Fuzzy logic dwf 6010ap washer error codes. Trying to commence spin cycle and code flashes LE
SOURCE: daewoo washing machine dwf-75ts
Found the manual for a similar model. LE error code indicates a "Lid Open" error. Most likely the little switch that is tripped when you open the lid has failed due to corrosion or some other reason. If you can find an equivalent switch then replacing it should do the trick. Otherwise, you can simply short the connection so the machine thinks that the lid is always closed. WARNING: This effectively overrides the open lid detection system and poses the risk of having the unit run a spin cycle even with the lid open! find a replacement switch if you can. good luck! just shorted mine out temporarily and it works -- until i can find the right switch.
Posted on Jun 10, 2008
  • 1294 Answers
SOURCE: LG Fuzzy Logic won't drain out the water
Click on your brand name (below FIXYA) on this website, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line. And dont forget to rate me, on this great site.
Posted on Dec 21, 2007
SOURCE: LE ERROR CODE ON LG WM-2277HW
It worked!!!!!!!!!!!!!!!This is the second time it happened to me and I had a repair man come out the first time. You need to have a shop vac with you so you can just pull the plug.
Posted on Sep 13, 2008
SOURCE: "le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Posted on May 18, 2009
  • 472 Answers
SOURCE: Hi, we have a LG
working on lg for a while we have talked to tech suport and they don't want to admit they have a issue with these units.. first of all they say if on a pedastal they will give you problems but yet they sale the darn things... what we have found though is there is a device called a haul densor and it is very easy to replace you have to remove the backof unit panel and gain access to the back of tub... make sure it is connected well as it is on a rotor looking device called a stator assembly... if it is connected well and you have made sure it is level you have a bad haul sensor...thsi is what determines the speed of drum and slows down unit if getting out of balanced.. it is not that expensicve and pretty easy to fix.... hope this helps you out...
servicer 18 years
Posted on Jan 06, 2011
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
My washer has an LE error code. It makes an attempt to spin after beginning a cycle, once the drum doesn't spin the error code is flashed.
'LE' stands for Lock Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor when there is vibration/movement from the drum turning, requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 06, 2011 | LG WM1814CW Front Load Washer
LE CODE WHAT MEANS. DAEWOO WASHING MACHINES MODEL: DWF-772W
LE error code refers to the door mechanism. Usually there is a locking switch that senses when the door is closed, allowing the wash cycle to start. If your door is closed and you are still getting the LE error, it is probably this switch that is faulty.
Apr 20, 2011 | Washing Machines
LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Apr 13, 2010 | LG WM1814CW Front Load Washer
My washer says LE and hasnt drained all the water
I have the same issue - Had this washer for 6 yrs - up to now - it's been great. But, now I'm not sure what that problem is. Looks like the bin only spins counterclockwise - not clockwise. I can hear the motor trying to spin - then eventually I get the LE error code.
Dec 06, 2009 | LG WM1812C Front Load Washer
Dwf-6010ap
I HAVE DAEWOO WASHING MACHINE MODEL DWF-6010AP
THE PROBLEM IS THAT COLD INLET IS LEAKING WHEN RUNNING I NEEDS SOLUTION OR WHERE CAN I GET PARTS
Jun 25, 2008 | Daewoo Washing Machines
Daewoo washing machine dwf-75ts
May 23, 2008 | Washing Machines
Washing Machines Logo
120 people viewed this question
Top Washing Machines Experts
