Question about AMD Athlon 64 X2 5200+, 2.6 GHz
No driver for onboard modem - AMD Athlon 64 X2 5200+, 2.6 GHz
Install window 7 but sound is not coming in it
Hi you could get some sound drivers from here
www.realtek.com
go up to downloads then choose either the AC.97 audio or the HD audio driver either should work
download it
install it
then restart the laptop
if you need to use your onboard mic if you have one then you may need to get a conexant modem driver
for that you may get it from
www.conexant.com
or better still
go to the manufacturer of your laptop's official website to find the modem driver
or repost back to us below where it says add a comment telling us the make and model of your laptop and someone may be able to find the driver for you
many thanks
Jun 23, 2011 | Computers & Internet
Dell Dimension 4550, OS = WINXPPRO. Just reformatted and reload OS. Got and installed drivers from Dell.com. System sees onboard ehternet but says no driver for a PCI communications device. Cannot...
Dell Dimension 4550 Drivers
From the above link you can download the required drivers. There are two drivers available for Broadcom and Intel. I suggested try the Intel Drivers (as your system may be having the Intel based Ethernet)
To PCI communication Controller (Modem) you have to install the Modem Drivers
Trt Eicon (recommended) Or broadcom conaxant etc
Hope it helps! Good Luck!
CreativeTECH
May 10, 2011 | Dell Dimension 4550 PC Desktop
Necesito el drivers de sonido modem device on high definition audio bus gracias.
Hi
www.toshiba.com
go to netbooks support/downloads use search options to find your make model and os
then scroll down to find the modem audio driver probably ( Conaxent ) this is probably what
you need for the onboard mic to work
good luck
Mar 13, 2011 | Toshiba Satellite P105-S6104 Notebook
Regarding Sm bus Controller
You need to download & install some motherboard-specific device-drivers, probably for USB ports, or an onboard modem.
Find the web-site for the manufacturer of the motherboard.
Search, using the model-number of the motherboard,
to find downloadable device-drivers.
Nov 17, 2009 | Computers & Internet
Speedstream 6520 driver
Windows doesn't detect Ethernet connected devices. You could hook up a dozen Ethernet Modems and Windows would not see any of them, but they all would work fine using TCP/IP. It is not like you installed the DSL Modem/Router inside the case of the PC. You do know how Ethernet works, right? The only driver needed is the correct one for your Ethernet card, but that comes the Ethernet Card or the Motherboard Drivers CD for onboard Ethernet.
Found a few things, here are some websites to try:
Troubleshooting: Here
USB Driver for your Speedstream: Here
Sep 25, 2009 | Computers & Internet
I can't install PCI modem
download the updated onboard audio and chipset drivers from the site below
http://www.foxconnchannel.com/support/downloads.aspx
Thanks for using Fixya
proton
Aug 15, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Mothterboard
Most likely in these situations it is a driver problem.  First things first, make sure your BIOS is up to date.  If not, follow this link to update your BIOS:
http://www.opendrivers.com/searchopendrivers/M963GV.html
After the update, enter your bios and make sure your onboard modem is enabled.  This could be another problem - the modem MUST be enabled in BIOS in order to work.
Additionally, there are drivers available for your specific motherboard model - go to the following site:
http://www.xpvistasite.com/m963gv_v5.0_19473.htm
These are windows drivers for your motherboard - they work across nearly all windows platforms.
If you do all of those steps, and it still doesn't work, let me know!
May 26, 2009 | PC Chips M963GV (V3.3A) Motherboard
Deleted browser driver for dell dem. 4600 desk to windows xp home
Assuming that you deleted the ethernet driver.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid
if you placed any other modem in the system, then tell the modem name. or else it is an onboard ethernet. you can driver from the above location
Apr 21, 2009 | Dell Dimension 4600 PC Desktop
My computer dont act right,something is wrong with it but i dont know what
is your videocard onboard?? if its is, well theres something wrong with your motherboard especially on the video side, but if its not onboard, well try to check your videocard (its driver).
a general cleaning of your pc will do, and try to use an eraser to clean the pins of the videocard.
also check your monitor, if you have a spare pc, try to use that monitor and check if its ok.
as for your ethernet cable modem, try to check if your modem works properly (like power). and install the proper drivers for the modem.
Mar 12, 2008 | Computers & Internet
AMD Athlon  64 X2 5200+, 2.6 GHz Logo
26 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
