Question about RCA P52926 52" Rear Projection Television
P61927 I have a problem with letter colors seperating and the screen dips in the center.
  • 927 Answers
It sounds like you have a convergence problem. Go into the customer menu and attempt to adjust, if that doesn't work. then you will further service. There are at least 4 different areas of concern. Call a factory authorized service center, but try unplugging the tv from the a/c outlet for 5 minutes, first. GOOD LUCK.
Posted on Jun 01, 2008
I have laser printer hp 3525 and printer don't mix colours properly so letters are to be printed green the yelow color print seperate and the blue seperate ,so the the print come with two letters as if...
> go to menu, apply set of default setting, then check..> go to menu, device setting,quality,calibrate color,calibrate now.. printer performs color calibrate, after completion, check the print quality. I hope it will resolve the issue.> if above said advises are not resolved the issue mechanical adjustments has to done which is not suggestible to the users.. only professionals can perform the activity.
Oct 05, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
RCA P61927
You are describing a convergence issue. Rear projection CRT sets use THREE separate color 'guns' that need to be aimed properly every so often, sometimes every month, sometimes once every year, but usually when its moved. Convergence operations are typically a user serviceable function and the process can be started from the menu.  If you have tried doing the user convergence and it is still a bit off you will need to get it to a repair technician that can either fix the power supply or mechanically align the guns.  In my many years of TV experience, rear projection CRT's are typically discarded for two main reasons; either the power supply is causing convergence issues or the blue gun is dull or dead. Either way if you cannot perform a convergence yourself you are looking at $200+ in repair and parts. I would suggest finding a local television repair technician, not many left I know, and get a quote.
May 26, 2008 | RCA P52926 52" Rear Projection Television
Have a p61927 rca 61" big screen - chassis ptk195m2 - picture bows in at top/bottom, color overlaps- thought it was stk730-130 on convergence board but don't see it, is it located on the back of board ?...
I believe that is on the back of the convergence board. What makes you suspect that particular switching regulator out of curiosity? It may very well be, but just wondering how you pinpointed it to that.
Thanks
Tim
Oct 01, 2010 | RCA P61927 61" Rear Projection Television
Picture is not centered on screen slightly to the RT. How to center?
Go into the menu and there should be some settings like H position and V position. You want to change the V position, IIRC.
Aug 09, 2010 | RCA P61927 61" Rear Projection Television
My boyfriend was bringing our new 60 inch television home. he put a tarp over it and it scratched the screen. what can we do???
There is not much you can do besides replace the screen. Go to www.encompassparts.com There are 2 screens together on the front. The outside screen is the lenticular sceen and the inside screen is the fresnel screen. Thanks
Oct 29, 2009 | RCA P61927 61" Rear Projection Television
Colors seperate and picture bent
THIS is a convergens problum .pls. prees menu key and see convergence menu select and see cross line on center the screen select one by one colour line to meching and cross line is white see the pictur is ok.
Oct 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Color seperation and red drooping line
You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
Picture and Color P61927
My Picture is Bulging and the color isnt set right.how can i fix it.
its a RCA Model # P61927
Dec 10, 2008 | RCA P61927 61" Rear Projection Television
Convergance,and distorted projection,colors will not align
These tv's have a separate convergence power supply that goes bad. This will cause the problem you are having. Depending on the age of your tv, the board may be available
Dec 07, 2008 | RCA P61927 61" Rear Projection Television
SPEED BUMP OR BOWING
Your convergence chips and convergence resistors are going bad. When they fail the screen colors will look distorted/3d looking. Another symptom is one or more colors can't be converged using the convergence menu. You can purchase the parts over the internet. Just make sure you get Sanyo brand convergence chips and the correct flame proof resistors. You can also check the site www.TvRepairKits.com for a kits.  Just make sure you replace both of the convergence chips and all of the convergence resistors.
Aug 25, 2008 | Philips 60PP9202 60" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
