Question about Kitchen Ranges
Well I have a Gss25tsress refrigerator, and recently I have started having problems with my ice melting in the top of the freezer, and the bottom of my fridge side freezing things, after doing some reading I decided to check my check my evap coils for frost, wich where frozen up, unplugged the fridge for 24 hours with doors open, checked the defrost heater resistance and it was 20 ohms decided to replace it bc it was only $30 well new one checked the same 20 ohms, did some more reading and figured I would change the defrost thermostat WR50X10068, # 4 thermistor WR55X10025, and the #5 Thermistor WR55X10025(only $24 for all three figured win win situation). Parts are on the way but I notice when I plugged the fridge back up everything worked but some time later I checked the freezer again and the compressor was running so was the condersor fan but when i looked in the freezer the evap fan wasnt blowing, even thought when i first plugged it up it was, so I unplugged fridge for about 10-15 min and plugged it back in, after 30-60 sec the evap fan came back on full speed, so I am really wondering if the main board could be at fault, or should i change change the defrost thermostat and the thermistors when they get here and see if it fixes it or should i just go ahead and order the main board as well?/ any help would be appreciated I have gotten most of my info from posts by "aasc'
  • raemmler Oct 01, 2010
    yeah thats what i was thinking too, I'm a diesel tech so working on trucks with air conditioning is basically the same concept as working on a refrigerator just different parts to some extent, and as a mechanic have that mindset of "why pay someone else to do it if I can fix it myself"
    also i notice that the pictures of the parts dont come with ends, so im assuming that if i solder and heatshrink the wires it will be okay, also the defrost thermo and #4 thermistor connector look fairly easy to get too, but the #5 thermistor goes into the wall dividing the fridge and freezer, any idea where that terminates or could i just solder the new one in there ?
  • 2,272 Answers
Yes just remove the old one out and solder the new thermistor there to its proper location .And it should be ok.As per the problem this is clearly indicating the problem of defrost in your unit.You have replaced all the possibilities relating to defrost.Just replace all the parts which you have ordered and see if it works.If in case this does not helps then the main board also has to be replaced.But as per the problem mentioned its not faulty main board,but the faulty defrost related parts.And that you are replacing so it should work. Check out.Keep updated.Thanks.
Posted on Oct 01, 2010
    President:
  • 2,777 Answers
I see, well the thermostat is the main culprit still in my opinion, but the fans issue is a very strange one. At this point I would recommend you do NOT order a main-board just yet. A faulty thermostat can send irregular information to the main-board itself and make it think it does not need to turn on fans, etc. I would start with exactly what you have on order, and I would think you would be fine. If it continues to have fan issues then you are correct in thinking the next part would be the main-board.
I am very impressed by your skills here! You are practically a fully fledged fridge person at this point!
Let me know if this doesn't clear up the issue, I am betting you will be fine without that main-board though.
Thanks!
Tim
  • 1 more comment
  • Tim Grayson
    Tim Grayson Oct 01, 2010
    You will be fine with just soldering the new one in there.
    Thanks!
    Tim
  • friermw
    friermw Sep 14, 2012
    Any follow up? Were you able to fix the fridge? I have the same model and have the same issues.
  • friermw
    Did the fridge work after the repairs stated above? I have the same problems with mine.
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
Whirlpool refrigerator #ER2CHMXPL02 I think I have two separate problems. 1st one is a water leak that fills the bottom bins daily! The freezer does not seem to be defrosting, everything in there looks...
Could be that the freezer is too full with foodstuff and there is no air circulation, therefor, some places in the freezer build ice. The defroster is working and melting the ice that drips to the bottom bins.
I suggest you remove everything from the freezer. unplug the frigde. Let all ice build ups melt. Remove ice from the foodstuff and put back in. Make sure that vents in the freezer and fridge are not blocked.
Oct 18, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
LG French door bottom freezer unit is only 5 years old. Bottom freezer suddenly not keeping food frozen. Ice cubes are melting, ice cream is soft, and there is water on bags of frozen food in top basket...
You have a defrost condensate drain blockage where all the water from defrost remains inside the freezer compartment and causes the symptons you are having. I cannot tell you how to remove every model numbers freezer rear panel but I think that if you study over my link here=> Leaking Refrigerators and this link HERE you will get an idea of what to do. I am here to answer any questions, Sea Breeze
Aug 09, 2013 | Refrigerators
Water is leaking from top part of freezer down to bottom of inside of the frig. Frost is on the top of the frig in the frigerator.
FIRST STEP: UNPLUG THE REFRIGERATOR. AFTER IT'S UNPLUGGED, DO THE FOLLOWING:
Remove the food from the freezer compartment and place inside the refrigerator temporarily.
Remove the bottom panel and back panel from inside the freezer compartment. You will probably notice that the bottom of the inside of the freezer is covered in ice. Use hot water (not boiling) from the tap and pour it on to the ice that is formed on the inside of the freezer compartment to melt the ice.
CAUTION: DO NOT USE A HEAT GUN TO MELT THE ICE AS IT WILL MELT THE INSIDE OF THE FREEZER COMPARTMENT. ALSO DO NOT CHOP AT THE ICE WITH A SHARP INSTRUMENT OF ANY KIND AS THIS WILL PUNCTURE AND DESTROY THE INSIDE OF THE FREEZER.
If you have a wet vac, you can remove the melted water using the wet vac. Or you can use a towel to mop up the excess water. You will still have to pour hot water onto the ice until all of the ice in the freezer is melted. Patience is key as it takes time to defrost all of this ice.
You will see a drain hole in the back of the freezer compartment that is still clogged with ice. You will need to continue to apply hot water until the ice has completely melted.
Note: When the ice in the drain breaks free, you will see all of the water disappear as it empties out.
In Whirlpool refrigerators, the water runs to a tray underneath the refrigerator. You will hear the water empty out into that tray. Then you will know that you have completely cleared the ice from the drain pipe in the freezer. To double-check this, take a small cup of warm water and dump it into the drain hole and you will see it visibly disappear and run into that tray underneath the refrigerator.
Replace the freezer panels back into the freezer compartment and plug it back in and return your freezer items back in to the freezer and you should be all set.
Oct 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My bottom refrigerator is not cold. The freezer is okay.
Check to make sure the fan in the freezer compartment is working and not blocked. This delivers the cold air to the refrigerator. The fan should run every time the freezer calls for cold.
Jul 22, 2009 | Refrigerators
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water accumulating in top shelf of refrigerator
Get yourself a thermeter and see what the tempeature is in the freezer. It should be "0" degrees or colder. If it is hanging around 30 degrees +/- you may have a compressor or control problem. You may have a drain tube clogged that takes the water out of the freezer. I am not familar with your model but many freezers are similar.
Mar 15, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Whirlpool Refrigerator or freezer Doesnot cool
I have a similar top freezer and during the summer
I have had a problem where the frdge part does not get cold. The two holes coming from the bottom of the freezer to the fridge are blocked
with ice. I took the back part off the freezer
got rid of a clump of ice. I also used a hair dryer
in the fridge section to melt the ice in the holes.
Dec 11, 2007 | Whirlpool ET1FHTXM Top Freezer...
Icemaker issue: cubes melting at the bottom causing water leak out the front
J, sounds like your dispensor flapper is not closing properly and you are drawing warm air up into the ice bucket. This model had an issue where the flapper pin holder was part of the housing and would break off. They have a kit now that fixes that problem. The only other thing it could be would be low freezer temps or it's staying in defrost too long. With out being there, I would start with the dispensor flapper. Check it out and post back.. Catriver.
Apr 21, 2007 | KitchenAid KSRS25ILSS Side by Side...
Kitchen Ranges Logo
88 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
