Question about Brother XL-2600I
I am trying to use a twin needle, however, every time I begin sewing the machine makes a very unhappy sound as though the needle is being blocked as it tries to pick up the bobbin thread. I have tried with different types of thread, cleaned the machine, and adjusted the tension but no matter what I do my sewing machine makes an awful noise and all the tread is lose on the underside of the fabric. What should I do?
  • Brother Master
  • 7,365 Answers
Check to see if the twin needle are damaged
check the bobbin & make sure the bobbin case is thread correctly
needle & thread may not be compatable
here's how to check
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
Posted on Oct 01, 2010
Thread breaks on the 2340CV Brother. Doing two needle and the right needle is breaking at the needle. Change needle and retreaded several times
Probably depends what that needle is hitting that is causing it to break. Make sure the presser foot and the needle plate hole are large enough to accommodate the twin needle. Twin needles come in different widths so if yours is too wide, it would break. However, it could be possible that your machine is slightly out of alignment that does not show up until you try to use a twin needle. Also, make sure that your thread is not causing the needle to break--could be misthreading. Some machines have separate guides and tension disks for twin threads. Those that don't have that accommodation may have more difficulty using a twin needle.
Mar 07, 2017 | Sewing Machines
I inserted the twin needle and threaded it. However, I don't know what what stitch I should use.
we have no idea here either try someplace that gives sewing classes locally
Feb 16, 2017 | Sewing Machines
Universal twin needles break. cant find x57521-001 recommended
Perhaps your machine is slightly out of time so a single needle will work fine but a double needle will not.
Oct 10, 2015 | Sewing Machines
How to adjust placment of twin needle so it doesnt hit edge of bobbin holder?
The needle should not hit the bobbin holder at all. Do you have the needle inserted all the way? If it is too low, it will hit. If you are saying the needle is hitting the sides of the needle plate where the needle goes through, then the needle is too wide for the plate. Either use a narrower twin needle or see is a needle plate with a wider needle hole came with your machine. Some decorative stitches can't be used with a twin needle because the combination of width of stitches and width of needle is too wide. In that case, narrow the stitch width until the needle doesn't hit the needle plate or use a narrower twin needle. I hope I have helped and answered some of your questions. Good luck.
Apr 26, 2014 | PfaFF Sewing Machines
Do I use a twin needle with my narrow pintucking foot on my Elna quilter's Dream 2 sewing machine?
if you want to sew pin tucks, then yes, you could use that foot providing the hole is large enough for the two needles to pass through. Twin needles come in 4mm gap and 2.2mm gap so just check that it will fit. When using a twin needle, there is a lot of heat created so it is always important so sew slowly, going too fast will cause the needles to break.
Also, you should check on the twin needle type, modern machines now using a twin which is slightly offset, the block colour is usually a dark brown/red colour. Your machine may have come with a twin needle in the needle selection so take a good look at it and see if it is an offset one, then make sure you buy replacements of the same type.
THe pin tucking foot allows you to keep rows of pintucks lined up, it will have grooves in the base that you can run the previously stitched pintuck through to keep even distances. Best on lightweight fabrics like cottons, lawns, batiste etc. You'd probably go for the narrow 2.2mm twin needle to get a nice fine tuck. I like to press each seam after stitching too to give a sharp tuck.
Oct 20, 2011 | Elna Quilter's Dream 6003Q
I need to hem a t-shirt but not sure how...ie: type of stitch,length,needle et...do I need to zig zag first then finish off with a stretch stitch ? Thanks
The best way to hem around a garment where the seam is going to receive stretching during wearing is with a stretch twin (double) needle.
Pretty easy, just turn up an even hem of 15mm right around the hem line (I am assuming that the bottom edge is even, if not, trim it up first), and press this hem allowance up, pin if you have a jersey that won't stay flat but many cotton knits are fine and the pressing will be enough.
Then thread up your sewing machine for twin needle sewing, refer to your manual if you have never done this before. You will thread two spools of same colour thread up on top of the machine and bring both threads through all threading points down to your needle, then one through each needle eye. Some machines will have a tension device where you can run each thread on either side of a tension disc, most will have twin spools on top of the machine to hold both spools.
You need a stretch twin needle, Schmetz do these in two sizes,
Stretch Twin
Size:
2.5/75, 4.0/75
Twin needles look like this.
tally_girl_65.jpg I prefer the 2.5mm gap between the needles. Dont try with a regular twin, it must be stretch needle with ball point points. On some computerised machines, you need a twin needle with a blue bridge, on mechanical machines it will have a red bridge (something to do with horizonal hooks I think). But read your manual or look in your accessory box, your machine may have come with a twin needle and if so, make a note of the needle bridgecolour, then buy that one next time.
Now, set the machine for a straight stitch and place the garment right side up, with the folded hem allowance underneath on the sewing machine and align the folded edge on your 10mm marking. Start at a side seam, and stitch SLOWLY around the whole hem line until you get back to the starting point. Stop, cut your threads and press again. Voila done. I never bother to zigzag a knit fabric, just stitch it. Knits don't fray.
Aug 20, 2011 | Sewing Machines
Seams puckering
Several things to try to trouble shoot this:
But basics first, always press each seam, both sides, then open after sewing it. This beds in the stitches and gives a smooth finish. I always sew with my iron on beside me. Guide how is here http://sewing.about.com/od/beginner1/qt/press.htm
To adjust the seam tension try either loosening the top tension, or shortening the stitch length. 2.5 for normal weight fabrics but if you are sewing silk or chiffon you would shorten up to 2. Obviously don't make it too close though or its a major pain if you need to unpick a seam.
Best thing is to test sew and get top and bottom tension perfectly balanced first. There is a instructions on how to do this here.
http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
Then practice seam on your actual fabric firstly making sure you've got the appropriate sized needle in the machine, needle sizes info here http://sewing.about.com/od/sewingmachineindex/ig/Sewing-Machine-Needles/ . Always use a new needle for every new project or 4-6 sewing hours - its never worth scrimping on needles, I have about 30 packs in my sewing cabinet in every size, ball point, sharp, twins, wings and microteck types.
Then stitch, press, and evaluate. If you still feel the seam is pulling up, then you could try not backstitching the end of the seam and ease some out of it after stitching. Or loosen the top tension a little.
Always stitch a skirt seam from hem to waist so that all the seams are sewn in the same direction, this makes a difference too.
And if you are still really unhappy with the performance of your machine you could consider taking it for a service to get it into tip top condtion or look at purchasing a higher end machine, take your fabric sample into a dealer and ask for a demo and see what quality seam they can get from their machines. IMHO I believe that there is a difference in stitch quality between a $200 mechanical front loading bobbin machine and a higher end horizontal bobbin machine, just due to the mechanical tolerances and build quality between the two machines. Watch a show like Simply Quilts and you'll probably see a European made machine being used. Most experienced sewers will have a machine prefererence after shopping around and comparing the different makes and models out there.
Jul 19, 2011 | Brother LS-2125 Mechanical Sewing Machine
Skips a few stitches when using a double needle. I'm using a recently acquired old Pfaff Hobbymatic and have used a double needle before on a Singer. When I tried sewing, it will stitch but then skip a...
firstly are you using a regular twin needle on a knit fabric? this could cause skipped stitches.
is the twin needle quite old and possibly blunt?
Is the Hobbymatic a model that requires a slanted twin needle, there are two types of twin needles as the computerised machines need the offset style. You can distinguish between them by the plastic block on the needle shaft where the twin needle points are set, either red or a deep brown colour.
If none of the above apply, then it is possible that the timing sequence is slightly off so that one of the needle's thread is not getting caught during the stitching.
Timing is an adjustment that I leave to the technician to address. But if you want to have a go yourself there may be some videos on you-tube for your model and how to make this adjustment to it.
Jun 18, 2011 | PfaFF Sewing Machines
I have for gotten how to make the machine sew and im having trouble threading a bobbin for my moms machine elna 7000 i need a manual or a quick note to get started
YOu can down load a manual from here http://www.arizonaexpressionz.com/elna_instruction_manuals/Elna7000.pdf
Just remember to click the bobbin thread into the tension device correctly and hold the two threads behind the pressure foot when you start each seam - Elna top loading bobbins give great stitch quality but you just need to keep stray threads out or they'll jam up.
Also, you must use the Elna plastic bobbin that the manual specifies for this machine - the 5000, 7000 and 9000 were Elna Tavaro Switzerland's first foray into computerised machines and first released in 1986.
Also, please check the manual when you go to buy twin needles, there are two types now as computerised machines usually need the twin needles offset from the shaft position. They have red or black plastic block between the shaft and the twin needles - I think you need the red ones but just double check the manual to make sure. And you can't do all the wide stitches with a twin needle as it will strike the foot.
Hope this helps a little.
Jan 16, 2011 | Elna 2007 Mechanical Sewing Machine
Can I use a twin needle on my Janome MW3018? Doesn't mention it in my instruction manual and I don't know how to thread the machine for twin needle sewing.
Twin needles can be used on any machine. Just make sure you use the correct presser foot......one that allows both needles to work without hitting the foot. Also.........you cannot zig-zag or use any other fancy stitch with a twin needle.......it is strictly for straight sewing. You have to use 2 spools of thread .....thread your machine with both threads as if they were one thread but separate the threads when you get to the needle. There is no change to the bobbin. Happy sewing. I can't be bothered to go to all this trouble so I just sew 2 rows to get the same look. Ofcourse you have to be very good at sewing perfectly straight seams doing it this way. Try both methods on a scrap and see which method you prefer.
Dec 21, 2010 | Janome Sewing Machines
Brother XL-2600I Logo
113 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
