Question about Hampton Bay 04078 Avanti Ceiling Fan
I have 3 of them, and when i use my remote control for one bedroom ,at the same time it starts working the other fans in the other bedrooms
  • 377 Answers
The code switches are very small two position slide switches. Start with one fan and open the handheld fan controller. You will see the small slide switches that set the code, they may be in the battery compartment and do not look like typical switches. However you set the code on the hand held, you need to set the same code on the fan itself. The switches on the fan are usually in the motor cage and will look very similar to the hand held switches.
Set new codes in one fan and set another code on one of the others. The third fan should be fine. Please message me if you have problems doing this.
Posted on Oct 01, 2010
2nd remote paired to two fans.
close the door and turn off power to that room and then try again
May 24, 2015 | Televison & Video
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
Bedroom remote doesn't work
weak batterys wont hold codes on it huh?
Sep 24, 2012 | DISH Network Televison & Video
I have one receiver in my living room. The living room tv is on the #1 channel and the kitchen, guest bedroom and master bedroom tv's are on channel #2. All remotes were working just fine and suddenly...
Hello! On the back of your receiver box you'll see a silver UHF antennae make sure its pointing straight up. If that fails try the steps in this link
http://www.dishnetwork.com/SupportSection/remote-setup
Daniel Busa
DISH Network Customer Service
Jan 04, 2011 | Universal Remote Control DISH Network...
My mother has two identical hampton bay ceiling fans with lights that are operated by a remote control. She does not know the model number. The remote will not operate the fan or the light anymore. It is...
Someplace there has to be a power (wall) switch that controls the power to the unit. Make sure it was not turned off by accident.If both the light and fan do not work on the unit, it sounds like a possible wiring problem or receiver problem. Unless you are good at house wiring, it may be best to have a professional come in. I would think a loose wire that takes power from the switch up to the fan/light unit or a white wire that would be a common neutral wire for both the fan and light. It might be a bit too complicated for someone without experience to attempt to remedy on their own.
Sep 30, 2010 | Hampton Bay Dryers
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
We have 2 Hunter ceiling fans with remotes. We can get the one in the bedroom to work great but the one in the living room now will not turn on the fan or light. Also when we are trying to get the living...
The remote might have wrong orders. Get the battery out and insert it back and see if the problem solved.
Do you set the dip switchs correctly on the fan and on the remote? Numbers set must be matched. Otherwise, the fan won't work either.
Aug 11, 2009 | Hunter 52" Ceiling Fan With Light And...
Motor Hum
check your grounds and all other connections. remote wiring has to be precise. somes times not for the do it your selfer. all the labor youve encountered somes the cheap can turn out to be very expensive.
Apr 26, 2009 | Hunter 52" Ceiling Fan With Light And...
I have a bedroom ceiling fan that recently started to have a surge issue. It was working fine before (although the remote control for this fan also worked on the Hampton Bay fan in the living room and the...
Sounds like you could have a problem with the fan....but there is also an equaly good chance it's the wiring of the fan. Perhaps a loose connection. If you are not familiar with checking electrical connections, you probably need to call an electrician to check the wiring SOON, before there is a short. If all connections are good, then you will know it's the fan (or the remote receiver on the fan).
Hope this helps!
Chad
Oct 14, 2008 | Hunter 52" Ceiling Fan With Light And...
Simultaneous fans
USE A DIFFERENT DIP CODE TO THE SECOND RECEIVER AND REMOTE
Jun 01, 2008 | Hunter 21617 Palermo Brushed Nickel...
Hampton Bay 04078 Avanti Ceiling Fan Logo
64 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
