Question about Garmin Nuvi 660 GPS Receiver
GPS can not locate satellites. - Garmin Nuvi 660 GPS Receiver
    Scholar:
  • 38 Answers
Where did you try this? GPS signals are "line of sight" only and will be blocked by even thin metallic coatings. Some high-end european cars have window coatings that block GPS signals.
If the unit is new, it may take it a long time to get its first fix, It trys to look for the satellites it thinks it should see at whatever location it last was and at whatever time it thinks it is. After it first locks on to a satellite, it will eventually download new ephemeris data and correct itself, but this may take a while.
make sure you are trying this outside where the GPS has a clear view of the sky. You can go to the system settings page and set your location and time and that will help it find satellites quicker than it would if it thinks it is somewhere else at some other time.
If you still can't get satellites, you may have a bad internal antenna or receiver.
If you have already tried what I suggest, contact Garmin for their free technical support.
http://www.garmin.com and push the support button near the top of the page. There is both phone and email support.
Posted on Oct 01, 2010
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
Will not find city or locations
Hello.
Solution to the problem.
With the right piece of hardware and software, it ispossible to triangulate your location anywhere on earth using satellitenavigation. These gamin devices cansuccessfully guide you from one place to another, or they can simply use theconnection with the satellite to tell you your exact current location. Thelatter function requires you to know how to locate the GPS device using theoptions onscreen.
1 Purchase a GlobalPositioning System (satellite navigation) product. There are manymanufacturers, including TomTom, NavMan and Garmin.2 Turn on the GPS and leave itfor a minute or so as it establishes a connection between the device and thesatellite.
3 Navigate to the"Current Location" option in the "Tools" or"Settings" menu (the exact pathway to this option depends on whichGPS device you have). The satellite signal will now successfully locate yourGPS device.4 Type a ZIP code or placename once you have located your GPS device. The gamin can now successfully guide you to your finaldestinationThanks.
Sep 18, 2011 | Garmin nuvi 255W GPS Receiver
Says loooking for signal - even when plugged into car charger - could it be the gps battery
Being plug into a car charger (or wall charger) has little to do with not finding a GPS signal and this apply to your gps battery as long as you get power to your receiver.
It is not unusual for GPS to have problem finding suitable Satellites signals especially inside a building or areas where you do not have a clear view of the sky above you and the unit (e.g. High Rise buildings).
In order to speed up the location of satellites signals, you need to update your unit A-GPS Satellite locations database on a regular basis via 'Tom Tom Home' (which should be installed on your PC or Laptop). You can download the latest version of Tom Tom Home from the official site.
Without A-GPS and the unit not being in regular use, your unit may take a very long time to find suitable satellite signals. My own TomtOm One, without an up to date a-gps database has taken over 15 minutes to locate the required signals even in a relatively 'open' air location!
Hope it helps and clarify the issue.
Jun 12, 2011 | Tomtom ONE GPS Receiver
Slow
Your GPS unit finds satellites based on your current location. if you are not in a wide open area then your GPS would need sometime to locate the satellites. You might want to upgrade your GPS for faster locating.
Feb 28, 2011 | GPS
I want to use the gps and navigator on my nokia 5800 can you please help
The Nokia 5800 has a built-in GPS satellite navigation receiver, which can tell you where you are anywhere on the planet. The 5800 also has cell-tower-positioning technology, which finds your location using the position of the nearest phone network mast if a satellite signal is unavailable. GPS is more accurate but can take a while (from 10 seconds to a few minutes, depending on how obstructed the sky is) to find your position ('Assisted GPS' is also present, to download the expected GPS satellite positions from the Internet and help speed up your fix.)
The 5800 also has a built-in mapping application called Nokia Maps, which shows you your location on a street map, tells you exactly how to get to another location by driving or walking, and can give details of nearby amenities such as shops, fuel stations, museums, etc. Nokia Maps uses both GPS and cell tower positioning to tell you where you are: the latter gives an instant rough position, while GPS data is used after the phone has locked onto enough satellite signals calculate its position. You'll know the phone is locked onto a satelite as the lock indicator at the bottom of the screen will turn green.
Other phone applications can also use the GPS receiver if required. For example the camera application can optionally "geotag" photos with your current location using the GPS receiver to work out where you are (click here to see our camera tutorial and find out more about geotagging). If you switch to the standby or menu screens while an application is using the GPS receiver, you'll see a little satellite icon in the top right corner of the screen to indicate that GPS is active.
How does the 5800's GPS work? Like all satellite navigation systems, the 5800 receives signals from many different GPS satellites in the sky, and calculates your position based on those signals, using a combination of triangulation, signal delay calculation and a lot of very heavy maths that you really don't want to know about.
Important Note: Satellite signals cannot penetrate buildings, so GPS satellite signals will be difficult or impossible to receive if you are indoors and away from windows. If you want to speed up the process of GPS showing your location, take the phone outside or place the phone next to a large window with a good view of the sky.
The 5800's GPS aerial is inside the top left side of the phone. If you want to get a good GPS lock make sure this part of the phone is uncovered
May 11, 2010 | Nokia 5800 XpressMusic Smartphone
Why does my GPS system have a difficult time locating satellites?It says ''acquiring satellites'' for about 5 minutes. Then it says it can't locate satellites. Should it continue trying? Why does it do...
this is what my navigon says about gettting the gps to connect.
Initializing the GPS receiver
In the upper right-hand corner of the display, the GPS symbol appears. As soon as
data from at least 3 satellites is received, the symbol changes to (GPS Ready). Note: If possible, position the device with a clear line of sight to the sky to successfully
receive messages from the GPS satellites.
Note: GPS initialization requires data from at least three satellites. If GPS data is not
available, the receiver will not initialize.
Note: It can take up to 20 minutes to initialize the integrated GPS receiver for the first
time.
Note: Each time you turn on the device, GPS receiver initialization begins. When GPS
data is available, reception starts within one minute.
If the navigation device has been switched to standby for more than a week, the next initialization
can take up to 10 minutes.
Jun 19, 2009 | Garmin GPS
Won't locate satellites each time you turn it on.
The GPS does not have a line of sight to the satellites. Relative satellite position may vary somewhat through the year as the Earth wobbles on it axis. Reposition the GPS in your vehicle.
Sep 16, 2017 | Garmin Forerunner 205 Gps Running Watch
Battery replacement now ca't find satellite Garmin c320
I had the same issue with the only difference that I haven't replaced the battery yet. When my unit can't locate or acquire satellites I change between GPS and WAAS mode. Within 45 seconds my unit successfully locates satellite. After some time if I disconnect unit I might have to switch it back to GPS and so on, and so on, and so on. It worked for me for past 3 months... Hope it will help you...
Nov 12, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
G1 gps not working
have you actually enabled the G1's GPS receiver within the phone ?
the GPS is not switched on out of the box aswell as Wifi and Bluetooth.
Try going into the settings and enabling the GPS Satellite receiver and then use the maps application to see if the Satellites can Triangulate your position and find where your at !
hope this helps :D
Greenie UK
Oct 26, 2008 | HTC G1
I have a Garmin GPS unit which is not able to locate a satellite.
I have a Garmin c330 Streetpilot GPS system. It says that it unable to locate a satellite
Mar 09, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
216 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
