Question about Dell E151FP 15" Flat Panel LCD Monitor
Contrast keeps dropping until the screen is black
  • Dell Master
  • 629 Answers
Try to use the auto-adjust option and reset the monitor to its factory settings. if this does not help, try to replace the video cable and test it on another computer if possible. If you get the same results, it would mean, the monitor will need to be replaced. you may also disconnect the video cable from it and power it on. this would make the monitor show either solid colors or coloured bars. if you experience the same thing during the monitor test, you can be assured that the monitor needs to be replaced. If it is still in warranty, you may proceed to get in touch with Dell for it
Posted on Oct 01, 2010
  • 4 Answers
Chck the capacitor of the power supply
How to change the 'Contrast' and 'Brightness' on the monitor screen
Bootup your computer and display your Windows Desktop. Make sure yourmonitor stays on for at least half an hour before you begin, so that itis properly warmed up.
Seta pure black image on the monitor so you can adjust the brightness. Toget a pure black image, do the following: Choose Start, then ControlPanel, then Display. This will open the Display Properties dialog box.Click the down arrow next to the representation of the desktop color inthe Color field. Choose black from the color palette, then click OK.
Maximizethe Brightness control on your monitor, then slowly reduce it until theblack of the image perfectly matches the black at the edge of thephysical screen. This puts the brightness at the proper setting.
Open a screen with a plain white background soyou can adjust the contrast. One of the best ways to do this is to open aword-processing document without any text in it. Gradually reduce the contrastsetting of your monitor until the white area of the screen begins to lookslightly gray or off-white. Then gradually increase the contrast until thewhite area on your monitor is pure white. This will give you the proper whitebalance. Now you've got your monitor ready for peak performance.
Hope this may help you solve your problem.
Nov 12, 2010 | Computers & Internet
How to i fix the scree, it has gone all black?
Either you need to replace the batteries or lower the contrast. You do that by pushing the 2nd key, then pushing on the down arrow. Keep repeating until you can see a number in the top left of the screen signifying the contrast level.
Nov 02, 2010 | Texas Instruments TI-84 Plus Silver...
I turned on my TI 89 calculator to take an online college test that is due by midnight, and my screen is completely black!..HELP
your contrast might be up to much.
try this:
hit the diamond key and then the minus key. this shoud decrease the contrast. keep reapeating these same steps until your home screen is visible. hitting the diamond key, then the plus key turns up the contrast.
Oct 20, 2010 | Texas Instruments TI-89 Calculator
I've replace battiers in my TI-85 and now when I turn it on there is a black screen. I can turn off. What do I do to clear screen?
After battery replacement, the screen contrast is liable to change: It may be too dark (your current case) or too light. You must adjust the contrast.
  1. Press [2nd] key and release it.
  2. Press an d HOLD one one of the navigation arrows
  • Down arrow to lighten screen (your current case)
  • Up Arrow to darken.
Keep pressing the relevant arrow key until the contrast is adequate.
Jan 25, 2010 | Texas Instruments Office Equipment &...
Screen is mainly blank except for one faint line. Have put new batts in and checked for any dampness on inside, every thing looks good. Still nothing on screen.
It is possible that the screen contrast is too light.
To adjust the screen contrast follow the procedure:
  2. Press and Hold the UpArrow key to darken or DownArrow to lighten. Keep pressing until contrast is adequate.
Jan 03, 2010 | Texas Instruments TI-83 Plus Calculator
When I turn the calculator on, I get a black screen. It won't go away.
Most likely the screen contrast is too high. Try to lighten screen
Press and Hold [DownArrow] until screen lightens to your liking.
As you keep pressing DownArrow, the top right corner shows a number that decreases as the screen lightens.
Dec 15, 2009 | Texas Instruments TI-84 Plus Calculator
I have a Texas Instruments TI-83 Plus calculator and when it turns on there is just a cursor in the upper left corner and the screen in the middle is black.
Hello
Try reducing the contast as follows
1.Press [2nd] key and release it
2.Press [DownArrow] and release it
3. Keep repeating the sequence until contrast is adequate.
To increase contrast Do the same but press [UpArrow] instead of [DownArrow]
Hope it helps
Sep 07, 2009 | Texas Instruments TI-83 Plus Calculator
Numbers are messed up on the screen. can't read what it says.
Press the [CLEAR] key to erase everything on the screen. Adjust screen contrast as follows
Reducing the contast
Hope it helps
Sep 06, 2009 | Texas Instruments TI-83 Plus Calculator
Problm
Press [CLEAR] button to clear the screen. Try to reset the calculator to defaults as follows [2nd][MEM][7:Reset][2:Defaults].
If screen is too dark or too light, adjust contrast.To increase contrast
2.Press [UpArrow] and release it
3. Keep going through Steps 1 and 2 in sequence until display is adequate.
To decrease contrast do as above and press [DownArrow] in step 2
Hope it helps
Aug 23, 2009 | Texas Instruments TI-83 Plus Calculator
Screen Solid Balck
Hey, if this is a ti-89, press green diamond button, then -, keep going and it soguld fix itself
Sep 01, 2007 | Texas Instruments TI-89 Calculator
Dell E151FP 15" Flat Panel LCD Monitor Logo
50 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
