Sony Playstation 3 (PS3) Console Logo
Posted on Oct 01, 2010
When turn back swith solid red light comes on cant eject game or press on button in front. (nothing happens) The only way it works is by putting a disc in at this time.So before i turn it off I eject game by pressing playsation button then when on icon of game press triangle the game will eject. However last time my girlfriend turned console off now game is stuck inside don't know what to do. When this happened previously I would have to turn back switch off and on and sooner or later when I turn back on and press front power button the system would work. Not this time game stuck inside and I have turned off a million times and can't get to work. If anyone understands my problem and can help or has any idea what is wrong or any idea what i can do to get to work please drop a line. Thank you
Anonymous
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Oct 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
32
Questions
0
Helped
6108
Points
54
There are many reasons cause PS3 disc stuck and console won't turn on. Your PS3 hardware need some kind of fixes. Send back to Sony is expensive. You better repair by yourself. I suggest you bought this guide, you can learn how to trouble shooting and disassembly your console and fix it at last. Good luck!
Wii has solid red light, won't turn on, faint ticking noise
if it was dropped check the bluetooth module , they can come unplugged and the wii will not function. Children love to put change in the wii which can short it out. Never bridge a fuse as it can cause unsafe conditions and potentially a fire hazard .
I can't turn on the Wii. The red light is always on and when I press the power button (or even the eject button) the blue light is flashing (Only when I press those buttons). I tried the solution of...
Try pressing the power button down and holding it for a few seconds and see if your WII comes back to life. When I first got my Wii I would hold down the button just long enough for it to turn green. This seems like a standby mode. To get my Wii to turn off completly I needed to hold down
the button until it turned red and when restarting the WII I held doen the button until the Wii started back up.
4helpful
My ps3 shut down in the middle of game play. Then when I tried turning it pack on, this is what happens... The power light flashes until I touch the power button, then it goes solid red. That means it's...
It seems that your unit may have overheated while you were playing that game, that yellow like you are talking about is the 360's Red Ring of Death. Try this, eject the HDD and let it cool off for about 24 hours. Don't put it in the refrigerator or anything, just let it cool off. Tomorrow, pop it back in and make sure there's nothing covering the air vents. Dust, Paper, a Blu-Ray Player, Home Theater Box, a Wii, a 360, anything.
If it's still doing it tomorrow, call SCEA (1-800-345-7669)
The game cd cannot be ejected from the PS3. When the eject button is pressed the red light keeps blinking.
Try the following solution.
Turn the PS3 off with the main switch on the back.
Turn the PS3 back on into standby (red light on)
While holding the eject button press the power button on the front of the PS3. This should initialize a forced disc eject.
Hope this helps and thank you for using FixYa
Red light flashes when turned on, cant even eject disc
Try to do these 3 things.1 - Restart your console.
2 - Take out all cables, and plug them back in.
3 - Take out the hard-drive, and place it back in your PS3 console.
Try this to take the disc out:
1. turn the PS3 off from the back
2. Put a finger on eject button
3. then turn PS3 on from back with finger still on eject button
4. disk should come out
1helpful
2answers
Ps3 wont turn on using controller and power button...
try cycling the power on the back of the console
are the lights blinking on your controller when you press them?
1helpful
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
1helpful
Won't power on or eject game. solid red light on-won't do anything else
Hmm. I'm not quite sure exactly what the problem is, but if your playstation doesn't turn at all when you flip the back switch it means your harddrive is probably fried.
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Playstation 2 power button
Try pushing the eject button to see if the power button is faulty. If the PS2 is off and you press the eject button, it automatically turns the PS2 on and ejects the DVD tray.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
