On a Toshiba e studio 161, how do i get into service mode to reset the developer and drum counters?? Thanks
  • yan dikshteyn Oct 01, 2010
    I need more detail than this please
    very clear and correct
    Thank You
  • 10,515 Answers
The procedure is explained below :-
Technical Service Procedure
Correct procedure for service of TOSHIBA e-Studio 161
When the spanner light and the developer (sun) light are illuminated it is time for a service.
* Try and run the PM Service and drum life counters together.
* Part that are required for a 50,000 copy service (OD 1620 DRUM, D1620 DEVELOPER, BL1620D DRUM BLADE)
* Clean and inspect drum unit.
* Clean all optics and glass.
* Clean and rewire transfer corona.
* Clean and check main charge needle electrode [saw tooth]
* Clean and check fuser units including blades, rollers and scraper fingers.
* Clean erase lamps and ozone filters.
* Clean and check all feed rollers.
* Clean machine inside and out.
* Replace the required parts.
* Reset mini maintenance counters:
* [CLEAR] > [EXPOSURE] > [CLEAR ]> [EXPOSURE] and the machine will die.
* Input [20] [START] [01] [START]"000""000" will flash on the display.
* Reset the drum life counter:
* Input [24] [START] [07] [START] "000"000" will flash on the display
* Reset developer life counter:
* Input [42] [START] [01] [START] "000""000" will flash on the display.
* Once all the part have been replaced and the counters been reset, check the copy quality.
* Notes: Application of the patting powder is for reducing the friction between the drum and cleaning blade. If the application of
patting powder is neglected, the drum and cleaning blade may be damaged. Please clean off the patting powder before putting the
cleaner unit into the machine.
Developing doctor gap adjustment
1) Loosen the developing doctor fixing screw A.
2) Insert a thickness gauge of 1.5mm to the three positions at 20mm and 130mm from the both ends of the developing
doctor as shown.
3) Push the developing doctor in the arrow direction, and tighten the developing doctor fixing screw. (Perform the same
procedure for the front and the rear frames.)
4) Check the clearance of the developing doctor. If it is within the specified range, then fix the doctor fixing screw with
screw lock.
* When inserting a thickness gauge, be careful not to scratch the developing doctor and the MG roller.
CHANGING A TRAY'S PAPER SIZE SETTING
Follow these steps to change a tray's paper size setting.
* The paper size setting cannot be changed when the machine has stopped temporarily due to running out of
paper or a misfeed, or during interrupt copying.
* During printing (even in copy mode), the paper size setting cannot be changed.
* A5 (ST) size paper can only be selected in upper paper tray.
* Do not load paper that is a different size than the paper size setting. Copying will not be possible.
Hold down the [PAPER SIZE ENTER]
key for more than 5 seconds to
set the selected paper size.
The currently selected
paper feed location
indicator will blink and
the corresponding paper
size (which is currently
set) indicator will light
steadily. All other
indicators will go out.
If the machine has two paper trays,
use the [TRAY SELECT] key to
select the paper tray for which you
wish to change the paper size setting.
Each time the [TRAY
SELECT] key is
pressed, a paper tray will
be indicated with a
blinking paper feed
location indicator.
Use the [ORIGINAL SIZE ENTER] key
to select the paper size.
The indicator of the
selected paper size lights
up.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 01, 2010
    President:
  • 3,278 Answers
Hello.
First, enter the Setup menu (or press the blue button on the remote control), then press the digits 4, 7, 2 and 5 / full manual.
Hope this helps.
How to reset Toshiba Studio 256se Total Counter?
Clearing counter
The counter indicating "current number of prints and driving time" used for the PM display function is
reset by entering "0" in it or clearing it in the PM support mode.
Notes:
Even if "0" is entered in the PM management setting value of the setting mode (08), the
corresponding counter for the PM display is not reset. Be sure to clear the counter in the PM
support mode when the maintenance is finished.
The reset condition of each counter is as follows:
• 08-6194: Current value of PM counter [process unit (K)]
• 08-6195: Current value of PM time counter [process unit (K)]
When the current value of "CLEANER/DRUM" on the main screen or "DRUM" on the sub-screen in
the PM support mode is cleared, the counter is reset.
• 08-5568: Current value of PM time counter [developer material (K)]
• 08-5569: Current value of PM time counter [developer material (K)]
When the current value of "DEVELOPER" on the main screen or "DEVELOPER" on the sub-screen
in the PM support mode is cleared, the counter is reset.
• 08-5576: Current value of PM counter [parts other than the PM parts of the process unit]
• 08-5577: Current value of PM time counter [parts other than the PM parts of the process unit]
• 08-6225: Number of output pages (Thick paper 1)
• 08-6226: Number of output pages (Thick paper 2)
• 08-6227: Number of output pages (Thick paper 3)
• 08-6228: Number of output pages (OHP film)
• 08-6244: Counter for tab paper
• 08-6247: Counter for envelope
When the current value of "FUSER" on the main screen or "FUSER ROLLER" on the sub screen in
Notes:
The following counters are cleared by executing the EPU replacement mode.
08-5568: Current value of PM counter [developer material (K)]
Jun 14, 2016 | Toshiba Office Equipment & Supplies
How do i access the service mode of Develop ineo 161?
1. Press the Utility key.
2. Press the following keys in this order.
3. Stop ? 0 ? 0 ? Stop ? 0 ? 1
4. The Service mode menu screen will appear.
Jun 08, 2016 | Toshiba E STUDIO 161 Developer Unit Mylar...
How to reset maintenance drum in toshiba e studio 200?? Please reply quickly.
You can use the Toshiba e-studio 160/200 service manual for this machine,
Enter 08 Service mode and:
check these addresses
340 Drum counter end setting. Drum Life:160 and 200 are 27,000 copies.
250 is 33,000 copies. If set to 0:Nothing displays.
673 Resetting drum related counters (08/355 and 08/401) works only if 08/869 is set to 1=SRU, if set to 0 is=CRU.
SRU: Service Replaceable Unit.
CRU: Customer Replaceable Unit.
Good Luck
Jun 27, 2011 | Office Equipment & Supplies
We have a Toshiba 170F fax machine that is no longer under warranty. I need instructions on how to replace the drum.
the drum & its cover is one unit
just remove the toner cartridge & put it in the new drum unit cover
May 11, 2011 | Toshiba E-Studio 161 Copier
Toshiba e-studio 161 developer low functions reset code
Sir, i added new toner and new developer but my printout is dull. What i do?
Nov 18, 2010 | Toshiba e-Studio 161 Copier Copier
Error code H2 on screen
Hello sir; H2 code require reset procedure as follow;
1, press "#", "interupt", "c", "interupt" these 4 keys.
2, enter 14 then press start.
3, turn power off and back on .
Jan 28, 2009 | Toshiba e-Studio 161 Copier Copier
Changing Developer on E-Studio 150
The developer you need to purchase is 1620 , and the drum unit also the 1620, you can see this number in the toner catridge itself. or in the toner catridge box. Regd. the 161 you need to purchase the products name 1620 number and the concerned part like developer, drum, toner, some gears etc.
Aug 19, 2008 | Toshiba e-Studio 161 Copier Copier
Toshiba e-studio161 Developer
* Input [20] [START] [01] [START]“000””000” will flash on the display.
* Input [42] [START] [01] [START] “000””000” will flash on the display.
doctor as shown.
screw lock.
CHANGING A TRAY’S PAPER SIZE SETTING
Follow these steps to change a tray’s paper size setting.
paper feed location
steadily. All other
Each time the [TRAY
SELECT] key is
be indicated with a
blinking paper feed
location indicator.
up.
Apr 11, 2008 | Toshiba e-Studio 161 Copier Copier
Change Developer indication doesn't go of even after replacing the Developer?
after replaceing the developer you have to clear the counter by going into service mode for techs and clear the total count for the developer to do this you need the service manual.
Dec 15, 2007 | Toshiba e-Studio 161 Copier Copier
980 people viewed this question
k24674
jasbo
jasbo
