Question about Cell Phones
My phone died.. went home to charge it and it asked me for a PUK phone... I am realy mad i just got this phone not even 2 weeks ago and its been 3 days since than
CellKiller
  • 9 Answers
SOURCE: blank screen on Nokia 6085
Frist U Change LCD Second Change Display Strip Third Change LCD IC  In Last Flash Phone.
Posted on May 09, 2009
webmaster21
  • 803 Answers
SOURCE: Need PUK code, T-Mobile SIM is deactivated (cancel line)
  1. Contact your cellular service provider and have it provide you with a new SIM card. Let it know your account and phone number so that it can transfer your phone service to the new SIM card.
  2. Check the manual that came with your phone to see if the SIM card is found in the standard location beneath the battery or if it's located somewhere else.
  3. Turn your phone over and remove the back plate by pushing down on the slide panel and sliding it away from you. Remove the plate and then put your finger in between the battery and the side wall. Push the battery away and pull it out of the phone.
  4. See if the SIM card has a metal covering. Remove the covering if there is one present and then pull the SIM card out.
  5. Place the new SIM card in the card holder and then snap back down the metal covering. Make sure to place the card in the same direction as the old card or your phone will not be able to read it. Put the battery back in and then place the back panel back on. Power on your phone to ensure that the SIM is working properly.
WARNING
Do not enter in any codes if the phone asks for a "PUK" or "SIM lock" code. Contact your cellular provider immediately and request the code because if you enter in an incorrect code, your SIM card will permanently deactivate itself.
Posted on Sep 24, 2009
SOURCE: PUK Code problem
i need a asda puk code please
Posted on Dec 18, 2009
  • 1416 Answers
SOURCE: Nokia e63 won't switch on or charge
hello,
this have nothing to do with your phone battery and the phone charger
from your statement what you need to do to fix up the problem is that you have to make a change of your phone charging port this is well the problem is from
the charging port bad
dole it will give a sign that it charging but the same time it will discharge the power and this can cause a damage on the battery bass on constant charging
what you need to do is that you are to make a change or replace the port with a better one
if you can not do the fix up your self then you will have to take it to a very good phone work shop around you to do the fixing then your phone will work fine again
thank you .
Posted on May 01, 2010
  • 49 Answers
SOURCE: My safelink phone is asking me for a puk code..
Get PUK from Service Provider...
Posted on Nov 10, 2010
I went down to ur stor and paid my bill a week ago that same day it die. when i turn it on it asks for a puk code, what is that, how do i get it, i havent used it for the whole week.
the PUK code is provided by the service provider on proof of ownership of the account
it is a code that stops a phone from being operational after the entry code has been applied incorrectly too many times.
Jun 12, 2015 | ZTE Cell Phones
Check Charging system light illuminates, all electrical shuts down and engine still runs on 2004 Ford Expedition 5.4l until battery dies. The opposite has also happened with the engine shutting down and...
Try replacing the "convinence control module" and bad board can cause all elec issues explained and also cause engine to cut out and other things but that is where I would start, hope this helps-
Nov 29, 2013 | 2004 Ford Expedition
I purchased the I phone 3 abt a week ago No damages no drops the phone as I was charging it which it had died completely when I tried charging it charged and showed 100 percent charged but the light...
Your cell phone or battery is faulty. I suggest you return the cell phone to the supplier/chop for repair or replacement as it will be under warranty.
Dec 21, 2012 | Cell Phones
Solutions c414r can't turn on only charges
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 08, 2012 | Cell Phones
Bought a new samsung wave 3 weeks ago went to charge it would not switch on again left battery out for 1full day it then powered up used it for another day or 2 went to charge it same problem.went back to...
Check the water damage indicators on the phone and battery. They are white stickers, and they will turn red if they have gotten damp or wet. Be aware that some phones can get water damaged from condensation, or being in a moist environment like a bathroom.
If the damage indicators are clear, they cannot prove that it has damage and you should take it back and talk to someone else.
Mar 02, 2011 | Samsung Cell Phones
Gud day! im fred, i just bought my samsung s5560 3months ago and i decided to activate the phone lock code. i change the default password 3 times but last week i change it again but unfortunately i forgot...
Hi
This what to do to solve your problem.
Enter the wrong code three times and it will request for PUK code.
Get the PUK code form the back of your starter pack or call your service provider to give you your PUK CODE.
Enter the PUK code and phone will ask you to put a new password.
Put your new password and the phone will unlock.
Good luck.
Sep 02, 2010 | Cell Phones
I own a 1999 altima & it won't start. It died a few weeks ago and we thought it was the alternator but when we looked it needed a belt replaced so we bought the belt & it started right up. I was...
yes get a new battery,,the old one probably,cant hold a charge,,then have you alt ck out to see if it is charging,,the car will run on the battery,,until no juice is left,,alternator recharges the battery,,
May 15, 2010 | 1999 Nissan Altima
Please give me puk code of my airtel sim
Hi everyone
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1) If you still have your packet that your Sim Card came in, you should find your PUK number in there, if you don't have the packet, please read bellow.
2) You must get a phone that is on the same network as your phone and call the networks Customer Care and ask them for your PUK number, they will ask you for your phone number, then they will tell you your PUK number. Once you have done this, you will be able to reset your Pin number so you will be able to go into your phone again.
Please also remember to give this solution a FixYa! rating if it helps you.
Kind regards
Dustin Ellse
Sep 28, 2009 | GE Security Simon 3 Wireless Home Security...
Asking for the PKU Code Where do i get this number
Finding a PUK (Personal Unblocking Key) number is not tough job. To find a PUK code all you have to do is call up on the customer care number and ask them to help you with the issue. Before they provide you the PUK code, they will ask you several questions. You need to give them the appropriate information. Customer care of your service provider are the only source from which can give you the PUK code.
At the time when you enter a wrong pin number three times. The phone asks you for a PUK number. The PUK code is generally eight digit number This PUK number is an unlocking code which helps you to unlock the phone and use it. If you enter a wrong PUK number 10 times than you simcard gets rejected. Then you will have to but a new simcard. It might happen that your phone might ask you for PUK2 after you enter your PUK number.
Aug 15, 2009 | LG Vu CU920 Cellular Phone
Puk number for at&t
The PUK code is (in my case) a an 8 digit number that I must enter to make the phone operable after someone (me) trys to enter my password and fails too many times.
I ran into this a while back before Singular became AT&T. I was locked out and I called Cingular and told the tech my phone was asking for a PUK code. I had to prove to him who I was somehow, I don't remember now how I did that. Maybe with my latest bill or something. Anyway he finally told me the numbers to enter. I wrote the numbers down first and then entered them. I've had to use them a couple of times since to get back in after I've locked myself out. It stays constant once you get the code. I have checked my phone under the battery and under the memory chip and these numbers are nowhere to be found on the phone. I SUGGEST YOU PUT A RECORDER ON YOUR PHONE OR HAVE SOMEONE LISTEN IN AND WRITE DOWN THE CODE WHEN YOU CALL AT&T. IT MAKE ME MAD THAT I OWNED A PHONE BUT AT&T KNEW A SECRET CODE TO MAKE IT OPERABLE. This is however a good feature though. I have my phone password protected so if I lose it and someone finds it they can only use it until they turn off the power one time and then they will get locked out and it will ask for the PUK code. Good luck, call AT&T and remember being nice will get you somewhere more then likely.
Dec 27, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Cell Phones Logo
12 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
