Question about PfaFF Tiptronic 2030
My Pfaff 1222 is " locked up" and the needle won't go up and down. There was a tangle in the bobbin thread and it was fixed, then the machine "locked up" and won't sew. The motor runs.
  • 255 Answers
SOURCE: Feed Dogs, Thread Tangle
Hi Jeanette! You have a Singer Featherweight--the best sewing machine ever made! (Mine dates from 1950/51 and I wouldn't trade it for the world.) These beautiful, sturdy machines were designed to be easily repairable at home, but you'll need a copy of the Service Manual (get the Instruction manual too, if you don't have one.) Go to www.singer-featherweight.com and check out what they have available.
I had a similar problem (needle thread not catching the bobbin thread) and the problem was that I hadn't put the needle in correctly (flat side to the left). Also, I will occasionally get thread wrapped around the bobbin housing--sewing along just great and then everything comes to a screeching halt. I'm not sure why that happens, but I'm getting pretty good at taking the bobbin housing apart. The manual is pretty clear on how to do it. You can contact me direct at robbie1949@comcast.net for more information.
Thanks!
Robbie
Posted on Jan 10, 2008
bargainbox
  • 1388 Answers
SOURCE: tangle in bobbin area, stuck needle
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Nov 13, 2008
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
Mongo32
  • 111 Answers
SOURCE: its like it is getting tangled in bobbin casing
loopy on bottom means upper threading or tension is wrong
Posted on Aug 23, 2009
bargainbox
  • 1388 Answers
SOURCE: bobbin thread tangles and needle jams
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
TOP LOADER:
FRONT LOADER:
back properly.
OTHER ISSUES:
bargainbox.com.au
Posted on Sep 04, 2009
Pfaff 1467 needle jammed in fabric and hand wheel stuck
Be sure to unplug the machine.
Loosen the screw that holds the needle in place (even though the needle is still stuck in place) and try moving the handwheel so the needlebar will raise to its highest position.
Try to remove the bobbin case from the machine. If the thread is tangled, you can try snipping (patiently and carefully) with small scissors and removing the loose threads with tweezers. Do NOT yank! Just keep working until the thread knot becomes loose enough to actually remove the bobbin case and the needle.
May 01, 2017 | PfaFF Sewing Machines
I have a pfaff 2040 and when the needle goes down to pick up the bobbin thread the main thread wraps around the bobbin housing and jams. Doesnt grab the bobbin thread. How can I fix this?
Be sure to use a brand new needle because a bent needle could miss the bobbin thread.
Search the internet for sites and videos relating to sewing machine timing or take it for service.
Dec 02, 2016 | PfaFF Tiptronic 2040
Baby lock pro BL40, bobbin thread tangles, tried new bobbin, cleaned under plate, needle is straight, what to do?
make sure the bobbin is turned the correct way in the bobbin case
make sure the top thread has not come off the thread take up lever
could also be a timing problem
Jul 28, 2014 | Sewing Machines
The thread from the spool breaks immediately. Does it need a particular kind?
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Oct 12, 2012 | PfaFF Sewing Machines
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
brother sewing machine
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
E6. Motor locked up because the thread is tangled. I have re-threaded machine and bobbin; thread still tangles after 2 or 3 stitches. HELP!
In my Brother CE-4000, it appears as though the feed dogs (which you can change to a higher position or a lower position) are allowing the bobbin case to spin all the way around and then the needle hits the bobbin case. When the feed dogs are in the lowest position, the bobbin case does not spin all the way around when the needle moves up and down (and therefore the needle does not get stuck in the bobbin case. I am wondering if this is a problem with the feed dogs/case?
Jan 18, 2011 | Brother CE4000 Computerized Sewing Machine
My Pfaf 1222 made a rattling noise, but was sewing. Now it jams with thread after two revolutions, need to hand turn the wheel to get it to turn those 2 turns. I broke one needle. I bent another. When I...
Check the manual for maintenance infromation.
Noise can be from lint in the bobbin area.
After cleaning, re-thread the machine with the presser foot up to see the combination of cleaning and "presser foot up" threading helps.
Mar 29, 2010 | PfaFF Tiptronic 2030
Pfaff 1222 Bobbin holder stuck with thread
With power off, take the needle out and the presser foot. Remove the two flathead screws that secure the needle plate from the machine and remove the plate. You'll have a top view of the bobbin housing and see the thread that's stuck to it.
Jan 30, 2009 | PfaFF Tiptronic 2030
Sewing Machines Logo
247 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
