Question about Craftsman Garden
26cc 150mph 340 cfm I need to know how the fuel line hook up one of mine was pulled off and now i do not know where to put it back
4 Suggested Answers
  • 35 Answers
SOURCE: The fuel lines pulled out of my 1978 GS550 when I
You will have two lines coming from the petcock on the bottom of the gas tank. the small one goes to the front of the number one carb, and the larger one plugs onto the fuel rail in the middle of the 4 carbs on the back. The lines that run between the 1 and 2 carbs and the 3and 4 carbs are just overflow lines, so they don't hook on anywhere else.
Posted on Sep 12, 2009
SOURCE: need to pull the full tank off a GMC 26cc petrol
go buy the same type of hose at home depot or lowes, and replace it yourself, it's easy
Posted on Jun 28, 2010
Terry Corrow
  • 10875 Answers
SOURCE: have a 1981 Ranger 377v bass boat. Someone took the 2 metal fuel tanks out and I want to put them back in. I need to know how the electric hooks up to my gauges and the fuel lines.
follow the wires from each gauge all the way back to the tanks,find the fuel line connections,each one goes to a tank
Posted on Jun 15, 2015
Testimonial: "The tanks and wire and plumbing has all been removed. They replaced the tanks with a 6 gallon plastic tank and I want the duel metal tanks back in the boat. I have the tanks but I need to know how the wire go."
I have a 340 Air Injection Chainsaw. We made sure it has gas/oil and chain saw oil. We get it started but it won't stay on? What are we doing wrong.
If it has an air filter make sure it is clean, also check the gas filter in the gas tank,
sometimes it will get gummed up and will pass very little fuel, it can be pulled out
by making a hook on the end of any wired coat hanger or stiff wire, once you pull,
it out remove the fuel filter , put the fuel line back in, make sure it is submerged
in the fuel, if it keeps running, just replace the fuel filter, the gas tank will have
two lines going to it, normally only one has a filter, also make sure the lines are
intact and don't have any cracks or breaks. make sure your gas to oil ratio is
correct. most chains will have it written on the chainsaw, or check your user's
manual. 40:1 ratio on older models , on newer models 50:1 good luck!
Jul 02, 2011 | Husqvarna Garden
Gas leaks out during use.
Mine is doing the same thing, I need to replace the gas cap on it. The other thing that you need to check is the fuel lines, the ethanol eats everything up.
Oct 25, 2010 | McCulloch 26cc Gas Blower Mcb3208
Troybilt TB90BC fuel line schematic? I have replaced fuel lines that degraded with age and am uncerttain about the correct hook to tank, carburetor and primer. A diagram would help
easiest way to tell you is that the primer is there to pull the fuel through the carb. so fuel filter line goes from tank to carb, then from carb to primer and then back to tank as a return. if you forget which is the in line for the carb just hook with gas in a jar and try sucking it out of the jar. put filte rin a jar. and run line to carb , then line out of carb to primer and line back to jar as a return. if it pulls freely and fills the primer bulb your ready to go. if it pulls hard or not at all something is wrong.
Aug 15, 2010 | Troy-Bilt Garden
What is the fuel line size for Troy Bilt TB525CS Trimmer?
Yes, something special to know. If the new fuel line is going into the gas tank, be sure to cut a steep angle on the end of the line going into the gas tank. This will allow enough of the line to get into the tank where you will be able to grab it thru the gas fill opening with needle nose pliers and pull it thru.
Apr 14, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My troy-bilt TB425CS gas string trimmer gas lines have gone away. In replacing those lines how far into the tank do they go?
far enough so that you can reach through filler cap and pull the line out to attatch fuel filter.
then you can pull it back in and let it rest on the bottom of the tank
Aug 14, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
The fuel lines pulled out of my 1978 GS550 when I was replacing the clutch cable. I need help hooking them back in the right places. I don't know which are fuel lines and which are vacuum and how they...
Jul 13, 2009 | 1980 Suzuki Gs 550 L
Cant figure out where fuel lines go on mccullogh chain saw
Fuel lines: one comes from the tank...has a filter in side the tank...runs up to the intake of the carb... you can tell by hooking up the lines to the carb, and put one into a gas supply... press the prime bulb... if it pulls gas, thats the one to hook into the tank...if not it 's the other... there should only be two lines a fuel supply and a return pressure line. Clean the air filter while you've got it apart....
k
Jul 01, 2009 | McCulloch 26cc Gas Blower Mcb3208
Poulan Weedeater sst25 25cc engine fuel line
ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
May 02, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Garden Logo
100 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
