Question about GE Refrigerators
PSS26MSWA SS - GE Fridge: water dispenser not working
Bought floor model, which was plugged in at store. I brought it home and started using it without connecting water line. Two weeks later, I installed water line. I am getting water at the filter but still not getting water to dispense. I then read in manual that if water line is not connected, ice maker power button must be in off position or valve may become damaged. I tried removing the filter and installing the bypass lid. Still did not work. Any suggestions?
    Problem Solver:
  • 14 Answers
This is a common problem with GE refrigerators. The water line freezes. It is a cheap and easy ($30) fix that takes about 15 minutes. I found a ton of people having this issue so I did a blog post with the symptoms and part to order. Read more about it here.
Posted on Dec 13, 2010
We took our new filter out and back in a couple of times, then it final started working. We are not sure why, but it worked! Good luck with yours.
Posted on Jun 24, 2009
  • 1,314 Answers
Try holding the water disp for 5-8 mins to fill the water tank
Posted on May 26, 2008
Why is my GE (ZFSB23D SS) side by side refrigerator leaking at the back corner, near the rear wheel where the plastic water line goes in?
If the tubing is plastic it could have cracked when you moved the tubing to install the filter. If the tubing is OK then possinly the filter isn't all the way in or is leaking.
Jul 31, 2014 | Refrigerators
Low water pressure from my GE water dispenser
This is a link to a photo breakdown of the back of your refrigerator=> HERE Location 800 in that photo is the WR57X10070 Water Inlet Valve The problem you are having is possibly the=> WR57X10070 Dual Water Control Valve is not opening completely. I am adding a video so watch the video and I believe it will make this easier to understand what is happening. I am here should you have questions Thanks Sea Breeze
May 02, 2013 | GE Profile PSW26P Stainless Steel Side by...
A magnitude of problems could be caused by this, you should really call someone to come out and look at the refrigerator. With that model having a ice maker and water dispenser, it could be a crack in the water filtration which is typically located in the lower read of the refrigerator. If nothing else seems to be wet on the inside of the refrigerator you can almost guarantee that its the filter and pump in the back leaking which will require a skilled professional to look at it.
Dec 08, 2011 | GE Refrigerators
Hi, I have an a GE Profile Model TPX24PPDCC fridge that came with the home I purchased in 2006. I believe the fridge is much older. I've been having problems with the water dispenser where water will...
Yes there is a way to disconnect the water line. Pull the Fridge out from the wall. The electrical power chord should be on the back side as well as the 1/4" water line. You need to locate a valve and shut off the supply water. Then you can disconnect the line with wrenches. It is located near the bottom.
Apr 01, 2017 | GE Refrigerators
GE Profile PFSS5NJWA SS water dispenser not dispensing water. I tried changing the filter, but it still does not work. I also tried pressing the "reset filter" button. When I press the water...
We have the same model and just had exactly the same problem. The coil behind the fresh produce trays is frozen. There are 2 coils, one provides water for the water dispenser and the other to the ice maker. Looking into the fridge the water dispenser coil is on the right hand side. We unplugged the fridge for a couple of hours and the problem has been solved. Try increasing the temperature of your fridge by a degree or two.
Feb 17, 2011 | General Electric PFSS5NJXSS Stainless...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
In my GE Performance refrigerator side-by-side Ice is being made, but no water is dispensing. The GE Smartfilter is atleast 5 yrs old (I never used/never changed) because we always bought water from...
The water that goes to the door actually is routed through the hinge on the freezer door. Take a look and see if you can't find where the tube comes out and goes into the water dispenser. I bet it has come loose and is rerouting the water down the side of the fridge and onto the floor; hence the puddle.
Also, just because you don't drink the water doesn't mean you don't drink the water! If you use ice from the ice dispenser then you ARE drinking the water. The water that feeds the ice trays comes through the filter, so you might consider changing it every 6 months rather you use the water dispenser or not.
Hope this helps, I have one too and its causing a different set of problems...
May 11, 2009 | GE Profile Performance 25.2 cu. ft....
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE PSC23SGRC SS refrigerator (Arctica) Profile
Main board is out. Replace. Located on rear of unit
Jul 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
688 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
