Our heater starts out good but sometimes the fan turns backwards and wont do anything. then you can turn it off and back on then it spins the fan the right way. it will light and burn for a few seconds and quits running with the flame light blinking. and the fan motor gets hot. its a reddy heater 125t. it runs off either number 1 or 2 kerosene or number 1 or 2 diesel.
  • 674 Answers
A bad capacitor can cause the fan to act like yours. I would check that first.
Posted on Oct 01, 2010
Why would a torpedo heater fan turn backwards? every time I start my all pro 115,000 heater the fan starts to spin counterclockwise and the heater wont ignite. But when manually spin the fan blade clo
If the fan has a 'run' capacitor, in rare cases, a faulty capacitor will cause a single phase motor to start in reverse. In most cases a faulty capacitor will cause the motor to only hummmm and not start or start slowly running the right direction then overheat and shut off.
See if there is a capacitor, change it first. If that doesn't fix it it sounds like its time for a new motor.
Nov 18, 2014 | Heating & Cooling
Car battery put in backwards, car wont start
It sounds like you have fried your alternator ;(
Jun 19, 2012 | 2003 Volkswagen GTI
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
The fan on my heater wont turn on
First make sure you have power to the motor. Then check to see if fan turns freely.If not a good cleaning on the fan or squirrel cage may help. If fan turns freely then set thermostat to call for cool and manually spin fan. If it runs then you will probable need to replace the start capacitor. If it does not run at all and you are sure it has power to the motor then you need to replace the motor. Best of luck and thank you.
Jul 21, 2011 | Heating & Cooling
Electric fan motor sometimes wont start. It tries
Your unit is a year old and sits around most of the year. Disassemble the unit to get to the fan motor. When you can see the bushings on both ends of the motor shaft use a light oil such as 3-in-one to lubricate the bushings. Rotate the fan blades for a while. Relubricate. Continue until the motor turns freely. Clean up any oil spills. This should solve your problem if you haven't damaged the motor by trying to run it with dry bushings. The lubrication should be done at the end of each season and at the begining before the unit is put in service. Let me know if I can be of anymore help.
hardrocko
Thanks for using FixYa
Feb 25, 2010 | Heating & Cooling
Heater wont start or runs intermitently
begine with a test of the motor first,do this with a test light,under the glove box is your blower motor,turn the key on and heater fan and defrost,now ground the test light to a good ground and test the wires to motor,if you have power replace the motor.
Dec 15, 2009 | 1994 Chevrolet S-10 Blazer
Fan runs backwards forces flame to blow back into heater instead
cracked heat exchanger not cheap replace unit ur motor just doesnt change rotation on its own
Jan 13, 2009 | Reddy Heater RLP100 Portable Forced Air...
MY HEATER FELL OER BACKWARD AND NOW ITY WONT HEAT . THE FAN WONT COME ON...NOTHING. WHAT?
Just needs a little TLC: We just bought this heater at Goodwill and it's still in very good condition. The fan wasn't working either, but there was definitely heat. So we took it home and took it apart just to the point where we could give the fan a good q-tip/tweezers cleaning (lots of dust was in there) and then used Penzoil motor high temp grease via a toothpick on the spinning fan axle and voila! The fan works now and doesn't make anymore noise either. Just a note: this is a tedious task that requires an extra hand to help hold things in place since you can't take the fan out completely.
Nov 20, 2008 | Marvin W.B. 3150 Convector Heater/Fan
HP Pavilion dv6915nr problem
if it's still under warranty bring it back to where you bought it so they can replace your defective fan
Oct 21, 2008 | HP Computers & Internet
Rumor phone problem help!!
My phone just started this after 10 months! It does the same thing it had black and white strips and i turn it on and i still have texts coming it but cant see anything and then sometimes you can actually see stuff but the screen is totally backwards.
Sep 26, 2008 | LG RUMOR Cellular Phone
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
