Question about ViewSonic E50C 15" CRT Monitor
My viewsonic E50c monitor does not have vertical scanning in the upper part of the tube . Lower part is o.k can you help me to fix this.
5 Suggested Answers
SOURCE: Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Posted on Jul 30, 2007
budmrtn
  • 11361 Answers
SOURCE: 3 shaded vertical bars on monitor about 3 inches
That the sign of failed T-CON board on the LCD panel, new panel will be needed. It will get worst with more lines appear.
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 25, 2010
nileshsingh2
  • 246 Answers
SOURCE: instructions on how to disassemble and fix a Viewsonic VX2235WM
Picture tube is not major problem. It is the main board, having damaged capacitors, could be more then 1. Other components to look at is, high voltage tranisitor, which gives up in most cases. Most cases in my career, i found that monitor tubes are good, unless the are dropped. So resolder the main board and check out for the components i mentioned. Careful while repairing, it has high voltage, take all precaution while openining the panel. Unsrew all the screwsat the back, also the stand, take a flat screw driver and lever the panel from one end till you open all the 4 sides. Thanks, and don't giveup.
Posted on May 19, 2010
i_goutam
SOURCE: Hi all, I got a 19" Viewsonic monitor VG1921wm ..
Dude Press ******* the lcd screen in the opposite side of the black shade or press hard using thumb in the corners of the lcd sure it will be FIXED i solved mine it may help you too
Posted on Sep 09, 2011
White colour displaying as blue, and red colour displaying as black
It's simple i had the same problem the solution is u go to the settings menu in the monitor and reset the options and settings.
Sep 29, 2010 | ViewSonic E50C 15" CRT Monitor
The brightness/contrast window pop up randomly and frequently. Brightness level keep on increasing automatically. Pls help.
A 15-inch CRT monitor? It's time to responsibly recycle it, and buy a 17-inch LCD monitor, because _nobody_ fixes CRT monitors any more.
Jul 03, 2010 | ViewSonic E50C 15" CRT Monitor
No display on monitor when powered,Light is on.
change caps 1000mf-10v to 1000mf-25v in power supply and 470mf-10v to 470mf-25 or 16v.
May 12, 2010 | ViewSonic E50C 15" CRT Monitor
The monitor says it is out of range. What does this mean
This means that the computer is sending scan frequencies, horizontal and vertical, that the monitor can not process. Try using a lower resolution setting, ie 1024x768 or 800x600 and see if the problem goes away. Use your video card properties to change this setting.
May 06, 2010 | ViewSonic VX910 19" LCD Monitor
I am getting a vertical white line on my monitor> pl help me in
The CRT tube in your monitor is damaged. The best way to fix this is to replace the monitor.
Apr 04, 2009 | ViewSonic A90f+ 19" CRT Monitor
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Aug 25, 2006 | ViewSonic E50C 15" CRT Monitor
ViewSonic E50C 15" CRT Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
