Question about Compaq Presario Notebook
The sound disappears...i cannot play music because when you open it you can only hear a beep sound. what would be the possible problems of my computer
    President:
  • 2,291 Answers
Open the Control panel 2. Open the "Sounds and Audio Devices" icon. 3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document. 4. If you were able to check this box, click ok and close out of this window and the Control Panel. 5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start. Now next you can do is If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button. Check ur sound card information by doing this Click on start menu Click on Run Type dxdiag, enter Click on the sound tab There is button of test direct sound click on this check if there is sound Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors.
Posted on Oct 08, 2010
My Sony Vaio VGN-FS690P has stopped playing sound. The sound card states it is working correctly. It does play one sounds, the sound when it starts and show the VAIO screen.
Hopefully this helps. Right click on your volume control icon. Open the "Volume Mixer," and make sure that nothing has the mute X on. Then right click on "Volume Control," and make sure that the volume control is checked to play all sounds, and that your Speaker box is checked. Next step is your music, if the sound was muted directly @ the music playback, this could be the problem. Open your Media Player and try to play music, if you cannot hear it, click on the mute button to the song playing. If your Player was shut off in the "mute" mode, then you will not hear sound. It Happened to me once. You will need to check all of your "Players" to see if any of them were shut off in "mute."
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Sep 26, 2010 | Sony VAIO VGN-FS690P Notebook
I can't hear any music, the sound volume icon disappeared, I hook up a speaker, I still can't hear any thing, not even a beep! I certainly need your help.
check video card drivers do an update to the drivers go to my computer properties and then device manager tab and check sound cards' properties and update drivers
Jul 22, 2009 | Intel Motherboard
Echo in my acer aspire 6930 latop
it sounds like you might have an old driver with your computer or possibly a progam running in the program is not allowing the computer to run fast enough to play the music. also try disabling if you have, antivirus programs or anti spyware programs.
Apr 27, 2009 | Acer Aspire 6930-6771 Laptop
Music outside the iPod
You can't because you can't. It is not a speaker that is meant for music, last time i checked it was pseudo something but forgot the exact name, its not able to make audio, just ticking sounds. Its sort of like the 'beep' that happens when your computer starts, you can't make that speaker play music it just beeps..
Mar 08, 2009 | Apple iPod nano MP3 Player
No sound for *some* blu ray discs / can't get a menu
Some blu ray disc play fine. Others play the menu music, but when the feature starts, the sound disappears completely. And then others don't play music at all, no sound what do ever.
Feb 05, 2009 | Onkyo TX-DS838 Receiver
Can't hear the voices when I play a DVD, only the music
WE'VE HAD THE SAME PROBLEM SINCE WE MOVED AND DISCONNNED THE SPEAKERS?
IS IT POSSIBLE THAT THE SURROUND SOUND WAS NOT HOOKED UP? AND THIS COU\LD CAUSE THE PROBLEM?
Dec 30, 2008 | kawasaki SVP500 Multi-disc DVD Player
Can't hear without handsfree, beeps
Hmm..did you try the customized profile so you can set it on the loudest mode? and also have you noticed if your phone makes any other noice like when you move around the menu or type a text messege? does it play music on the speaker? Try all possible ways you can think of that makes the phone create sound as a response. And last thing to do would be a reset.
  • Go to menu
  • Phone settings
  • Reset settings
Try this to bring the phone to factory settings, make sure you back up your information, like your contacts before, and good luck.!
Dec 13, 2008 | LG KU990 Viewty
I get a loud beep on my laptop but cant hear anything else
There is a beep system in all PC's
One quick been means the computer is OK when starting.
one long continuous beep is defined as :
' Power Supply or System Board / Keyboard stuck '
Note: Alternately it could be a Memory module
However it's more likely that it's the above
If you check those two things, you are likely to find the culprit.
If not, you need to post your BIOS and
Feb 20, 2008 | Dell Inspiron 2200 Notebook
Can't hears sounds without headphones
i guess u have 2 replace your speakers visit a nokia gallery
Nov 04, 2007 | Nokia 5300 Grey Cellular Phone
Sound capabilities
The symptoms you describe are caused by a break in the earphone socket ground connection.
If you are confident enough, dismantle the player and re-solder the 4 connections to the earphone socket.
Oct 04, 2006 | Philips GoGear HDD6330 MP3 Player
Compaq Presario Notebook Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
