Question about HP L1702 17" LCD Monitor
I have this blinking problem that makes me unable to surf. i have reseted my graphic card and switched monitor. both do not work. help me pls
  • 11,361 Answers
Flickering screen/ Look for bad caps just like the rest of failed monitors, please read on if you are going to DIY repair.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 01, 2010
Graphics dnt work tried everthing in compatibility doesnt work pls help
The problem is usually that the monitor has the wrong input selected.
If you are using VGA (The 15 pin connector, maker sure VGA or AUTO is selected in the monitor setup.
IF you are using a DVI cable, (18 pins also called a single link cable ) make sure DVI or AUTO is selected.
Many monitors will not work with a 24 pin DVI cable. (Also called a double link cable.)
The main reason is because they are not able to reach the resolutions of double link, or the graphics card is using the center 6 pins of the double link DVI cable for some other usage, which is a bad idea.
Sep 01, 2015 | Graphics Computers & Internet
Screen white and power button blinking
Try another monitor if it works ok then the other monitor needs replaceing if it still does the same then you need replace the graphics card.
Terry
Apr 02, 2014 | Sony SDM-HS75P/S 17" LCD Monitor
My lcd monitor is samsung 740n. 17inches. When i start my computer,the CPU is on,Fan is running, Hardisk is working and CPU lights are blinking, the initial intel logo and windows loading logo is ...
First thing I would try this monitor with another PC first since the problem can be in some where else in the PC also. Do you get video if you boot up in safe mode? Did you load any new sofetware, drivers?
If it is monitor problem, then you should read below so you will know what to look inside.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 02, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
G foce 8400 graphics card does't work , if i connect the monitor in my graphics card monitor only monitor let blinking but graphics card fan run what can i do..? pls help me..
Actually this is happen when your card is gone. But this may happen according to RAM problems. So be sure your RAM is in good condition.
Think this is helpful !
Aug 11, 2010 | ASUS P5GZ-MX Motherboard
My Asus EN7200 GS stoped working, lines appeared in my monitor
you must be reset your bios put on jumper coms clear choice 2-3 then reset configure position again 1-2 then computer is ready activate built in agp
Thanks
Nov 22, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
My monitor is almost black, i can faintly see what is on the screen it doesn't help if I try and change the brightness of the monitor
There are a problem with VGA (Graphics port) in CPU .Pls check your CPU on another Monitor or vice versa.Pls call vendor for repair the Motherboard if Graphics card inbuint on the Mother otherwise get it replaced the Graphics Card.
Nov 18, 2009 | Samsung SyncMaster 152N 15" LCD Monitor
Graphic problems
first problem
ur monitor start blink bcoz the graphic cards does not support ur game i.e call of duty world
Do this steps
first remove ur card clean with soft cloth & insert in ti slot than afterwards reinstall the game than also the monitor blinks than the same case as above i have mentioned
second problem
reinstall the crack of chronicle
or update the registration of the game
if problem occurs than the game has not been installed properly
Dec 04, 2008 | XFX GeForce 6200 Graphic Card
After 15 -20 min my monitor goes blank
This could indicate a problem with the graphics card. Take the card out and clean it, then clean the slot that it fits into. (I normally use a small dry paintbrush).
Replace the card, making sure that you push it down gently but firmly and ensure that the plastic clip has gone back correctly that hold the card in place. Rescrew the card back to the casing correctly and reboot.
Hopefully this will resolve your problem. If it does not, to determine whether or not your graphics card is faulty. Change the monitor lead over to the onboard graphics port instead of the agp/pci port and reboot. If the monitor works properly with no problems, then you have a bad graphics card.
I hope this helps.
Nov 13, 2008 | Intel Motherboard
New monitor but unable to use its maximum resolution settings
no, there's nothing wrong with either your graphics card & monitor.. it just that your graphics card does not support a 1680x1050 resolution. if you want to fully enjoy the resolution of your monitor, you should upgrade your graphics card. purchase at least 256mb graphics card and you will see the difference..
Jan 21, 2008 | Gateway FPD2275W LCD Monitor
HP L1702 17" LCD Monitor Logo
158 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
