Question about Kenmore 57029 Side by Side Refrigerator
When you open the door there is a loud click sound coming from the bottom hinge. Model 106.56989601
    President:
  • 1,796 Answers
Hi!!
Would you tell me a little more about the click sound please. Which door hinge is it coming from fridge or freezer?
The water dispenser tubing remains attached to the freezer door and pulls through the bottom left hinge. Make sure you protect the dispenser tubing from damage.
Another thing to look for is the door closing shim or door closer click on the following link for a diagram of the refrigerator parts http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram pass the mouse over the bottom corner of the diagram for a description of the part. Let me know if you could identify the part and we go from there. Thanks
Posted on Oct 01, 2010
2 Suggested Answers
  • 457 Answers
SOURCE: my whirlpool fridge side makes a click sound when
sounds like the plastic holder on the hinge is are worn. the call them grommets also.
Posted on Feb 24, 2010
Front passenger door suddenly started to make a loud clacking/snapping sound when opening, sprayed lithium grease - no change
between the top and bottom hinge of the door you will see a flat plate thats fastened to the door and post its purpose is to smooth opening and closing the door check the securing bolts and nuts its known for them to come loose over time also the welded on nuts that secures it can break loose so that area is where the noise is coming from
Mar 11, 2016 | Cars & Trucks
Right door makes a clicking sound
There is a nylon gasket at the bottom of the door hinge pin that needs replacing.
Jun 27, 2010 | Frigidaire FRS23KF7AB Side by Side...
How to move the door to be opened from the other side?
To change the door opening side, you will have to do the following.
Move the hinges to opposite side. There should be a plugs in the holes for the new locations. Carefully remove them without damaging them. They will be re-used in the opposite side.
Remove the door and hinges. Install the hinges and door on the opposide. Insert the plugs in the
holes left from removing the hinges.
Carefully remove the plugs for the new location for the door handle.(You will reuse them)
Carefully remove the trim at the top and bottom of the handle. Now remove the screws and move the handle to the opposite side and install. Install trim top and bottom. Put the handle plugs in the holes left from the handle removal.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GB9SHKXL
and click on your model number. The new window will have an assembly diagram of your unit. Click on the diagrams on the left-hand side for different views.
Mar 29, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Difficult to pull door open and loud click coming from left hinge
I would check for obstruction in the path of the door spring areas. If appropriate, remove the bottom access panel (typically 2 screws); open/close the door in attempt to observe the inside bottom left and right for the clicking sound.
If not already done so, also ensure your dish-washer is raised of the floor a little bit; leveled and properly secured to counter top with 2 screws.
-C
Fremont, CA
Jan 30, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
Frigidaire fridge door makes a loud popping sound
You need to take the door off the hinges and remove the lower hinge plate from the bottom of the door. This is where I found my popping problem. The black bushing with the 3 bumps and dips on it is loose in the plate going into the door. I took black eletrical tape and rapped it around the part that goes into the plate to tighten the bushing up so it wouldn't turn anymore. ( This was a temp fix to see if the popping would go away) 3 Weeks later and still working. If the sound comes back I will put some double sided sticky back foam on it. Both doors were doing this on my fridge, and now its as quite as a mouse. I hope this fix works for you.
Dec 29, 2008 | Electrolux Frigidaire Professional Series...
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 57029 Side by Side Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
