Question about Dell OptiPlex GX520 PC Desktop
Orange light incdutors on mother board, change power supply same problem
  • Dell Master
  • 1,183 Answers
Since you have told that , that you have tried replacing the power supply and still the problem is the same. The problem could be with the motherboard. Disconnect all the cables and cards from the motherboard. Except the processor and power supply and the front power button switch and then try to power on the system. Use the following link to check the beep codes that the computer gives . To ascertain the faulty component.
Diagnostic Tools
Thanks Using Fixya
Proton
Posted on Oct 01, 2010
How can i fix my mother board if on switching on it shows orange
Hey i had the same problem there is a short somewhere in your power supply i would recommend replacing it
Apr 05, 2013 | Computers & Internet
5 bleeps on a conpaq
it say that you have a critical failure it can be power supply ; CPU ; memory or motherboard
to test your power supply:
1 unplug it from motherboard
2 on the ATX conetcor (P1 with 20 or 24 pin) use a wire to link green with a black wire
3 with a voltmeter verify that yellow have 12V ; red and purple 5V and orange 3.3V (nearly)
for the CPU and memory modules you can change it and test(only 1 memory module is enouth) or test it on an other mother board (must be compatible)
and for the mother board test on an othr hardware that work (if previous test was passed it's the mother board)
Oct 27, 2012 | HP Compaq dc7100 Ultra-slim PC Desktop
What does the blinking orange light mean on my dell CPU, I can't get it to power up
dell only knows 2 colors blue and orange... if you have no light on the mother board when power is plugged in. then your power supply is probably gone. considering you didn't mention beeps I would say thats it.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 16, 2011 | Dell OptiPlex GX270 PC Desktop
Just install a new power supply because the first blow out. mointor lite up but stay on orange light what can be the problem
Make sure all of the ram cards are in properly make sure that all power cords are plugged in correctly and make sure that no other wires where disturbed when you installed the power supply also make sure that the mother board is not the problem because sometimes when a power supply goes out it can burn up the mother board
Jan 15, 2011 | Computers & Internet
I have a compac presario, plugged and still no
usually ether pwr supply or mother board. i have seen older Compaq's having bad mother boards. check pwr light on front of pc case. if orange it is mother board, if off pwr suply.
Dec 13, 2009 | Computers & Internet
Orange power light blinking but will not power up, any advice
If ur orange power light is bllinking and device is not being powerd on than you can try it by replacing ram of laptop or boot system after removing bettry, of change the cmos bettry, if problem is not solved than there is a problem with ur mother board thry this it will help u out.
Aug 25, 2009 | Computers & Internet
I have a emachine PC. PowerSupply blew up. changed it still down
Dear,
ELECTRIC SHOK OR IMPROPER EARTHING IS DAMAGE POWER SUPPLY,MOTHERBOARD,PROCESSOR,RAM
HOW TO CHECK IT.
(WHEN CHECKING KEEP CAUTION :- REMOVE HARD DISK DRIVE POWER SUPPLY SOCKET)
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Aug 04, 2008 | Dell OptiPlex GX520 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
206 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
