Question about IC Intracom iVIEW 4-port KVM Switch
Hi, I lost my iView ac/dc adapter and need to buy a new one. Can you tell me the specifications about voltage, polarity and amperes?
The switch that I have is a 4 port, (http://www.cablegear.com/156752.html) and it uses a 9-volt, 400mA A/C adapter. I do know that this type of adapter can be found on most VTECH cordless phone cradles which also has the same size DC plug.
Posted on Jan 12, 2011
Need to know input, polarity and voltage to ensure I have the right adapter.
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Jun 24, 2013 - If the device has a DC input of +12V / 5.4A, get an adapter that has a DC output of +12V / 5.4A. If you have a universal adapter, make sure it has the proper current rating ... Ideally, you'll have the same voltage, current and polarity on your ......or hdmi on my laptop .can you say what's the reason for the same.
How to select an AC to DC power adapter - ApogeeKits
www.apogeekits.com/power_adapter_selection.htm
An explanation of regulated versus un-regulated AC to DC voltage power adapters. ...voltage output power adapters and how to use this information to select the right one... Some (more expensive) DC voltage output power adapters have voltage ... Care should be take to ensure that the maximum input voltage of the load ...
AC/DC Power adapter ' Laptop Parts 101
www.laptopparts101.com > Laptop parts
Dec 26, 2008 - It's very important to use the right adapter for your laptop. ... Polarityon the new adapter's plug must be the same as on the original ... AC/DC power adapter voltage and amperage ..... I have purchased an non-hp dc-dc convertor (150W), 12Vinput, 19V output. .... So the cable component has to be replace.
Determining Proper A/C Polarity - Galen Carol Audio
www.gcaudio.com > Resources > How-To's
Jan 10, 2016 | Computers & Internet
I lost my 12 V 3A DC adapter for my LG Flatron E2360V-PN What kind is compatible
have you been tried to find at the shopjimmy.com or at the amazon.com?. you can replaced it with other adapter even not LG, the only need to considered is the same voltage and amper rating as will as the size of the output jack and polarity of the adapter you will replaced. which will fit and same polarity to your monitor .
Dec 11, 2012 | Computers & Internet
Can i use AC Adaptor that has input: 230V-50Hz output: 9VDC to Creative SBS 2.1 370 Speaker?
The Creative SBS 370 Works on 11.5V AC (IT IS NOT DC) 1600mA (Means 1.6 Ampere) and 18.4VA. So, the Power Adaptor which you connect to the power socket behind the woofer is an AC ADAPTOR and NOT A DC ACAPTOR.
Nov 02, 2011 | Creative Labs SBS 370 Computer Speakers
I want to buy a battery charger. Where do I purchase?
Hello
The external power adapter for your device is for [6VDC - 1 Ampere]. You can use any adapter with this capacity to charge the battery inside the your Philips Da1000. Brand is not matter, but the voltage and current is. Just check the DC socket polarity. It is the main thing that ahs to be checked. Some sets will have outer (+ve), and some others have (Outer (--ve). This will be marked at the DC in terminal of your radio. It is best to be the set in hand, when you go to buy a new one. This adapter can be bought from most of the electronic spare parts selling shops at your town. Philips has designated as [6V direct current, positive pole to current pin] as pin confuguration for the AC adapter. If so outer ring connection will be (--ve). Anyway, make sure about it before buying a new one. OK.
Aug 30, 2011 | Philips DA1000 FM Radio
I have a Prolink wireless 900 Mgh wireless speaker system. I have just moved and have lost the plug in adapter for the transmitter. could you tell me what the adapter voltage is into the transmitter. ...
I have Prolink 900 MHz wireless loudspeakers, probably the same as yours. The transmitter is labelled on the bottom as "CAN 2579 102 1811, UNI-ART PRECISE PRODUCTS LTD". That transmitter comes with an AC/DC adapter whose output is labelled as 12VDC, 300mA, with polarity positive outside, negative inside. Note this polarity is the OPPOSITE of what is typical for AC adapters.
Sep 14, 2010 | Audio Players & Recorders
What is the DC voltage, current, and polarity of AC adapter
Howya mate , i wouldn't use a adapter which your not 100% sure belongs to it , even something you'll have the right connection and the right voltage on the plug it will still fry the chip or electrics cause the designers of the item designs adapters in such a way the voltage might be the same but the current is altered and that's why you have to buy a replacement adapter at double the price.
Aug 19, 2009 | Office Equipment & Supplies
Lost ac/dc adapter
Hi, for a 12v 2 ampers device any universal laptop power suply can be used. They usually are tesignedfor about 2-4 ampers so it won't be a problem. All you have to ake soure is the correct polarity, and the changeable dc plug.
good luck.
Mar 20, 2009 | Kogi L7CH Monitor
Lost the power plug what kind is it
1. You can buy a new power plug here.
2. You look at the power connector on your scanner and try to find a replacement with the following specifications:
Input voltage/frequency:
  • 100 Vac, 50/60 Hz (Japan)
  • 120 Vac, 60 Hz (North America)
  • 230 Vac, 50 Hz (Europe)
Output voltage/watt:
  • 12 V DC, 15 watt maximum
If you try to find an AC/DC converter yourself, make sure that the DC plug has the right +/- polarity and right size.
Jan 11, 2009 | Visioneer 4400 Flatbed Scanner
Lost power supply
If the desktop charger is the version that can accommodate two radios simultaneously similar to the T5000, then the AC wall adapter or the power supply is 9 volts AC.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 26, 2008 | Cobra Radio Communications
What type of ac adapter do I need for the av700
I would suggest to check the plug on the av700 and see the polarity, it might be indicated there.
In regards to using any adapter, you could as long is the same polarity. The original adapter is 6 Volts and 2 Amperes.
May 21, 2008 | Archos Televison & Video
IC Intracom iVIEW 4-port KVM Switch Logo
149 people viewed this question
Top IC Intracom Computers & Internet Experts
micky dee
sonyamw
Stojan Nikolovski
Stojan Nikolovski
Are you an IC Intracom Computer and Internet Expert? Answer questions, earn points and help others
