Question about Jenn-Air JGR8850 Gas Kitchen Range
Oven was off...woke up to oven beeping and the F9 code came up & door is now locked. What is F9??
  • Jenn-Air Master
  • 1,711 Answers
This waht F9 mean
F9 Door latch Check door latch components.
You will need to replace door latch
Posted on Oct 02, 2010
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
Jennair oven 8114 p472-60 or p458-60 f9 error code
The F9 error code for this model number Jenn-air range indicates a door lock issue. The control sees it as locked, unlocked, or both at the same time.
The technical manual instructs us to check the wiring to and from the door lock mechanism and if no issues are found replace the motorized door lock.
Mar 24, 2014 | Kitchen Ranges
F9 whirpool range
I had a power fail & when the power came back on I had the F9 error code on my range with a beep beeping that would not stop until I pressed cancel, beeping stop however F9 error code stayed on, I solved the problem by turning off the power, then turning power on again and then I pressed start button and it removed the F9 error code and all is working GREAT now...
whzurdaddy...
Feb 26, 2012 | Whirlpool Kitchen Ranges
Request Onwers Manual/Troubleshooting Guide: [FEF366CCE]. PROBLEM: Oven locked in code [F9] & [F1] w/ the the [Door Locked] LED flashing w/ beep. Stop top functional, oven inop.
Here is the Owners Manual for your model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257123en.pdf
Here are all of the error codes and solutions for Frigidaire ranges: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Frigidaire Range / Stove / Oven Fault Codes#ixzz1Dxy4q2ze
Feb 14, 2011 | Frigidaire FEF366 Electric Kitchen Range
Code f9 on frigidaire self cleaning oven. what does it mean. i went to clean the oven and the door locked and the code f9 came up and keeps beeping. i unplugged the stove for 1/2 hour and plugged it...
Hi
Thanks for using FixYa. F9 error in your oven/range indicates an issue with the door locks assembly and/or the door latch. To start with check the door lock circuit, you can also try to jump start it to see if it's working. If it's not working then the Electronic Range control has gone bad and should be replaced, if it is working then the door lock circuit should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 15, 2010 | Frigidaire Ovens
F9 is appearing in the clock window
HI. This will code is indicating that the oven door lock mechanism is experiencing difficulties. Check the wiring to door lock switch (the wire harness may be connected wrong, or loose). Check for stuck lock switch, as well.If the wiring is not loose, or connected improperly, this will lead to a failed door lock mech. it will require you, ro your service tech to replace it, in this case.
F-9 Oven door lock failure
Dec 07, 2009 | Whirlpool Ovens
Door locks and F9 fault codes
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 24, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Jan 22, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Frigidaire Range FEF357BBD error code F9
I had the situation where the oven thinks the door is locked but it was not locked. Setting and holding clear eventually gave a f9 error.
I solved this by turning the circuit breaker off and taping over the oven light switch ( so it thinks it really is locked ) and turning on the breaker. The oven unlocked and appears fine now.
Nov 09, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Jenn-Air JGR8850 Gas Kitchen Range Logo
706 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
