Question about Microsoft Windows? Vista Home Premium Edition Upgrade Version for PC (1 Computers) (66I-00021)
My os is vista.yet when it boots i saw a massage "xxxx file is missing" on prompt window
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 52 Answers
The operating system on your computer is Microsoft Vista.
Windows Vista comes with a rich feature set of diagnostic and repair tools that you can use in the event that your computer is not operating correctly. These tools allow you to diagnose problems and repair them without having to boot into Windows. This provides much greater flexibility when it comes to fixing problems that you are not able to resolve normally. Do the foll. :-
To start this process, insert the Vista DVD into your DVD drive and turn your computer on. Your computer will start and you should see your BIOS listing your hardware and other information. When that information is cleared, your computer will see that a bootable DVD is inserted and present a prompt similar to the figure below :-
Incase you do not have your Vista disc (DVD), then your computer MAY be having a Recovery Partition : you boot the computer and immidiately go on tapping on the F8 key, untill you see Windows Advanced Options : using the up & down arrow keys, highlight Repair your computer and then proceed as below :-
my os is vista.yet when it boots i saw a massage - a671445.jpg As you want to boot the computer from the Windows Vista DVD you need to press a key, and any key will do, on your keyboard when you see the above prompt. After you press the key, you should hear your DVD reader spinning up and then you will see a black screen with a white status bar at the bottom stating Windows is loading files.... After a while, the status bar will turn completely white and you will see a screen stating that Windows is loading. The Windows Setup environment will continue to load and when finished you will be presented with a screen similar to Figure below.
e6a0226.jpg At this screen you should configure the Language to install, Time and currency format, and Keyboard or input method options so that they are set correctly. When done, press the Next button. You will now be at the main Windows Vista setup screen where you would normally instamy os is vista.yet when it boots i saw a massage - 3075514.jpg to a computer.
3075514.jpg As we want to repair the computer, you should click on the Repair your computer option. This will bring you to a new screen where the repair process will look for all Windows Vista installations on your computer. When done you will be presenmy os is vista.yet when it boots i saw a massage - 406fab5.jpge System Recovery Options dialog box as shown in Figure below.
406fab5.jpg Press the Next button to continue
The repair process will now display the System Recovery Options screen. If you get any other options, then click on Vimy os is vista.yet when it boots i saw a massage - 98dd287.jpg options for system recovery and support, to get to the System Recovery Options, as in the figure below :-
Click on the Startup Repair option.
The Startup Repair tool will attempt to fix your computer and get it booting up again.
710e668.jpg If Startup Repair finds a problem with an important operating system file, the tool may suggest a solution of some kind that you have to confirm or may solve the problem automatically.
Whatever happens, follow the promptsmy os is vista.yet when it boots i saw a massage - fff3abc.jpgry and accept any changes suggested by Startup Repair.
Important: Your computer may or may not restart several times during this repair process. Do NOT boot from the Windows Vista DVD on any restart.
fff3abc.jpg Click the Finish button once you see the Restart your computer to complete the repairs window to restart your PC and start Windows Vista normally.
The above steps most probably should resolve the issue with your computer.
Posted on Oct 01, 2010
Missing Boot INI File when starting a Dual Boot Machine , Win 7 64 bit and Win 10 64 Bit
Windows 10 is the default and will be looking for a EFI file that is probably not set up on your old hdd. Change the format of the old hdd to accommodate the new type of boot file.
Sep 29, 2015 | Computers & Internet
How can i fix missing os or unformatted active partition for lenovo y410?
Have you used this system before successfully?
If so it sounds like you might have a corrupt or missing boot or system file. You'll need a repair disk or system disk to fix it. You need to get to a dos prompt (black screen with white writing) and run the Check Disk command.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Mar 31, 2012 | Lenovo 3000 Y410 Notebook
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
File:\windows\system32\config\system file is missing or corrupt laptop : sony vaio
boot you computer using OS CD and at first screen use recovery console command prompt
at command prompt
wait for 10 second and the enter your administrator password
then go to c:\windows\system32\repair
the type copy system c:\windows\system32\config
press y to overright file
and restart your computer
Nov 23, 2010 | Computers & Internet
I have an acer aspire laptop with genuine vista os. i didnt operate for quit sometime and now, when i wanted to use it. it even didnt boot giving me a message. 'boot manager missing'. what is the problem...
If your Windows Vista computer has encountered the dreaded "BOOTMGR is missing" error, you aren't alone. If the problem isn't hardware related you can fix it with relative ease as long as you have a Windows Vista DVD handy.Boot off the Windows Vista DVD and then click Next at the first prompt:You should see a link in the lower left-hand side for "Repair your computer"The installation process will attempt to find your Vista installation directory. If there's more than one in the list, select the correct one and then use the Next button again.Click the first link for "Startup Repair".The installation process will repair the system, and then prompt for you to reboot.Alternatively you could have chosen the Command Prompt option instead, and use the following command to fix the boot options only:
bootrec /fixboot.
At this point you should be able to reboot your computer, remove the DVD and everything should be working.
Sep 19, 2010 | Acer Aspire 4730-4947 Notebook
My laptop wont voot to windows
Sounds like you have a corrupt ntldr.dll file. You will need to insert you windows disk and repair the dll file, here are links with detailed instructions,
This is for windows xp
http://pcsupport.about.com/od/operatingsystems/ss/instxprepair1.htm
This is for windows vista
http://pcsupport.about.com/od/toolsofthetrade/ss/windows-vista-startup-repair.htm
Jul 06, 2010 | Dell Inspiron 6400 Notebook
My windows launcher has stopped working
Try using System File Checker to scan your OS for missing/corrupt files, complete these steps:
Click Start, and then type cmd in the Start Search box.
In the results area, right-click cmd.exe, and then click Run as administrator. You will be prompted to type the password for an administrator account. Click Continue if you are the administrator or type the administrator password. Then, click Continue.
At the command prompt, type Sfc /scannow, and then press ENTER.
The scan may take some time, so be patient. Windows will repair any corrupted or missing files that it finds. If information from the installation CD is needed to repair the problem, you may be prompted to insert your Windows Vista CD.
Hope this helps you. Let us know either way. Make it a great day!
And Thanks.
Mar 10, 2010 | Microsoft Windows Vista Home Premium with...
Got acer aspire 5535 laptop it is comming up ''BootMGR missing press ctrl alt delete'' have tried this no success
image16.pngYou should see a link in the lower left-hand side for “Repair your computer”
image17.pngThe installation process will attempt to find your Vista installation directory. If there’s more than one in the list, select the correct one and then use the Next button again.
image18.pngClick the first link for “Startup Repair”
image19.pngThe installation process will repair the system, and then prompt for you to reboot.
image20.pngAlternatively you could have chosen the Command Prompt option instead, and use the following command to fix the boot options only:
bootrec /fixboot
image21.pngAt this point you should be able to reboot your computer, remove the DVD and everything should be working. If not, then head over to our forums and ask your question there. We’ve got some top-notch geeks over there!
Feb 16, 2010 | Acer Aspire 5500 5570-2609 Laptop
Microsoft Windows? Vista Home Premium Edition Upgrade Version for PC (1 Computers) (66I-00021) Logo
90 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
