Hi I have a jvc xl m500 6 disc cd changer and the tray won't open help.
I had the same problem. Out of the blue, neither the single tray nor the cassette would eject. On top of that, it wouldn't change discs or even play the disc in the engaged tray. I then unplugged the unit, moved it to my work table, plugged it back it, and it worked fine.
Last year I had a similar problem with the JVC receiver RX750V that I had bought along with the CD player, probably around 1986--it simply would not turn on. I took it out of the cabinet, and shipped it to a JVC repair shop called BC Electronics, Levittown, PA 215 547-7600. They were very knowledgeable and courteous, but said they could find nothing wrong with the unit, and that the unit worked fine. They shipped it back, and the unit worked fine initially. I found that the problem recurred, i.e. that every so often I'd turn the machine on via the on-off switch, and nothing would happen. If I then unplugged the unit, left it off for a while, and plugged it back in, it would work fine. I then installed an in-line on-off switch on the receiver cord. It now seems to work fine consistently.
It seems that after twenty years, this same problem may affect this generation of JVC components, i.e. that the main power source to the unit must occasionally be cut off.
On the other hand I could be completely wrong and just plain lucky...Hope that helps.
Posted on Feb 13, 2011
Cd player won't open and won't power off.
This means that something in the mechanism is jammed. It keeps on trying to correct for the misalignment- a service technician will need to see the unit.
Dec 08, 2012 | JVC XL-FZ258BK 5-Disc CD Changer
JVC xl-fz258 won't open to eject cd, won't play
The basic problem is that the drive mechanism has failed. The problem with CD ejection can be caused by binding in the tray or a weakened ejection motor
Dec 02, 2012 | JVC XL-FZ258
Li Have Sharp Home Vedio system Model : CD BK 1600. the Tray was not open .
hii guys as using my sharp CD-BK 1600 in video mode suddenly PROTECT mode is activated and i have lost my user guide plz help me reaching out of it....
Mar 25, 2011 | JVC XL-FZ258BK 5-Disc CD Changer
I HAVE A 5 DISC CHANGER.......I PLUG IT IN, TURN ON POWER AND THEN PUSH OPEN. OPEN COMES UP ON THE SCREEN BUT THE TRAY DOES NOT OPEN. WILL NOT SKIP FROM ONE DISC TO ANOTHER EITHER???????? ANY...
The 5 disc carousel CD player has a belt driven mechanism in it. And after about 3-4 years the belt looses its tension and cannot push the tray in or out. If you keep your ears on the top cover and turn on the system you will hear a whirring sound coming from the inside which will prove my point.
There are two belts in the machine. One for the eject mechanism and the other for disc change mechanism. One has to seek professional help to replace both because there is timing sequence also involved like the cam shaft of an engine.
Mar 08, 2011 | JVC XL-F154BK 5-Disc CD Changer
Jvc xl-f254 cd changer for home. 5 disc changer. Carousel will not slide out. makes humming noise, possibly trying to open.
Take the cover off and inspect for a jammed disc.
If there are no jammed discs you either have a broken belt or stripped gear.
You will have to take the unit apart and inspect, belts are commercially available from electronic stores and are a cheap easy fix!
Let me know if you need more details or guidance.
Cheers!
Kevin
Jan 29, 2010 | JVC XL-F254BK 5-Disc CD Changer
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
On my JVC TH-60 disk drawer will not open?
hello the problem you have is that the tray is not in time so the security switch dont let to open this try to get ifo how put on time or align the mark on main spindle against the small one hope you undrstood saludos
Jan 08, 2009 | JVC XL-F154BK 5-Disc CD Changer
Cd changer won't open
try to open by hand,see if the tray is stuck.
opening by hand is you turn the motor.
if you put a power supply direct to the motor the pcb will be burnt
(giving a bigger problem).
Look for mechanical problems.
Mar 09, 2008 | Audio Players & Recorders
Cd Changer will not play CD's
hi does it then say no cds? does it try and load the tray? sounds like it is not reconising that any cds are inserted, could be the laser, faulty or the tray is not reaching the tray in/loaded switch. not worked on many jvc units, so it a bit of guess work regards Mark www.carradiospares.co.uk
Jan 08, 2007 | JVC CH-X470RF 12-Disc CD Changer
245 people viewed this question
 Grubhead
Grubhead
