Question about Samsung CLX-3170FN All-In-One Laser Printer
Samsung 3170 I have a paper jam or scan door open, but I cannot find any paper anywhere or an open door. The blue line for wireless status is blue and red - And I do not have a manual for this printer.
5 Suggested Answers
mickblu
  • 12 Answers
SOURCE: Clear Paper Jam error -- but there is no paper jam!
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very throroughly eyeball the paper path for any "foreign" objects...
Posted on May 31, 2007
SOURCE: Re: paper jam in brother laser printer hl 2040 : paper red ligh continue to flash
Besides your helpful
there are extra doing steps to make my printer back to normal:
- Remove completely the unit toner cartridge, check paper jammed in that unit
- open the basck lid of the printer , remove all paper jammed in that arrea
- Blow out the container inside of the printer, to blow away all paper depris and dust.
- re-install unnit toner, close back lid\re-strat printer like your suggestion
Many thanks
Have a Nice Day
FP
714-715-6412
Posted on Feb 13, 2008
SOURCE: Samsung CLP-300 Printer has red light on, won't print, don't see any paper jam
  1. Close all the covers.
  2. Check in the paper tray for paper.
  3. Check for the toner cartridge.
  4. Remove paper tray, toner cartridge and open the back cover for any paper jam.
  5. Please make sure that only supported paper type and size is loaded.
  6. If printer prints after opening and closing the door, try to load different type of paper.
  7. Disconnect the pritner from the computer, and restart the printer.
  8. If Red Light lits up right away, there's a possible paper sensor problem.
  9. If you see a Green Light, press and hold down "Cancel" button for 4 seconds and then let it go.
  10. If it prints the demo page fine, connect the printer cable to a different port or replace the printer cable.
  11. If it goes back to Red Light, pick-up roller inside the printer is defective.
Posted on Aug 23, 2008
  • 2386 Answers
SOURCE: my samsung clx 3170 keeps jamming up after every
Use this link and you will have all the information on your printer you should ever need
http://www.samsung.com/au/consumer/print-solutions/print-multifunctions-copiers/colour-multifunction/CLX-3170FN/XSA/index.idx?pagetype=prd_detail&tab=support
good luck
Posted on Nov 29, 2010
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
On a clx-6200 message says "paper jam 0-c=open/close door. what door is this?
It is telling you that there is a paper jam. Open the door, pull the jammed paper out, close the door, it should clear the message.
Apr 21, 2012 | Samsung CLX 3160fn All-In-One Printer
My samsung clx 3170 keeps jamming up after every copy. You can see where the paper is trying to roll thru. because there is a slight indentation in the paper about a third of the way on each piece of...
good luck
Nov 29, 2010 | Samsung CLX-3170FN All-In-One Laser...
Printer says "scan unit open or paper jam 2" Hav...
Dear
The printer paper jam-2 cover may be opened or not locked properly.
This door is at back side of the printer.
Thanks.
May 21, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I have a paperjam on my colour laser printer CLX 3170 and I dont know how to get to the paperjam inside the machine
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I can'r find the paper jam in the printer. screen
If not picking up the paper then it the Pick-up Roller just above where the paper tray is. Remove the paper Tray and Tip Printer back so you can see under the Printer. Take some rubbing alcohol and clean off the rubber roller
Service Manual found here Free...
http://hotfile.com/dl/28988134/55113fe/CLX-3170-3175.zip.html
Feb 09, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
PRINTER SAYS PAPER JAM 23 ..
thanks J
Jan 11, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung CLX-3170FN All-In-One Laser Printer Logo
345 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
