Question about Sony Cyber-shot DSC-W70 Digital Camera
I had the "Access" error when turning on my Sony DSC-W70. The lens would go in and out a few times, and then I would be instructed to turn the power off and on again, which did not help. After reading comments from a few people with the same problem, I tried yanking on the lens when it was out and giving it a good couple of twists. I also took a q-tip with alcohol on it and cleaned all around the sides of the lens. Worked like a charm!
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Feb 15, 2011
Whenever I switch the camera on, I get the error message "Access Turn the power off and on again". Lens does not collapse and remains extended. Cannot take pictures. This happened after the...
Unfortunately, many cameras that fall prey to lens error problems (Access Error on Sony's) can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jul 03, 2011 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-W70 "access"
Hi Guys
Sorry to be the bearer of bad news :(
Both your camera`s lenses are faulty. It is a common problem found on the DSC-W range of cameras and therefore not to expensive to repair.
The lens unit is only available as a complete unit from Sony. Your best bet would be to contact the retailer where you bought it and ask him for the details for your nearest Sony Service centre. It needs to be a Authorised service centre as there are software and settings that must be done after a lens replacement.
In my experience repair cost will be between 40 and 60 % of the price you paid for the camera.
Sorry there really is not anything you can do yourselves to fix these problems.
Good luck
Dec 28, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Sony cybershot DSC N-1
Lens isn't working properly and need to be replaced.
Jun 07, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
System error sony DSC-w70
Try re-charging your battery or you may check your memory stick. If the cause of this problem is by an accidental drop of the device, then may be you suspected right on the lens. It may cause dis a line of gears... ^_^
Jan 15, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
I cannot get pictures from my camera - W70
Try checking your memory card. It maybe corrupt or damage... ^_^
Jan 14, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Carmera not opperating
lens alignment or onboard memory problem , try using a memory stick instead of onboard memory ,and LIGHTLY TAP THE LENSE if you can get it out. if that doesnt work i suggest to go to a sony repair center
Sep 27, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
apparently i have some bad news , its the lense which is misaligned or broken in terms of gears, the thing to do turn on the camera and make sure that lens is out and then LIGHTLY tapp on the lens the direction of which you feel that the lens is not equal legnth to the outer ring > place that looks uneven
Sep 26, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Camera will not go past this mode.
Firmware problem. Check your Manuel for fault types contact Sony Tech support Team
Jul 11, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Problem in DSC-W70
Just keep tap it a couple of times on your palms.. Try that a few times.. Had the same problem and worked like a charm for me ;)
Apr 09, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
CYBER-SHOT DSC-W70
Hello LILYD, there is no password. Replacement/realignement of the optical block will solve the problem. Please contact the nearest Authorized Sony Service. The price for optical block (lens) is about 70 Euro (for my account). If you need more info please advice, Arpi
Mar 07, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
24 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
