Question about Fine Digital FineDrive 350 GPS Receiver
PLEASE INSERT THE SYSTEM SD CARD TO CONTINUE
Although, the performance on this GPS was slow it was all the same functional and then all of a sudden I am receiving the following message: PLEASE INSERT THE SYSTEM SD CARD TO CONTINUE, even though the card is in. I cannot access the navigation part at all. I thought perhaps the SD card was corrupted so I purchased another one and reinstalled the maps, but I still received the same message. Everything else on the menu seems to function, i.e. tools, pics, etc. Can you help me? I am ready to throw it out.
  • 2 more comments
  • Anonymous Jun 11, 2008
    ALL IT SAYS ISINSERT SD CARD
  • Raffaela Jun 14, 2008
    I believe i"v done that already, I do have a DVD with pre-installed maps and i downloaded them onto the existing card but still received message, then i bought a new sd card but still same problem. what do you suggest i do.
    i thank you for your input.
  • Raffaela Jul 01, 2008
    Hi
    Thank you for your suggestions. I have been away for the past 3 weeks and unable to attend to this problem. I will try sending you a copy of the map dvd and we'll take it from there.
    thanks for your time and offer.
  • ctguy20 Aug 27, 2008
    my fine drive 350 comes uo with insert system sd card when i hit navigation button. what can i do to fix it?
Well that stinks I had a brite blank screen and I opened it up and fixxed it but not for everyone to fix I need the dvd or card do you have the dvd as you may need to install the system software on the cards also
Posted on Jun 08, 2008
  • neededwares Jun 14, 2008
    hi,
    lets do this can you copy the map dvd and send jt to me I'l load it into mine and see if it works. that will define the problem
  • neededwares Jul 01, 2008
    hi my email is lappuaz@optonline.net and I will send you the mailing address as mot to post it
How to calibrate Vtech Storio?
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
•Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover Program Card' then click 'Next'
•From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
•The application will now format the SD card with the Storio factory default operating system
•When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
•Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
Feb 15, 2012 | Vtech V.Reader Interactive Reading System
My uniden trax 5000 gps says insert sd card, i dont know what to do
I have a UNIDEN TRAX5000 it has all of a sudden started coming up with a message "Please Insert SD Card" we have never had a SD Card in our GPS before and it worked perfecly... Pleas HELP!!!
Jun 06, 2011 | GPS
I have a Navigon 2100Max 4.3" GPS. When it turns on freeze at the Navigon screen. I tried to reset it won't work. Their website is no help. Please help.
Please remove the battery for a minute or so. If the problem still persists then have the firmware reinstalled as it has got corrupted.
Dec 14, 2010 | GPS
I`d like to use the mp3 on my GPS but don`t know how to put music or pics on
You need a standard SD digital memory card (not the newer HC high capacity cards as Magellan does not guarantee compatibility although I did get one to work that was a micro SD card with the full SD adapter). You will need to put your mp3 music files from your PC onto the SD card just as you would your mp3 player; insert the SD card into an SD slot on your computer, laptop or USB adapter and copy the files to the card. After files are saved, put the card into the slot on the right side of the Maestro and then refer to the User Manual (http://www.magellangps.com/support/product.asp) page 64 to see how to play the music. You can play through radio speakers or by using headphones/ear buds with a USB connector.
Oct 11, 2009 | Magellan Maestro 4350 GPS Receiver
I have a Nokia 500 gps system. The sd card with
Try to fix the sd card with some recovery software (recuva or similar) and transfer the data to a new card. If you have the installation disk, use that to copy the data to a new card. Do not use the corrupted card, since you might lock up the device for good.
Jul 14, 2009 | GPS
How to add music and video files to the sanyo nvm-4370 gps system
Option 1 (Internal Memory):
  • Connect the GPS to your computer with a supplied USB cable
  • For Windows, go to My Computer and find the connected drive (Removable Disk), when you open this disk you should see MobileNavigator folder
  • From the root of this drive, you can create 3 folders: Photos, Music, Videos and copy your media files respectively
  • Safely Remove Hardware the connected unit and unplug
  • Select your player/viewer (Photos, Music, Videos)
  • By default the internal memory (a can shape icon) is selected
  • Now enjoy your media
Option 2 (SD Card):
  • Assume your computer has a SD card reader
  • Insert the SD card to your computer
  • Insert the card to the Sanyo GPS
  • Tab the internal memory option (a can shape) to change to SD card option (sd card shape) to access files on SD card
Feb 26, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Loss of Somes States and Cities
You can perform a master reset to get it functioning again. Just following these steps:
  1. With the device powered off press the 'Bottom Right' hand corner of the 'Touchscreen'
  2. While pressing down on the screen power the unit ON and continue pressing the screen until a message says 'Do You Really Want To Erase All User Data'.
  3. Tap 'Yes' and go through the set up again.
  4. Please allow the unit sit standing still outside for 15-45 minutes
  5. Allow the unit to acquire satellites before searching again
Dec 29, 2008 | Garmin StreetPilot C330 GPS Receiver
Can't detect SD card
Try removeing your sd card. start your tt and after it has booted then insert the sd card.
Hope this helps
Nov 21, 2008 | Tomtom ONE GPS Receiver
Garmin Streetpilot i3 GPS cannot load map to memory card
A way around this is to insert the SD Card into the computer (SD Card reader), point the directory to the card and install the maps like that. I had to do that the first time I bought my unit because I couldn't figure it out and got frustrated. So I thought of this easy work-around.
Dec 22, 2007 | Garmin iQue 3600 GPS Receiver
My gps will not recognise my sd card or turn on
Try the clear flash utility. It worked for me. Martin
May 06, 2007 | Tomtom GO 510 GPS Receiver
Fine Digital FineDrive 350 GPS Receiver Logo
187 people viewed this question
Top Fine Digital GPS Experts
ChuckyMo
drivealot
Iqbal Husain
Iqbal Husain
Are you a Fine Digital GPS Expert? Answer questions, earn points and help others
