Question about Cell Phones
How do I record a personal greeting for my uniden dect 6.0 phone
Set greeting on uniden dect 6.
Select the model of your Uniden DECT 6.0 system from the list beginning at http://www.uniden.com/scat/dectphones_mnl to download a copy of the manual.
Jan 19, 2014 | Uniden DECT 6.0 Cordless Telephone...
I have the uniden dect 6.0 3 handset. I lost my manuel and do not know how to record my answer message
Which specific Uniden DECT 6.0 phone do you have? There are a number of them. Uniden has the manuals available here: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . Phones are listed in alphabetical and numerical order.
If the answering system is off, turn it on before proceeding to the following steps.
If you are at home, there are usually two methods to access the answering system. Some Uniden phones let you set the outgoing message from the base or the handset. Others will only let you set the message from the handset. (Calling in remotely is more complicated.)
To access the answering system menu from a handset, on some models, push the Mute/Messages button. Then let your current message play or press 5 to stop the recorded announcement. Then either use the up/down arrows to select Record New Greeting (or the number that matches the sub-menu item). It's number 8 on the DECT1480. Then wait for the prompt (tone or "Record Greeting") and then speak into the handset clearly. Press 8 to stop recording and press End to save the message. Press 6 to select the outgoing greeting if a default greeting is available.
On other Uniden DECT phones, press Menu and go to Ans Setup. Then choose the line for the greeting (if it's a multi-line phone) and then select Record Greeting. Press Start, wait for the prompt and then press Stop when done. Press Stop again to save the message. If there is an optional pre-recorded greeting, use the Greeting Option submenu to select the greeting to play. (This applies to the DECT4086.)
From the base, you'll do something similar. However, you should stay about 9" from the microphone while recording. Messages can be between 30 seconds and 3 minutes 30 seconds for most systems.
I hope this helps.
(recording a new greeting during a remote call can be done but consult the manual for details.)
Dec 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
How do i record a personal message on the answering machine of my Uniden DECT1480?
Record a Personal Greeting
1. Access the answering system from any handset. Wait until the system finishes its announcements, or press 5 (Stop) to skip them.
2. Press 8 (RecNewGreeting).
3. Wait for the system to say "Record greeting," then begin speaking.
4. When you're finished, press 8 to stop recording. The system plays back your new greeting.
5. To keep this greeting, press End. To re-record it, go back to step 2.
Or you can get the manual on the link below page 17.
Good Luck
Nov 08, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do i change my vociemail message for the Dect 6.0?
Reording a Personal Greeting Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 8 to start the recording. The system announces, "Record greeting." Begin recording after the announcement. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recorded greeting plays back for you.
Selecting a Greeting Once you have recorded a personal greeting, the phone automatically switches to your personal greeting. You can also switch back and forth between the pre-recorded greeting and your own greeting at any time. Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 6. The system plays the current greeting.
To keep this greeting: Do nothing.. To switch to the other greeting: Press 6 while the system is playing the current greeting. Each time you press 6, the system switches between the pre-recorded and the personal greeting. The last greeting you hear is used as the current greeting.
Deleting Your Personal Greeting You can delete your personal greeting from the base. You cannot delete the pre-recorded greeting. Press /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode. Press 6. The system plays the current greeting. Switch to your personal greeting if necessary. (See the previous section to switch the greeting.)
While the personal greeting is playing, press 4. The system announces "Greeting has been deleted," and switches back to the pre-recorded greeting.
Oct 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
I have the Uniden 6.0 Dect 1580-3 but there was ...
43
43
h
e
s
t
e
m
Recording a Personal Greeting
Your.answering.system.comes.with.a.pre-recorded.outgoing.message.or.greeting.that.plays.when.you.receive.a.
call:.“Hello,.no.one.is.available.to.take.your.call..Please.leave.a.message.after.the.tone.”.You.can.record.your.own.
personal.outgoing.greeting..Your.recorded.greeting.must.be.between.two.seconds.and.thirty.seconds.long.
1).Press. /MUTE..The.system.announces.the.number.of.new.and.old.messages,.then.starts.to.play.the.
messages.unless.it.has.no.messages..
2).Press.5.to.stop.the.announcements.or.message.playback..You.will.hear.intermittent.beeps.indicating.that.the.
system.is.in.the.command.waiting.mode.
3).Press.8.to.start.the.recording..The.system.announces,.“Record.greeting.”.Begin.recording.after.the.
announcement..
4).When.you.finish.recording,.press.8.again.or.press.5..You.will.hear.a.confirmation.tone,.and.your.recorded.
greeting.plays.back.for.you.
Once.you.have.recorded.a.personal.greeting,.the.phone.automatically.switches.to.your.personal.greeting..You.can.
also.switch.back.and.forth.between.the.pre-recorded.greeting.and.your.own.greeting.at.any.time.
3).Press.6..The.system.plays.the.current.greeting.
S
e
tt
in
g
U
p
t
h
e
A
n
sw
e
r
in
g
S
y
s
te
m 4).To keep this greeting:. Do.nothing.
To switch to the other greeting:.Press.6.while.the.system.is.playing.the.current.greeting.
5).Each.time.you.press.6,.the.system.switches.between.the.pre-recorded.and.the.personal.greeting..The.last.
greeting.you.hear.is.used.as.the.current.greeting.
You.can.delete.your.personal.greeting.from.the.base..You.cannot.delete.the.pre-recorded.greeting.
3).Press.6..The.system.plays.the.current.greeting..Switch.to.your.personal.greeting.if.necessary..(See.the.previous.
section.to.switch.the.greeting.)
4).While.the.personal.greeting.is.playing,.press.4.
5).The.system.announces.“Greeting.has.been.deleted,”.and.switches.back.to.the.pre-recorded.greeting.
May 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
I would like to know how to record a greeting, Uniden DECT 6.0
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest that you select it from the list beginning here to download a copy of the manual.
Mar 01, 2010 | Uniden DECT 6.0 Cordless Phone ID
How do I change the outgoing message on my Uniden 6.0 1580??????? Digital answer machine.
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a
call: “Hello, no one is available to take your call. Please leave a message after the tone.” You can record your own
personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the
announcement.
The system announces “Greeting has been deleted,” and switches back to the pre-recorded greeting.
Cheers!
Feb 14, 2010 | Uniden DECT 6.0 Cordless Phone ID
Info to change message on telephone dect 6.0 telephone Uniden dect 6.0
Your answering system comes with a pre-recorded outgoing message or greeting that plays when you receive a call: “Hello, no one is available to take your call. Please leave a message after the tone.”
You can record your own personal outgoing greeting. Your recorded greeting must be between two seconds and thirty seconds long.
  1. Press /mute. The system announces the number of new and old messages, then starts to play themessages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that thesystem is in the command waiting mode.
  3. Press 8 to start the recording. The system announces, “Record greeting.” Begin recording after the announcement.
  4. When you finish recording, press 8 again or press 5. You will hear a confirmation tone, and your recordedgreeting plays back for you.
  1. Press the /mute. The system announces the number of new and old messages, then starts to play the messages unless it has no messages.
  2. Press 5 to stop the announcements or message playback. You will hear intermittent beeps indicating that the system is in the command waiting mode.
  3. Press 6. The system plays the current greeting.
Jan 06, 2010 | Uniden DECT 6.0 Cordless Telephone...
I am unable to record my message on my Uniden DECT 1580 phone. It tells me to go to command 8:RECNEWGREETING. My question is where the hell do I find command 8?? Jesse
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Press /mute on the handset. The system announces the number of new and old messages, and then starts to play the messages unless it has no messages.
You will hear intermittent beeps indicating that the system is in the command-waiting mode.
Press /mute.
Oct 30, 2009 | Uniden DECT 6.0 Cordless Phone ID
Cell Phones Logo
356 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
