Question about Garmin GPSMAP 178C Sounder GPS Receiver
I have Garmin, GPSMAP 178C Sounder,Why it can't receive signal,The History : When It was running normaly suddenly lost signal When I was in the sea,Sometime It was only get 3 level signal, it's not enough for GPS, GPS can't work, I hope you give me any good solution, thank....
SOURCE: GPS wont boot up
Use with caution: This will delete your user data on the unit.
Try a reset:
  • Hold QUIT pressed when turning unit ON (will delete waypoints, routes and tracklogs)
(This worked for me when I had a similar problem.)
You could try a master reset;
  • Hold Zoom-OUT + QUIT + NAV and power ON. Hold keys for 10-12 seconds.
  • You lose all almanac and temperature compensation tables (it reconstructs itself but takes time - several hours)
  • Be patient - it will take HOURS for the unit to recover
Fair warning: I have not personally tried the master reset.
Posted on Dec 16, 2007
  • 638 Answers
SOURCE: would like to buy a garmin gpsmap 178/178c owners manual
Contact Garmin and they will sell you one.
Posted on Apr 15, 2010
SOURCE: GPSMAP 178C Sounder GPS Receiver: My 178C will not stay powered up. I just replaced ...
I had the same problem with mine. It is caused by a crimped wire on the internal harness inside the machine. I opened it up and discovered that when originally put together 3 of the wires from the plug were crimped. One was broken off. The only way to fix it is to open it up, restrip the wires place a piece shrink wrap on before you solder it back and then make the shrink wrap flush with the back of the plug and heat her up. And, Voila... no more intermittent operation. Hope this helps? John
Posted on Jul 16, 2010
leethedeuce
  • 4472 Answers
SOURCE: my garmin gps 178c sounder
I assume your talking about the marine updater. All the steps are located here:
http://www8.garmin.com/products/marineupdater/
If you have any other questions let me know.
thank you,
Lee
Posted on Oct 10, 2010
SOURCE: My Garmin GPSMAP 178C screen backlight failed
Backlight problem: Remove the display, remove the light tube from behind the LCD. Buy a led panel from Ebay for around $5 and install it behind the LCD under the drfusing layers. Run the wires out to a 12 VDC source and there you have it.
Posted on Sep 15, 2011
Why does my screen blink all the time on my 178c sounder
check your power connection, if that is still good your unit may be dying
Jul 05, 2014 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin GPSMAP 178C not boot
can we download india map?if tell me how to download and install the map in my device Gm4300?
Nov 20, 2013 | Garmin GPSMAP 178C Sounder GPS Receiver
I have used the Gpsmap 178c for about 3 years now. Recently I have started be unable to find satelites, wass on or off. Once in a while it works. presently I get no satelites I would buy a new antenna...
Based on the problems I have seen with this unit the problem is the reciever circuit not the antenna, so you should consider a new unit, Garmin charges a fortune to repair these.
Sep 22, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
Jul 13, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
May 18, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin 178c won't find satellites
It would appear that your Garmin has no clue as to where it is on the planet. I think a trip to the owner's manual:
http://www8.garmin.com/manuals/GPSMAP178CSounder_OwnersManual.pdf
might be your best bet to help initialize your unit. The info on how to graphically initialize your Garmin can be found on page 5.
Hope this is helpful.
Good Luck!
May 04, 2010 | Garmin GPSMAP 178C Sounder GPS Receiver
Garmin 178c turns off on it's own.
Hi
Sounds very much like the wiring plug connections in the back, always overlooked but so important that connections are tight and contacting.
Jul 06, 2009 | Garmin GPSMAP 178C GPS Receiver
Garmin GPSMAP 178C Sounder GPS Receiver Logo
55 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
