Question about Canon Office Equipment & Supplies
My canon image press 7000 has an error code number E000515-8005-02 What does this code mean and how do i fix it?
IB4G2008
  • 3587 Answers
SOURCE: canon pixma mp600 error code 5100
try this solution..from fixmyprinter.com
This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 02, 2008
SOURCE: PLEASE HELP ERROR CODE
E602-003this code means Canon’s hard disksystem have some problemsthe only solve way is change the hard diskThe hard sisk form our company just need connect to the printer then can usewithout any unconventionalitytill now our hard disk we selt to everywhere in China not found any trouble . if client’s machine already have print function,only need add our company’s print system then can get back the print function.(this print system need add RMB100)。If client’s machine don’t have print function,only need prepear the ROM card and network card from our company then can have the print function.(the ROM card and network card need add RMB600)
Our major disk:IR 2200IIR 2800IIR 3300IIR 3320IIR 5000IIR 6000IIR 8500I kprice as following
IR 5000I hard disk+system 500 +100 +600
IR 6000I hard disk+system 600 +100 +600
IR 8500I hard disk+system 850 +100 +600
*Period of validityall the year*
ADD:
201, West block, Shang bu commecial building , Hua Qiang south road, Fu Tian district, Shenzhen China.
Tel:0755-81677725 Mr.Lin
QQ: 870530595
Posted on Aug 19, 2008
  • 13 Answers
SOURCE: What is error code E000025 0002 for a Canon Color Image Runner C3380i and how do you fix it?
You should look at the 4 sensors behind the grey front plate, behind the front door, toner fall from hopper assembly on it and cause these codes ( each color cause a different code ), you should order a modified cable guide that protect sensors from toner and replace it after cleaning these sensors.
If the error code still appear you should change the toner supply motor ( each color have a different code ) or the PCB relay Kit (if i remember well you should also verify somme connectors on this PCB that can cause this problem)
Regards Mug71.
Posted on Sep 14, 2009
SOURCE: Canon Image runner 3200 error code E000002-0102
press *28*
<functions>
press "clear"
"error"
<Ok>
then off the main unit and on it
Posted on Dec 17, 2009
  • 1335 Answers
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
Posted on Dec 19, 2009
How to solve the problem of canon image runner 2318 error code E000001-0001?
The error code you have, means;"waste toner full, replace drum unit" .
Let's try to reset, step by step;
1,press "additional function", "*" "2", "8" in that order.
2, sssw will display, press "OK"
3,enter 34 press ok, enter 0 press ok.
4, press stop key.
Apr 16, 2015 | Canon Office Equipment & Supplies
How to fix the Canon Image Class Printer 4750 error code e001-0000
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
for more details : www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Jan 04, 2015 | Canon Office Equipment & Supplies
What does error E000003-0002 mean
The error code means you have a fixing unit problem. I take it you have a Canon machine. It may be rest, but whats the model of the copier? There are to many different models and ways to rest the code.
Jul 16, 2013 | Office Equipment & Supplies
When I press the button to turn on my Canon G9 the lense extends and then immediately goes in and on the LCD it shows "E16" Any clue what that means?
You're going to have to get it serviced since it will likely need a part replaced. If you need service on one of these, I'd highly recommend: www.camerasandparts.com They exclusively work on the Canon Powershots only and they do amazing work. The best part with them is they are about half of what Canon charges and the service with them is excellent. They really know these cameras. Good luck with it
Mar 02, 2011 | Canon PowerShot G9 Digital Camera
Canon image runner error code E000000-0000 solution
Note that clearing the error may not necessarily fix the fault.
Press the * with a circle around it then press 2 and 8 at the same time.
Then press * again.
Press copier touch button / function / clear / error /ok button then switch off.
Switch the machine back on.
The error code indicates that the machine doesn't sense the temperature of the fuser getting hotter. Usually this calls for the fixing film unit to be replaced because the thermistor has gone bad.
Oct 13, 2009 | Canon Office Equipment & Supplies
E 000001-0002
The error code mean your fixing heater isnt getting warm in a specific time.But it can be caused by a power dip.
So try this.
Press the star button and then the no 2 and 8 together press star again.Then you are in service mode.
In service mode sellect "copier" and then "Function"and then"clear"ant then"error" and press the ok on the screen.Swiths the machine at the plug off and on.
And Katchiiing!!!
If it doen't help you will have to contact your Canon dealer to replace that Fixing.
Oct 29, 2008 | Canon IMAGERUNNER 2230 Copier
Error E000
This is a reprint from another tech, he was right on with this...
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used until the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no response means the fixing assy didn't even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arrow buttons to scroll to #4 printer reset press set. press the appropriate arrow key under the YES to clear the error. unplug the copier and reboot. At this time normal function should return if not and it resets a E00 the you can assume either the fixing assy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to research the problem to avoid spending money on excess parts
Hope that helps...
Lbcoaster
Aug 08, 2008 | Canon ImageClass D880 Copier
Canon IR 3100 error code (E000020-0081)
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
Error code E005
if your machine is giving E-005 that means your fixing assembly (fuser cleaning web is not detecting) is bad.
go in service mode by pressing additional fuction + 2 & 8 + again press addtional function
If you find that the E005 code won't reset after replacing the Web, and clearing both web counters in service mode, <COPIER>COUNTER>MISC>FIX-WEB> and <COPIER>COUNTER>DRBL-1>FIX-WEB> perform a Error Clear in service mode <COPIER>FUNCTION>CLEAR>ERR>.
enjoy
Sep 28, 2007 | Canon imageRUNNER 400S Copier
165 people viewed this question
old marine
old marine
