDF - View as html MAV4758AWW, MAV551EEWW, MAV5758EWW, MAV5920EWW, MAVT236AWW, MAVT346AWW, MAVT446AWW, MAVT546EWW ... 4. Remove Agitator by loosening bolt threaded into ...www.servicematters.com/maytag_library/docs/TDL-0086-B.pdf
Nov 22, 2009 | Maytag MAV5920E Top Load Washer
Noise in washer need to know how to remove agitator
For most Kenmore, Whirlpool, Estes, Maytag, and some GE washers the top portion of the agitator can be pried off (either a cap or fabric sofrtner dispenser depaneing on make and model) and there is a bolt underneath. Once removed, the agitator can be lifted straight out. Some GE's you have to actually "pop" the agitator by placing a strap underneath and lifting it out that way. If your are still having trouble, reply back with your model and serial number and we can go from there.
Jun 18, 2008 | Washing Machines
MAYTAG A-606
There are two methods used to hold the agitator in place. The first is a main bolt at the top of the agitator under the softener cup. The second is a small bolt located on the lower portion of the agitator. To access the transmission the tubs will have to be removed.
Jan 11, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Maytag Performa Large Capacity Top-load Washer
the agitator should have a SCREW, AGITATOR RETENTION that holds it on ..see brakedown. unless you are talking about the DISPENSER, FABRIC it should just snap on. let me know if his helps krazytech
Sep 09, 2007 | Maytag Performa PAV2200
Washing Machines Logo
643 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
