SOURCE: kenwood kdc 1016 wiring problems
Hi
For a Kenwood KDC1016, the below listed wiring and color coding is followed:
Yellow - Battery B+12 terminal
Red - Accessory/Ignition B+12
Black - Chassis/Ground
Blue - Power Antenna
Blue-White - External Amplifier trigger
White - Front Left +
White/Black - Front Left -
Gray - Front Right +
Gray/Black - Front Right -
Green - Rear Left +
Green/Black - Rear Left -
Violet - Rear Right +
Violet/Black - Rear Right -
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
SOURCE: need wiring diagram for kenwood
Hi Carol
Everything you need to know about the wiring and installation of your unit can be found from Kenwood here.
I am more than happy to answer
any other questions you may have about it, just give me a hoy :) If you
still have problems, before you give a rating for this advice, please
get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you
as sound, a FixYa rating is a great reward for my efforts to help
you. Cheers.
regards
robotek
SOURCE: i forgot my code for
Hey there soliddragon,
You're in luck!
Click here,it will bring to a Tip page authored by one of our best technicians(Robotek). He outlines the procedure for clearing the code on mostKenwood models.
If this gets you going, don't forget to give Robotek a FixYa rating Remember: Good things come to those who Rate!!
Mike
if you get yourself a wiring harnest you wont need the diagram
SOURCE: Wiring for a kenwood kdc 1020 cd player
if you have the wire connector it's easy.....give the negative conection to the body of the player..find the wire from the battery with has the power supply even when the switch is off..and connect it to the yellow wire.that is for the memory...find the wire which has the power when the switch is on ,and connect it to the red wire from the player....what i mean by switch is the ignition switch... u can easily find the speaker connections...most speaker wires comes as blue,ash,green,white...there are two wires from each colour......
