Question about HP Compaq Business Notebook NX9010
Broken hp... So I shut my hp off this morning and when I tried to turn it back on... it doesn't go on. I heard it was in hibernation mode but I how do I get it off that? How do I get my laptop to turn on????
  • Desiree West May 26, 2008
    Okay so that didn't work... any more ideas????
  • indoplaya84 Mar 22, 2009
    no booting up.. no lights no noise... is there a way to determine if its the motherboard or something smaller like the power adapter? i replaced the adapter within the year and changed the RAM.. i put the old ram back to see if the ram was the problem but it wasnt.. any ideas?
    Novelist:
    Scholar:
  • 148 Answers
Unplug the power and remove the battery at the same time. Put the battery back in and plug it back in to power. It should come back up and maybe give you a message about "windows was not shut down properly" select "start normally" and it should be fine. From there, you will soon need to get it to a technician to check the logs to see what happened if anything other then a typical windows burp, it does happen. Good Luck.
Posted on May 26, 2008
  • Will Kibler
    Will Kibler May 26, 2008
    Is it booting up at all? are there any lights? if it boots at all you may have to delete the hibernation file. Let me know exactly what it is doing and I can help you from there. Also be sure the LCD is enabled by disconnecting any external monitor and pressing the "fn" key while also pressing the key that has a monitor icon on it, typically one of the 'F' keys.
Laptop wont go into hibernation when lid is closed
NO PC STATED
xp is a virus magnet , why run XP?
The hinge is a switch, ? and failed with hinge,
why not use XP power sittings, advanced, in control panel
why not just use the power button and shut it off.
the overheating is failure #3, and is packed inside full of lent. bad that.
in control panel make sure the power button is set to turn off
if you program the powe buttion to hibernate then you must use
XP start , shutdown feature to turn it off.
ever seen control panel. and power settings and advanced?
set the lid to do nothing, its broken so.....
then set the power button as you wish.
btw most XP are infected with virus or worse.
and hibenate will not work, getting hibernate to work in XP or any old XP is like a DREAM. all things must be perfect for hiberate work correctly , and all HP drivers installed, matching your exact PC.
or it fails. I never use hibernate. its a pain most times.
and can also fail to come out of hibernate.
use sleep mode its more Robust.
your PC is broken why not get it fixed?
https://h30434.www3.hp.com/
Apr 11, 2017 | Compaq Computers & Internet
I have old pc that worked for too long but after i bought new screen ( HP L1950 ) every time it says montior is going to sleep and some time it freezes forever and some time it says no signal but after i...
* check com cable all thru the video card socket,also check you video graphic card pci if its inserted properly,try to clean it first.
* might your pc is in Hibernate or Sleep mode
A power management mode that conserves power by powering down the system. In hibernate mode the current state of the system is saved to the hard drive, and the system will power down. When a user turns the system power back on, the saved information is read from the hard disk, restoring the last used settings. Hibernate mode is similar to sleep mode, however in sleep mode the power cannot be shut off.
go to control panel > power management and change or default the settings you wish.
Jun 08, 2011 | Computers & Internet
Dell 1737 laptop won't turn on (A/C or battery powered). Last night I tried for 15-20 minutes then it worked. This morning it didn't work again (from stand by mode). I held the power button to shut down...
you have a BIOS bug when hibernation , leave without battery for few days try to turn on with the charger, and if turns on go to the battery settings and disable the hibernation option, later go to dell website and update your system BIOS.
please rate me
Aug 13, 2010 | Dell Studio 1737 Laptop
Can HP dv2715nr hibernate instead of putting it on sleep mode?
It sounds like the hibernate feature is missing from the power options list. Click on start button, select shut down, and then hold shif or ctrl and stand by should change to hibernate.
Let me know how you get on.
Regards.
Mar 11, 2010 | HP Pavilion dv2715nr Notebook
Appears to be stuck in sllep mode, sr2020nx
unplug computer if necessary. Can also hold the power button in until it shuts off. Then you might want to to turn hibernation off in your power settings in your control panel.
Oct 25, 2009 | HP Compaq Presario SR2020NX PC Desktop
When I shut down my computer, I think that it is shutting down completly. All lights are off indicating that it is shut down. Then a small blue window will appear and will say "Entering Power Safe Mode"....
If you are turning off your computer by pressing the front panel power button, it is probably just putting Windows to sleep but not shutting the computer off. If your computer has Windows Vista, the default is to hibernate and not shut down even if you shut down through Vista. The "power save" message you see is coming from the monitor, which is letting you know it isn't getting a signal from the computer anymore but the power is still on. Windows will start up again from sleep mode if someone or something moves the mouse or presses a key.
The solution is to make sure the computer is actually shut down. In Vista you can do this by clicking the arrow near the power icon on the Start menu. This gives you the option of shutting down instead of hibernating. In XP, shut the computer down using the start menu shutdown option instead of the computer power button. Then the power will shut down completely.
Jun 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
Laptop stuck in quickplay mode
try starting in safe mode than exit hibernation and you may have to log in under administration user and log in as adminstrater you will find in the user account
log off is in the shut down option control screen
or
control panel open power options
requiring password after sleeping and also hibernation the same.
Mar 11, 2009 | HP Pavilion dv6000z Notebook
My acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
Hibernate mode
Press the power button it might flash
Apr 02, 2008 | HP Pavilion dv6000z Notebook
Need help
You are confusing Hibernation, where the RAM is written to the HDD and power is turned off without unloading the OS, with Screen saver (control panel - display).
Mar 18, 2008 | HP Pavilion a1120n (PX759AA) PC Desktop
HP Compaq Business Notebook NX9010 Logo
56 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
