Question about RCA P52926 52" Rear Projection Television
P52926 I am told I have a vertical alignment problem but am unable to figure out how to fix it. The picture dips in the middle and the letters look like a rainbow.
  • millerd43 Jun 09, 2008
    Just couldnt figure out how to get to the convergence menu. Thanks anyway.
  • 927 Answers
You do not have a vertical problem, you have convergence concern. Try unplugging the TV for 5 minutes. If no fix call only an authorized service center. GOOD LUCK!
Posted on Jun 01, 2008
RCA P61927
You are describing a convergence issue. Rear projection CRT sets use THREE separate color 'guns' that need to be aimed properly every so often, sometimes every month, sometimes once every year, but usually when its moved. Convergence operations are typically a user serviceable function and the process can be started from the menu.  If you have tried doing the user convergence and it is still a bit off you will need to get it to a repair technician that can either fix the power supply or mechanically align the guns.  In my many years of TV experience, rear projection CRT's are typically discarded for two main reasons; either the power supply is causing convergence issues or the blue gun is dull or dead. Either way if you cannot perform a convergence yourself you are looking at $200+ in repair and parts. I would suggest finding a local television repair technician, not many left I know, and get a quote.
May 26, 2008 | RCA P52926 52" Rear Projection Television
Red color alignment problem
1) Whenever a rear projection TV has convergence issues, the
fix involves replacement of both IC's = STK392-110.......sub to
STK394-160E for improved durability...........
2) Soldering only is a temporary "fix" at best
3) Do not allow generic IC's, OEM quality or better = I use
Hitachi brand,made by Sanyo,with no callbacks....
4) Skill level needed = above average,....needs chassis pull...T.
Nov 14, 2007 | Hitachi 43FWX20B 43" Rear Projection...
The heads of the people are cut off the picture is to high
If the top of the picture is stretched and off the screen and the bottom appears normal, this is usually a vertical deflection problem and will need a repair tech to fix. If you continue to watch the set with this problem present it will only get worse and can cause more problems.
Nov 27, 2009 | RCA P52926 52" Rear Projection Television
Letters on screen missaligned horribly, red/blue off wakko
It sounds like a convergence problem. A fairly common reason for this problem is the convergence chips have failed. They are usually referred to as "STK" chips since the model number of these chips start with STK. I will put a link to another part of this site where someone has posted pictures and a link where to get the parts should you decide to fix it yourself. Look at Ecullier2012's posting. Jean's posted site will not fix this problem. Hope this helps you out. Let me know.
http://www.fixya.com/support/t1684874-screen_blue_green_green_red_outlines
Mar 14, 2009 | Sony KP-51HW40 51" Rear Projection...
Intermitten snowy picture
well the vertical deflection IC is good but you need to get the conversion chip for it , it controls the vertical , horizontal, color, color alignment ,
it would be wise to get it done soon before anymore dammage is done
Oct 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Vertical Alignment ProblemHitachi 50"
resolder the vertical ic. you have bad connections on the bottom
Jun 12, 2008 | Hitachi Televison & Video
Picture gone.
You have bad conv. ic's.On these sets when the ic's go bad it will usually pop a fuse or burn up a few safety resistors,causing ith video to go away.
Mar 03, 2008 | Toshiba 50H72 50" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
77 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
