Question about Hampton Bay 52 In. Brushed Nickel Romano with Integrated Pan Style Light Kit Fan
I bought a 3 ceiling fans, i dont find the boxes so i do not know the code for each fan, so when i use the remote t control the other two fans start working. or when in the other room someone use the remote in my room the fan start working.i removed the lamp sectio, but i dont see the receiver. Im going crazy. please help
  • 377 Answers
The code switches are very small two position slide switches. Start with one fan and open the handheld fan controller. You will see the small slide switches that set the code, they may be in the battery compartment and do not look like typical switches. However you set the code on the hand held, you need to set the same code on the fan itself. The switches on the fan are usually in the motor cage and will look very similar to the hand held switches.
Set new codes in one fan and set another code on one of the others. The third fan should be fine. Please message me if you have problems doing this.
Posted on Oct 01, 2010
Sometimes my hampton bay ceiling fan goes on by itself . It has a remote control switch only. It is a model 08060
you probably have a neighbor with the same remote .. each fan has a set of code switches on its receiver .. what ever code is selected by the little switches on the receiver (box in the fan) also must be set into the remote control (code switches in the battery compartment of the remote) .. either you or your neighbor will have to change their code ..different codes wont interfere with each other ... if the fan came with the remote control then the switches might be available on the top of the motor housing .. remotes that have been added on require that the lamp section be removed to get access to the receiver .. some older fans dont have a code selection .. the code is stamped on the receiver .. in that case then maybe your neighbor could change his code ...
once in a while a strong or local transmitter will interfere and set the fan on .. if you are near a radio transmitter, CB or ham radio ..
May 25, 2010 | Hampton Bay 24002 Ceiling Fan
I have 21 ceiling fans in my house.
Three suggestions (maybe not viable solutions):
1. Consider creating ceiling fan "groups". A group is a set of fans that is controlled by one remote.
Group: All (or some) in all vaulted ceilings.
Group: All hallways
Group: Outdoor celing fans
2.
Power OFF ceiling fans at the wall switch that are not used often. Those can have duplicate codes.
3.
If the remote controls are iR (infrared) rather than RF (Radio frequency), then the ceiling fans that are farthest apart or have more solid walls in between, can have the same codes and not be affected by the "wrong" remote.
Oct 01, 2009 | Sea Gull Lighting 1555-734 Three-Light...
I bought a house with hunter remote control 52" fans, and one doesn't work, I replaced the battery and still doesn't work. How can I verify the remote code is correct for this fan? The code on the fan is...
set the remote to match the fan code. be sure you have a good battery in the remote and in thereceiver which is in the dish at the ceiling holding the electrical wires
Jun 23, 2009 | Hunter 52" Ceiling Fan With Light And...
I bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Jun 19, 2009 | Hampton Bay 24002 Ceiling Fan
Why does my Hampton Bay fan light goes on by itself
I had the same problem as well.....It turn out that there was interference from some other electronic device, garage door, microwave, digital phone etc etc etc who knows for sure. I removed the fan from the ceiling and pulled the small remote control box out, changed the code on the four tiny switches...changed the code on the remote control to match the control box...... Completely solved the problem with the lights. Hope this helps..
Dec 14, 2008 | Hampton Bay 24002 Ceiling Fan
No power to hunter ceiling fan or light.
It sounds like either the top part of your remote is bad, or you have a bad connection to it. Have someone that is familiar with electricity (that may be you?) check to see if there is power to the ceiling box, and fan's remote that is ususally in the ceiling box, or just under it in the cover. If you have power there, your remote is failing.
Nov 23, 2008 | Hunter 52" Ceiling Fan With Light And...
How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Jul 05, 2008 | Hampton Bay 04383 Calibre Ceiling Fan
Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Jun 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hampton Bay 52 In. Brushed Nickel Romano with Integrated Pan Style Light Kit Fan Logo
76 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
