Question about White Sewing 1866 Mechanical Sewing Machine
I dont know how to thread the machine or thread a bobbin. and i've really been wanting to use it! :D
    Genius:
  • 1,788 Answers
Download your manual for free at www.singerco.com. Just go under customer support and put in 1866 and voila, you can download it.
Posted on Oct 01, 2010
  • Mary Dunn Oct 01, 2010
    That drawing in your manual is really hard to figure out, I have been sewing for 50 years. How about going to www.sewusa.com and the threading diagrams, try Singer 1852, I think that is pretty close to yours. If that is close enough keep looking under that site to find one really close. I am shocked at how hard it is to see the parts. Good luck, feel free to contact me because I would be glad to help you for free.
Bernina 1000 Special sewing machine won't pick up bobbin thread
try tuning the bobbin the opposite way in the bobbin case.
Apr 03, 2013 | Sewing Machines
Bobbin case catching thread
I believe that you are talking about the assembly that holds the bobbin case in. The bracket that holds the bobbin case in must be adjusted to allow the upper thread to slide by. Check if the thread will go by this area without "hanging up" while rotating the hand wheel. Also check your bobbin to make sure you have the right one. If it is too high or wide it will definitely be a problem.
Apr 17, 2017 | Janome SEW MINI Mechanical Sewing Machine
Two threads coming from bobbin?
try adjusting the top thread tension-one number or letter less, then
sew on a piece of the scrap fabric if you have any. to see if that helps
try changing the needle
make sure the bobbin is turned the right way in the bobbin case, I
know this may sound crazy but it can hinder the sewing, I was sewing
a skirt the other night & I turned the bobbin the wrong way & inserted
the bobbin into the bobbin case & it didn't work good,, I took the bobbin
out of the bobbin case & had multiple threads. so I had to clean the mess up & turn the bobbin the opposite way & the machine worked
just fine
Oct 03, 2012 | Singer 3116 Simple
Juki, DNU-1541S: thread was not picking up the bobbin thread. The hook shaft is not moving... After trying to move the needle in a reverse motion... Now the hand wheel will not move it is frozen in place.
You've got something binding in the bobbin area. Open up the entire bobbin/feed dog area plates so you can really see. Get your magnifying glass out and really examine the area for threads wound around things. DO NOT unscrew anything if you can help it. If you unscrew the wrong thing you can knock it completely out of time. (which may be why couldn't get the bobbin thread up anyway.)
If all this is intimidating to you... take it for repair.
Sep 09, 2012 | Juki DNU-1541 Mechanical Sewing Machine
I THINK I've followed every instruction and tip regarding threading my machine and bobbin, but the needle won't pick up the bobbin thread. It just comes up as it went down, without the loop fr
Hi. Usually this is due to a wrong needle or your needle not being set correctly. Do you know if your patcher is a 29k? or?
http://www.parts.singerco.com/IPinstManuals/
There are various manuals at that link... hopefully your patcher is there. good luck
Jul 24, 2012 | Singer Sewing Machines
Loose boobin winding
You need to ensure that the thread is going from the thread spool at the back of the machine, through the eyelet, then around the silver tension disc on top of the machine, then to the bobbin when you are winding it. Also, pull the thread tail up through the hole in your bobbin to start and hold the tail so the thread starts to fill smoothly and doesn't loosen.
I've marked the disc in red on this image
Please read my Tip on bobbin winding; its really important to get a good wind and you can add more tension yourself by applying gentle pressure to your thread spool on the back pin as you wind off it.
Link is http://www.fixya.com/support/r10598580-winding_bobbin_correctly
The stopping when full is possibly because your bobbin is winding unevenly but I never run it until it stops itself anyway, and do the winding at 3/4 speed, not flat out. You want a really smoothly tensioned even wind onto the bobbin so your thread comes off the bobbin when stitching with even tension, not stretched, then loose.
Hope this helps you with your problem.
Dec 14, 2011 | Elna Quilter's Dream 6003Q
Bobbin placement we cant get in correctly and it wont pick the bobbin thread up. when trying ti sw it bunches in knots and breaks sometimes
Sounds like the bobbin may not be the right one for your machine. YOu haven't said what make and model this is but you should check your manual or online to ensure you have the correct bobbin for it. I've seen Elna's with Singer bobbins in, they'll stitch okay but then tension problems occur, you need to have the right one for your machine. (if you aren't sure, try looking at www.sewusa.com or www.sewingpartsonline.com to find the bobbin described for your machine.)
Also metal bobbins can get squished if they've been stood on, so have a good look at it and make sure the bobbin is in good shape and looks okay.
Now take the thread off it and rewind a fresh bobbin making sure you've got tension on the thread the whole time and that the thread winds onto the bobbin very smoothly and evenly. This is something that is not emphasied in sewing machine manuals but makes a HUGE difference. Think of your garden hose coiled onto the hose reel. If you wind as the hose wants to go, it goes onto the reel all over the place, then jams up and you can't get it all on there. Look at how a thread spool is wound, the factories wind the thread in a very neat sequence and you want your bobbin to look the same. So always use the tensioner on top of the machine to take the thead around when winding the bobbin. If you don't have one, then put tension onto the thread spool the thread is coming off to ensure the thread runs off at a constant tension and speed.
Carefully watch the thread as it goes onto the bobbin and nudge it with your fingertip to get it to fill evenly top, bottom and middle of the bobbin. Stop when 3/4 full.
Now put bobbin to bobbin holder ensuring that it goes in the right way, always the thread should come off the bobbin and reverse direction in a V shape. Click the thread into the tension spring. Double check it is in there and then thread up the rest of the machine and test sew.
THere is some good trouble shooting tips at www.sewusa.com so this might help you also.
Sep 14, 2011 | Sewing Machines
I don't know how to thread the machine and how to put in the bobbin. I have a White 1410 machine.
I don't have a solution, but I wanted to thank GUEST for the drop of oil solution - I was about to buy a new machine and throw out the one I have ( 3 years old!) because it wouldn't wind up thread on the bobbin. You've saved me money and futher frustration :-)
Jan 06, 2010 | Sewing Machines
Dont know how to use the sewing machine so how do i thread
well!I If you buy a new sewing machine it has a manual to guide you in any brand.But if buy a used one sometime it doesn't have a manual, you didn't mention the type of sewing machine you want to use any how if you have a mechanical sewing machine it's better to start on it.First you must know and must familiarize the significant part of machine and important usage of them,I'll just mention the most usage part at start.Putting thread in bobbins first there is bobbins winder where thread was wind,draw thread from spool through bobbins winder tension disc located at top of machine.wind thread around an empty bobbins serveral times then,place bobins onto bobbins winder shaft with thread wound on bobbins clockwise sometimes this is located at top right side a shaft coupled to circular rubber touching handwheel perpendicular sometime it was located at right side front of machine near handwheel.Release clutch by pulling handwheelor rotating pivot wheel counterclockwise at the center of handwheel whlle holding freeze the handwheel tigh in order to disingage the motion of handwheel from mechanism of machine.
Mar 11, 2009 | Sewing Machines
Elna sewing machine
Amy,
did you solve the problem with your Jubilee?
I would suggest that the problem may be not holding the two threads at the back of the needle plate with starting each new seam. Elnas really need you to hold the threads, don't let the tail get caught and pulled back into the bobbin holder area. Once you have one jam, you'll have minute threads you maybe can't see caught under the ring guard (black bit) and the jamming will keep happening. Also, make sure you only use Elna bobbins always with holes on the top.
If you've still got the Jubilee and are having issues with it, feel free to add more info, the other contributors comments about the bobbin being faulty are valid but I dont think your machine is worn out, just jamming. You can remove the bobbin holder yourself and clean underneath it and once you've done it once, and know how to line it and the ring guard back up, its pretty easy and will ensure that the bobbin area stays clean.
Mar 11, 2008 | Sewing Machines
White Sewing 1866 Mechanical Sewing Machine Logo
100 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
