Question about Weiser Lock Powerbolt 1000 Lock
Weiser Lock keyless entry alarm is goes on and off randomly
    Problem Solver:
  • 17 Answers
Same here. I have found that unplugging the keypad connector relieves the beeping problem, but of course this isn't a solution except to suggest that the keypad is the culprit. Perhaps a replacement keypad is needed? Contact their customer service - http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Posted on Oct 05, 2010
How do I reset keyless door entry that is in lock out mode
Viper Keyless Entry Systems
https://www.viper.com/car/keylessentry/
Viper is the industry leader in keyless entry systems. Add the convenience of keylessentry to virtually any vehicle - even vehicles without power door locks!
Alarms, Remote Car Starters, Keyless Entry & Locks - JC ...
www.jcwhitney.com > Audio, Video & Electronics
20 out of 32 products in Alarms, Remote Car Starters, Keyless Entry & Locks ..... ofKeyless Entry & Car Alarms allow you to lock and unlock power door locks.
How to program your keyless entry keypad - Ford Ownerhttps://owner.ford.com/.../locks.../how-to-program...Ford Motor CompanyDiscover how to lock and unlock your doors and how to program memory settings that will adjust seats & mirrors for each driver.SecuriCode™ Keyless Entry Keypad - Ford Ownerowner.ford.com/.../locks.../securicode-keyless-entr...Ford Motor CompanyLearn how to set a 5 digit SecuriCode on the Ford keyless entry keypad. ... Sign out. Register/Sign In · Your Vehicle. Service & Maintenance. Service & .... vehicle's SecuriCode keypad to lock and unlock your doors without having to use a key. ... Thekeypad will go into an anti-scan mode if you enter the wrong code seven ...How Programming Your Keyless Entry Can Make ... - Ford Life
Jan 08, 2016 | Cars & Trucks
How do I enter new code?
[PDF]Quick Reference Installation & Programming Manual
www.weiserlock.com/.../electronics/smart...
Translate this page Weiser Lock25605-02 Weiser SmartCode Manual. Program. Button .... Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into .... anyone withaccess to the power board can change these codes, you must restrict access ...technical means, or evaded by entry elsewhere on the property. No lock.
Nov 26, 2015 | Weiser Lock Locks & Locksmithing
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Partial draw back of bolt on the 1st attempt with keyless entry. 2nd subsequent input of the 4 digit code pull the bolt to the unlock position. Have changed the battery, looked for tight fit where the bolt...
I understand that you've already checked for any mechanical binding within the lock and between the lock and the strike plate--(does this problem occur when the lock is cycled when the door is open?)
I'm including a link to the troubleshooting page for your powerbolt:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
If you don't find a solution here, although the lock is beyond its one year warranty, I'd still contact Weiser Customer Service (preferably by phone) and appeal to them to help you troubleshoot or replace your lock. Here's the contact information:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
May 08, 2011 | Weiser Lock GED1460X GED1460X3BR Lifetime...
My parents have a keyless entry and want to change their code. But don't know how. Do you have insturctions.
There is a learn button under the back cover where tha batts are. Press and release enter your code then press release. Test to ensure it is changed prior to shutting the door!
Feb 25, 2011 | Weiser Lock Powerbolt 1000 Lock
Key pad freezes up and unit goes into an alarm mode. My unit is only a few months old. Thanks Marc
Weiser has a one year warranty against electronic problems and a lifetime warranty for mechanical and finish problems with their locks. Contact them from this link:
Nov 23, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
My touchpad electronic deadbolt has been working fine but now, when I enter the code, it beeps for each entry number and then emits a constant blast for 10 seconds and goes dead. I've changed the...
Powerbolt is beeping
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Oct 28, 2010 | Weiser Lock Powerbolt 1000 Lock
2001 subaru impreza WRX unlocking doors with key
usually after opening the door you can deactivate the alarm by pushing th unlock button or simply insert keyy in ignition and turn it on.
Aug 13, 2009 | 2001 Subaru Impreza
Keyless entry stopped working on 05 cobalt now i have to unlock door with the key and when i do that the alarm goes off. Help
Lock all the doors from the inside (with all the doors closed), unlock your driver's door by manually lifting the lock, then press it back down after you are out - this will prevent the alarm from sounding when you use the key to unlock the door.
Aug 02, 2008 | 2007 Chevrolet Cobalt Coupe
Weiser Lock Powerbolt 1000 Lock Logo
120 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
