Question about KLH KL2400 Tuner
My remote for a KL-2400 receiver has died. Where can I get another one? Or what kind of substitute can I get?
I read your answer for the display receiver problem and was correct. I have an old receiver model Kenwood VR615 5.1 with remote # RC-R0621 I was wondering if you knew were I can get an original ...
sorry but I can recommend substitute remote since The original remote (VR615) is no longer available product from
the manufacturer.
Pls visit either of the URL below to get one ,if you wish..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
http://www.dvdremotecontrols.com/Mfrs/Kenwood/KenwoodAudio/RC-R0626.htm
http://remotes.com/store/kenwood/vr615.html
All Remotes come with a One Year Money Back Guarantee
The remote below is the recommended substitute remote. Substitute remotes
provide similar functionality to the original, although there may be minor
differences.
The substitute remote will work TUNER/RECEIVER functions only.
Jul 03, 2011 | Audio Players & Recorders
What type of the remote control have avr-2400 and how i found this?
Hello. call 1-800 remotes
tell them your brand and model and they will ship you a denon remote for your avr. Joe
thanks for choosing Fixya!
Feb 10, 2011 | Denon AVR-2400 Receiver
Manual & Remote controls
My remote control got problems. It's hard to find another in my country (VietNam). So, would you kindly advise me which kinds of remote control I can use as a substitute (equivalent) for my YAMAHA DSP-A1 Receiver. Thank you for your support
Jan 06, 2011 | Yamaha DSP-A1 Receiver
Model KLH KL-2400 Reciever keeps popping fuses. Resistor in power input ckt is color coded YellowVioletYellow Gold for 470 Ohms 5% Tol. However this resistor reads 370 Ohms. Resistor needs replacement?...
470.000 ohms not 470 ohms 470k ohms at 5% tol. either the main p.s. diodes are shorted or the output and driver transtors are shorted causeing the fuse to blow....
Nov 17, 2009 | KLH KL2400 Tuner
First of all a resistor color coding of Yel-Vio-Yel is 470Kohms not 470ohms. You are probably reading some stray voltage in the circuit. Yes, both NEG terminals of the speakers are common. Usually a receiver that blows the main fuse has a power suplpy problem. Check the recifier diodes for shorts. Other than that, the output transistors may be shorted.
Check those out and post the results.
Dan
Nov 17, 2009 | KLH Audio Players & Recorders
Need remote control replacement for a KLH Rec/Amp kl2400
Yes, it might not be the original one but there are
replacements available in your nearest electronic
supply stores.
Sep 21, 2009 | Audio Players & Recorders
Add su bwoofer to KLH 200
the subwoofer i have, a polk, connects directly to the right and left speaker lines of the klh2400.
i then connect my stereo left and stereo right speakers to the subwoofer.
essentially, the subwoofer becomes a middle station between my speakers.
make sense?
Jun 06, 2009 | KLH KL2400 Tuner
KLH KL2400 Tuner Logo
133 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
