Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
My dishwasher wont clean the dishes. The bottom rack gets kinda clean and the dishes on the top rack come out dirty and covered in film.
  • 901 Answers
Check whether the top rack spray arm main hose sits firmly into the
machine. If there is a leak in this area water pressure may not develop.
Also check the water pump in the machine!
Posted on Oct 01, 2010
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
It' no longer cleaning my dishes
hello,
If your dishes are coming out of the dishwasher covered by a removable dirty film, your water may not be hot enough, or you could be using an inferior brand of automatic dishwashing detergent. If you have tested your hot water and find it is between 140 degrees and 160 degrees Fahrenheit, consider how long it takes for the hot water to reach the dirty dishes in the dishwasher. If the hot water has to travel a long distance to reach the dishwasher, chances are the water filling the dishwasher starts out cold. To alleviate this problem, run the hot water nearest to your dishwasher until the water coming out is hot. This will guarantee the water filling the dishwasher is as hot as it should be to properly clean dirty dishes.
To remove this type of film from dirty dishes, after running the dishes through a basic rinse cycle, set a bowl filled with a cup or two of white vinegar on the lowest rack of the dishwasher. Remove any metal pans or utensils, and with the vinegar on the bottom rack, wash the dishes as usual. Dirty dishes that were once covered in film should come out squeaky clean
thanks.
Oct 23, 2010 | Dishwashers
Dishes are still dirty at the end of the cycle
hello,
hope this help?
thanks.
Oct 23, 2010 | Kenmore Dishwashers
Our Whirlpool dishwasher, DU1145XTPBA, has almost quit cleaning the dishes. It started with dishes on the top rack. My husband was told by rep to replace the top unit. That did not help at all. Now the...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
The top rack does not get clean. There is a dirty
Most likely the "food grinder" screen is clogged, which limits the flow throught the pump, leaving thehigher dishes unwashed. It's flaw inthe design of whirlpool/kitchenaides. Not only does the screen clog but the teeth on the "grinder" wear down, the girneder does no grinding, and the food particles build up onthe screen, clogging the water flow. Open up the collector, pul out he choer/grinder and clean the screen. Check the teeth on it and if worn, repalce the chopper/grinder. If it happens again , then the choper/grinder driving mechanism is basd -- replace the pump/motor assembly.
Feb 21, 2010 | KitchenAid 24 in. KUDU02FR Built-in...
Only bottom rack cleans. Re-plumb or replace?
Do you have a garbage disposal? If I run mine while the dishwasher is running, dishes do NOT get clean!
Jan 09, 2010 | GE 24 in. Profile PDW7800 Built-in...
Clean on bottom rack but dirty on top
Clean the filter at the bottom of the tub. If it is dirty or clogged the water pressure may not be strong enough to spin the top arm. Make sure also the there is nothing blocking the holes of the spinner arm. If the filter and arm are clear then the pump may be failing.
Aug 13, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Nov 25, 2008 | Dishwashers
Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Oct 11, 2007 | Kenmore 15529 Built-in Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
364 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
