Question about RCA 27F530T 27" TV
FPA LOCK ON MY RCA TV MODEL 27V513T
I have an rca tv model 27v513t that the fpa lock is on and won't let me change to cable mode or change the tv with the remote which is getting on my very lasting nerve....PLEASE HELP ME IF POSSIBLE
  • 3 more comments
  • davinco Jun 17, 2008
    I've lost the original remote and am using a universal remote. The FPA lock is on on my RCA 27V513T tv and I want to shut it off.
  • Anonymous Jun 19, 2008
    centrex TV has locked and I cant do anything with it
  • enolen Jul 07, 2008
    fpa is locked cant find out how to unlock it please help thankds
  • Anonymous Feb 15, 2009
    I have a rca tv and the fpa is on and I dont have any remote for it what can i do to have image again
  • baby bubbles Feb 15, 2009
    my 27'' rca has the fpa lock on and i dont have a remote for it its very fustrating when I can get it to work any where Please help me to get my tv working again
  • 85 Answers
Go to menu of your remote and unlock the fpa
Posted on Jun 11, 2008
  • jojo_crisp Jun 21, 2011
    i go to the menu and it wont let me move up or down with the remote
  • Buzzard320 Apr 05, 2012
    I can't get it to go to menu
What buttons do i press on the remote to remove fpa lock on a rca tv model 27v513t
Most RCA TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jul 07, 2012 | RCA Televison & Video
Turn off fpa lock without remote
Install an IR Remote App in android phone. The app link below worked for me to remove the fpa lock on. Configure the App for your RCA TV. Set TV as Device type, RCA as the brand. and choose the model (e.g., TV 20 F420T) also, select the Alternate IR Driver.
All the options of the command may appear in a list form. Close that and an actual remote with buttons should appear.
Then Power your tv will turn ON. Press the Menu. Pressing the Channel Down/Up Button to navigate to Preferences. Press OK button on the screen.. Then Navigate to FPA Lock. Press OK again. THis will turn the FPA Lock to Off.
Then you could use your on-TV buttons ZappIR Universal IR Remote Android Apps on Google Play
Nov 23, 2011 | RCA TruFlat 27F520T 27" TV
Rca 27'' tv set can't acess cable chanels with remote or tv buttons tv was in fpa mode by mistake got out of fpa mode but when i push tv buttons lock on again
Hello
Just unlock its FPA by any one of below mentioned process. Reset the V-Chip settings later and try.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Any one amoung the above process will unlock your GE TV. After unlock, you have to do the Vchip-Set.
May 08, 2011 | RCA TruFlat 27F520T 27" TV
Rca tv model 20F420T. tv is fuzzy and says "fpa lock" i cant get it back to regular cable
FPA lock option is located under TV setup. I just turned mine off and on without problems. Hopefully, your reset is effective.
Sep 27, 2010 | RCA 20F420T 20" TV
FPA lock on; have no remote control
FPA Lock On and have no remote for the TV on a RCA TV
May 20, 2009 | RCA 24V511T 24" TV
Lost orig remote/ fpa lock on
I have a 20f511t RCA Tru Flat with FPA lock on, using an universal GE remote press setup, then menu, channel down to preferences, press enter, channel down to FPA LOCK, volume up to change to on or off, press menu to remove, all shoud work now
Nov 23, 2008 | RCA 20F420T 20" TV
Rca tv 27v513t fpa lock
yesterday i was watching tv but suddenly it turned off and after that i was trying to turn it on but i wasn't.......but today it turned on , infact i was trying to turn it on.........i wanted to know what is the problem so pressed on botton and it said "FPA ON " after 10 min.again it turned off..............i don't know what should i do...........can you please solve my problem......i will be so nice of you.
thank you
Feb 08, 2008 | RCA 27F530T 27" TV
RCA Model 27V513T FPA Lock On
hey i have the same problem only i don't have a remote and i locked my tv out of my own stupidity. its model no. is 27V512T if you're any good with chips mabye you figure out a way to reset the tv.
Jan 17, 2008 | RCA 27F530T 27" TV
RCA FPA LOCK
Take the remote and turn the set on. With FPA (Front Panel Access, or Child Lock) on, the set will only turn on with the remote. Enter the menu, navigate to the page with FPA and set it to OFF.
Sep 02, 2007 | RCA 20F511T TV
FPA lock
rca fpa will not trun off plz help me trun it off
i nedd help plz
ty for your help
betty
Aug 15, 2007 | RCA 20F511T TV
RCA 27F530T 27" TV Logo
1,308 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
