Question about Ricoh Aficio 450 Copier
What SC 541 is ? - Ricoh Aficio 450 Copier
  • 126 Answers
Sc 541 is a fuser error code. try these steps
press clear mode once
press 107
press clear/stop and hold it untill your screen changes to copy sp mode.
press copy sp on screen
off and on the machine. it shud reset its code. i am a Ricoh tech. email me if you are having difficulty. ronils_singh@yahoo.com.au
Posted on Oct 01, 2010
  • Sean2020z Nov 23, 2010
    Thank you so much. Worked like a charm on first attempt. You are good:o)
  • 313 Answers
Thermistor error in the fuser unit, could have toner build up on surface of sensor. take fuser out and turn upside down remove the cover and check thermistors..Reset with following....yellow clear button at top of numbers panel then enter 107 then hold down stop button until panel changes(this needs to be done in sequence)
Sc 541 in sp 100
THIS QUIESTION NOT CORRECT , SC 541 ERROR IS SCANNER ERROR PLAESE CHEQUE THE SCANNER CABLE
Apr 28, 2015 | Office Equipment & Supplies
Errore code sc 541
kindly call for a change of themostat
Feb 02, 2013 | Gestetner DSc338 Copier
Errore code sc 541
Your problem is in the fusing unit.Check the thermistors and thermofuses.Reset the code :
Interrupt(yellow)key - 1 0 7 -press and hold STOP/CLEAR key more 4 seconds,enter in SP mode,open the front cover,turn OFF the main switch,wait 1 minutes,close the front cover,turn ON the copier.
Error cod sc 541
This SC-541 code comes when the fuser thermistor fails ore contaminated or poor connecton finellay power supply bord defective most of this cases we find thermistor failure first replace the thermistor 90% your problem solves- thankyou
Dec 15, 2010 | Ricoh Aficio MP 1600L Black and White...
Code sc 541 is poping up
SC 541 is caused by a defective thermistor check clean or replace the thermistors (center and Edge) of your fuser unit
May 30, 2010 | Ricoh Aficio 1035 Copier
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
SC 541 on Ricoh AP410N
press "yellow key"->107->Press "Red Key"for 5 sec-> 5#810 -> Press"Text/Photo Key" and "#" at the same time.
Reboot machine.
Jun 26, 2008 | Ricoh Aficio AP600N Laser Printer
Error Code SC 541
Its a fuser code. Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power.
Apr 01, 2008 | Ricoh Aficio AP600N Laser Printer
Ricoh Aficio 450 Copier Logo
672 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
