Question about Mitsubishi VS-50501 50" Rear Projection Television
Mitsubishi HD 1080 wont turn on now
This TV is just at 5 years old and has worked great with no problems until out of the blue it has no power and will not turn on. Thanks for any help.
Ken
  • catfishjuke May 26, 2008
    thanks for taking the time to try and help me. I pulled the fuse out and it is still good. What would my next step be?
    Thanks again.
  • 868 Answers
You most likely have a blown fuse and its not very hard to change it.I'll try my best to walk you through it.Pictures have been added to make it  simple.First  remove all the panel screws 1.mitsubishi HD 1080 wont turn on now - 3f3f5df.jpg
Posted on May 26, 2008
  • Archie Ferrarini
    Archie Ferrarini May 26, 2008
    (1.) First, now you UN PLUG the TV or else you'll never finish putting the TV back together  2.locate(as illustrated in PIC .#2) the fuse and remove it.Test it & replace it if needed.
       I hope this helps you,it is about 80% of the problem I find in Big Screens.And for about $1.50 is what your fuse costs you can't complain.If your not sure if fuse is good than hold it up to the light to see if wire inside it is blown,thats a bad fuse.
I have a mitsubishi hd 1080 65315 model and the code is 23 what is the problem.
Mitsubishi TV Shutdown Troubleshooting - Stereo & Video ...
www.stereoandvideorepairco.com/.../MitsubishiShutdownTroubleshootin...
For example, the sequence: blink-blink, pause, blink-blink-blink, indicates an error codeof 23. This sequence repeats 5 times, so you can figure out if you are ...
Mitsubishi VS 50705 error code 23 - Service manual, repair and ...
forum.eserviceinfo.com/viewtopic.php?t=81051
Oct 24, 2010 - 10 posts - ‎4 authors Tv is old about 10 years. Shows error code 2-3 horizontal deflection failure. A few years back had a leaking crt, replaced the caps recomended ...
Oct 19, 2015 | Mitsubishi Televison & Video
did u by any chance open the assembly of the tv and touched the pcb board... the circuits on this board r very delicate and u shud be very if u r handling tis....
wen u switch on ur tv r u able to listen to any sound or wat?
if yes reply back, i wil help u
Jun 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My mitsubishi 42' hd 1080 tv turns off immediately after i turn it on.The set is about 7 years old.HELP!!!!!! niteowl42
Have you acessed the power indicator error code by pressing in the menu and input buttons on the front of the set both in together and hold in for 5 seconds? The led will blink a series of blinks to indicate a 2 digit code which will repeat several times. Let me know what the blink seqience is.
May 31, 2011 | Mitsubishi WT-42311 42" Rear Projection...
My PS3 connects to my 3yr old Mitsubishi HD tv fine via HDMI or the analog connection. However, using the same cable(s) it won't do anything but flash a squiggly green line a couple of times on a 6 year...
yup one or the other is capped at or below 1080 P - I so when you go to power it up at a new tv push and hold power till it makes the second beep 5 secs later and your good to go ok :)
Dec 21, 2010 | Sony Playstation 3 (PS3) Console
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
Jun 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
My 50 inch Hitachi plasma 1080 tv has a blinking blue light and screen is blank when powered on.
my hatachi hd/1080 tv has a solid blue light on and it wont turn on i push the reset button on the bottom right and it still wont turn on
Mar 27, 2010 | Hitachi P50H401 50 in. Plasma HDTV
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
No sound in hd 1080 mode.
check to make sure that you have all the cables plugged in for that model you need a total of 5 cables for the HD input. 3 component(red,green,blue) and 2 audio(red,white)
Mar 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
HD setup, 480 to 1080 not working.
I had this same problem, got my HD installed yesterday w/ Direct TV, have had this TV since '02. The fact that is wasn't working, and Google, led me to your post in search of answers. I even went to a local retailer that sells the Mitsubishi TV's and they were as helpful as if I had gone to a drug store seeking the answer. So, between browsing other posts, and then going to the manual (who'd of thunk) I got my, and your, answer. You need to do the following, nothing magic: 1)Connect the component video output of the Direct TV HD Receiver to the DTV inputs on your TV. The COMP 1/2 inputs are NOT 1080 compatible, only the DTV input. As another poster said, you must use component video cables, not the old red/yellow/white cables. you can lose too much signal quality w/ the old R/Y/W cables and your TV still won't recognize the 1080. 2)Set your receiver to a HD Channel, which are in the 70's. 3)Use the format selection on your remote and select until you get the 1080i Standard (or whatever your preference is) format. 4)Enjoy Bottom line is the COMP inputs are not HD. Page 64 of the manual (at least the one i downloaded from mitsubishi-tv.com) is what gave me the final piece of the picture. Good Luck!
Sep 20, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Televison & Video Logo
149 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
