Question about Bulova Watch
Need instructions for a puritan watch model PURO 6936
I have a Coleman digital watch. Four button. I replaced the battery and need to reset the time and date.
Click on your watch model number to open the instruction sheet below.
Your model number is located on the caseback of your watch
go here> http://www.gsi-usa.com/instructions/
Aug 16, 2014 | Coleman Mens Digital Dual Time Sport Watch...
I need instruction for a lifemax ladies watch
For Lifemax watch instructions, go to http://www.rnib.org.uk/shop/Pages/Category.aspx?Category=talking_watches
and select the model of Lifemax watch for which you require instructions.
When that product page opens, scroll down to find 'product instructions'. Click on that to open the instructions in a Word document (you will need to have MS Word or the free OpenOffice suite to read it)
Jun 02, 2012 | Watches
Hi i have an aviator watch avw7770G59 and i can't change the date ?? please help me by which button should i press
disculpe queria saber a que precio tiene el reloj aviator reloj_ caballero clave a v w 7 7 7 o g 5 9 y keria aber si me podrian vender el puro cascaron la caja eske ya teno la caja y la tapa
Jul 01, 2011 | Bulova Watch
I bought a invicta watch model number 6620 and i dont know how to change the day setting. It reads wed but i need it to be sat.
The Instructions for Invicta watches can be found here:
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
the instructions are organized by the functions of your watch , not by model number. Refer to page 6 of the pdf file to find the instructions for your model.
Mar 26, 2011 | Watches
Need instruction manual for ACCURIST GRAND PRIX watch - Model MS645 ...
Accurist do not list their instructions by model name but by calibre number on the back.
If you go to http://www.accurist.co.uk/acc-service.php and follow the instructions for identifying your watch calibre, you can download the instructions for your watch from the list given.
Feb 12, 2011 | Watches
Need instructions for armitron Model 20/1984
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Mar 27, 2010 | Bulova Watch
Need Instructions for new Baby-G Casio watch- model 300D
Follow this link: http://world.casio.com/wat/download/en/manual/ Enter module number and download instructions for your watch.
Rate me, plz.
Jan 06, 2010 | Watches
Puritan watch link removal
its sound simple enough but you will need to use a bit of force to budge the pin.
you will need
blue tack
punch
pin hammer
pliers.
Roll up the blue tack push onto flat surface , push the barcelet side on into the blue tack wthe arrows pointing downward.
insert the punch into the hole and tap with hammer.
do this until you have removed enough links then push a pin back into the bracelet and tap home withthe hammer.
Aug 25, 2017 | Lucien Piccard 26024 Wrist Watch
Can't change the time setting on my sports watch
Your Fossil Watches has four push button and one for winding button. the first button has mark of LIGHT , the below button is MODE ,,upper right START/STOP,,, lower is LAP/RESET. the center button is what they called it a CROWN to set crown is just pull it and you can set the hour and minute. the LIGHT button is the set button also, just press it for 15 seconds if dial flashes, then go to MODE button and choose what going to set, the START/STOP -- LAP/RESET is the scroll button you going up and down the number or on /off ,some model of chronograph the set is in the MODE button just press it long and if flashes it ok. and follow procedure what i said before. setting cannot damage the watch...
Regards;
VOTIT
DON'T FORGET TO RATE;
Jul 24, 2008 | Watches
Watch
You better prepare a plain cloth to avoid scratch a piece of jewelry screw and ponson pinch ,if you cannot secure a ponson, find a big needle or sharp nail,take your watch put a piece of cloth to protect from scratch,hold your watch firmly that cannot slipt.In the side of links,there is a screw marks, or pinch marks lock,if you see screw marks you should use the screw ,if pinch mark ,use the needle or the nail to punch out the lock and detach it ..Again punch it in so it locks or screw it in.That s all you do patswan...
hope this may help;
Regards,
VOTIT
Bulova Watch Logo
93 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
